Front coil springs rubbing bump stops? - TTORA Forum
post #1 of 6 (permalink) Old 05-25-2011, 11:19 AM Thread Starter
razr's Avatar
I have a '97 FZJ80 w/Slee 4" front coil spring and bump stop extensions. When the suspension compresses the inside of the front coil springs rub the steel lip on the bump stops, this happens on both the passenger and driver sides. Do you just grind them down?
razr is offline
post #2 of 6 (permalink) Old 06-03-2011, 10:54 PM
vistataco's Avatar
Send a message via Yahoo to vistataco
I had the same issue with my FOR 3.5" lift. I just removed the metal sleeve and the noise is gone.
So-Cal Staff Member STFU and WHEEL!!!
- 1997 Lexus LX450 Locked F/R, F.O.R. 3.5" coils with 7100's, 35" BFG KM2, DO sliders, DO bumpers, 4.88's, Yaesu 7900 (KJ6VCY), Superwinch 9500, and other do-dads. (Satin black)
2011 Lexus GS350 Pearl White (DD)
vistataco is offline
post #3 of 6 (permalink) Old 03-17-2012, 01:42 AM
I took my rig out again to test out my most recent fender trimmings today, and, the trimming was quite successful, no rubbing! But... A familiar sound was still present which I thought was my tread lugs hitting my fenders, but I discovered that when either side of the front end is extended to the max, my coils (not only are removed from contact at the top) but are severely rubbing on my bumpstops/spring perches, not sure what to call them, but the large tubular peice that comes down through the center of the spring.Is this something to be concerned about, or is there a way to remedy the problem?
jackmartin199030 is offline
post #4 of 6 (permalink) Old 03-18-2012, 02:19 PM
4banger4x4's Avatar
if its over extending get some limit straps and it will stop the coil from coming out of its seating and should stop the rubbing if youset the limit stap to the right lengh
Awesome $33 PVC snorkel
Diff Breathers front and rear
KC 55w flood reverse light
Mickey Thompson classic lock II 15x8
Cooper SST 33 12.50 15
All-Pro 3" standard leafs
Rear 5125's
SAW 2.0s 650#
EBC Rotors and Green stuff Pads
SS brake lines front and rear
ECGS front 4.56 open
OEM rebuilt CVs from CVJ
4banger4x4 is offline
post #5 of 6 (permalink) Old 03-19-2012, 09:54 PM
Land Pirates Off Road's Avatar
yep, limit the suspension with straps. It will take care of that problem.
Drive Harder, Faster, Safer & keep it rubber side down!
https://www.facebook.com/LandPiratesOffRoad
Landpiratesoffroad.com
Land Pirates Off Road is offline
post #6 of 6 (permalink) Old 04-05-2012, 09:07 AM Thread Starter
razr's Avatar
I ground down the lip on the bump stop cup. Just on the front where it rubbed.
razr is offline
Timbren Front Bump Stops jmoss13 Parts/Electronics/Wheels/Tires 8 03-03-2011 05:07 PM
bump stop placement for front springs of SAS Bear Solid Axle Swap Tech 30 11-12-2010 02:45 PM
front factory bump stops? dunescott Long-Travel Suspension Tech 1 02-09-2010 09:48 PM
Front IFS bump stops meat Tech 5 11-03-2005 01:23 PM
Front bump stops Crash Solid Axle Swap Tech 6 05-17-2005 11:36 AM
