97 T100 Dana 44 SAS - TTORA Forum
post #1 of 29 (permalink) Old 02-17-2012, 04:51 PM Thread Starter
wsxpos54's Avatar
97 T100 Dana 44 SAS
After spending hundreds of hours on the forum and sending a ton of PM’s its my turn to try and help someone out. The truck is my DD 97 T100. With the 3” body lift Ball joint spacers and AAL in the rear on 35s I was destroying CV shafts like crazy and bent 2 idler arms.
After breaking or bending something on every trip I decided it was time to start gathering parts. A huge thanks goes out to Zac at Rustys Off Road and also Josh at Inchworm Gear. Once you deal with companies like those its hard to call anywhere else.
Parts List: Front
Chevy D44 passanger side drop axle
Re-geared to match the rear 4.56 with aussie locker, warn hubs
Skys Off Road Full size axle front hanger
Rustys Off Road RX300 shocks
Trail Gear 47” long 3” lift front leaf springs, shock hoops, 5” shackle, shackle mount (from josh @ inchworm gear)
Independent 4x Right side flat top knuckle
This is how the front sat the night the swap started. (cell pic sorry)
97 t100 SAS rear 4 link 4.56 aussie front lockright rear 35s
My build-http://www.tacomaterritory.com/forum/showthread.php?t=185319
wsxpos54 is offline
post #2 of 29 (permalink) Old 02-17-2012, 05:05 PM Thread Starter
wsxpos54's Avatar
Since both Cv’s were blown, the idler arm was bent, and the control arm bushings were frozen allowing for no caster adjustment I took out the plasma cutter and went to town.
The front diff with 4.56 gears and aussie locker is still available for sale. It works great and has never given me a problem.
After an hour fri night I had the front cut off and was ready to start grinding.
wsxpos54 is offline
post #3 of 29 (permalink) Old 02-17-2012, 05:24 PM Thread Starter
wsxpos54's Avatar
Saturday a few buddies of mine stopped over to help out. Since the plasma cutter is 20 years old and I never used it before, I left a lot of over hang from what was cut off.
The upper control arm mounts are also a part of the motor mount. I did not want to leave them open so I cut them as flush as I could with a sawzall and made some caps from some 3/16” scrap.
I never really saw any rear shackle mounts/setups so I decided to try my own way. I used a piece of 3/16” plate steel about 9” long 5” wide to make the base for the rear shackle mount. The rear mount is a Trail-Gear (from inchworm gear) shackle mount and the gussets were from rustys off road.
wsxpos54 is offline
post #4 of 29 (permalink) Old 02-18-2012, 12:19 AM
weltz99's Avatar
Send a message via AIM to weltz99
mass huh? part of any clubs down that way? Im up in northern vt but wheel all over.
I hate cookie cutter rigs....
Wheelin Rig: 99 Taco reg cab
Full cage, 3 link and full width build up here!!
Tow Pig: 07.5 Duramax ecsb
4" dumped exhaust, AFE Stage 2 intake, EFI live and some tranny upgrades
weltz99 is offline
post #5 of 29 (permalink) Old 02-18-2012, 06:37 AM Thread Starter
wsxpos54's Avatar
i just joined northeast toyota crawlers, i also have a small group of 12 that wheel with us every other week during the summer. i can Pm you a schedule as soon as we line the dates up.
wsxpos54 is offline
post #6 of 29 (permalink) Old 02-18-2012, 12:55 PM Thread Starter
wsxpos54's Avatar
I pushed the front hanger as far forward as I could and after double checking everything was straight tacked everything in place.
I couldn’t wait any longer and wanted to see a little flex. Set the truck on its own weight and went up with one lift arm under the axle. I stopped before it got to close to the lift incase it slid off.
I used the pre-made 14” travel shock hoops from Inch worm Gear and Rustys Off Road Rx 300 remote reservoir shocks in the front.
wsxpos54 is offline
post #7 of 29 (permalink) Old 02-18-2012, 01:10 PM Thread Starter
wsxpos54's Avatar
After a whole weekend of nonstop work the front end was done and ready for paint. Imho the truck is way too tall for 35s. my plan is to remove the body lift and let the front settle before doing any suspension changes. It rides down the road awesome and has way less body roll then the ifs did. It handles the normal bumps a lot better as well. I did have a problem on my first road trip. The front leaf springs had a lot of play in the hanger and caused a serious death wobble. I made some small spacers a little wider then a washer for each side of the leaf spring bushings. This took up 98% of the play and stopped the death wobble. I am still waiting on a front drive shaft but took some poser shots in my back yard.
wsxpos54 is offline
post #8 of 29 (permalink) Old 02-18-2012, 04:49 PM
Supra TT's Avatar
How come you didn't add any reinforcement plates to the frame? Nice work non the less
2000 Taco Ext. Cab 2.7L, SAS D44 3 Link front and Ford 9" Full widths. Never ending cycle...
SAS Gathering
SAS Build Thread
Supra TT is offline
post #9 of 29 (permalink) Old 02-18-2012, 07:42 PM
taco4x4rar's Avatar
Send a message via AIM to taco4x4rar
The T100s, non tacoma trucks, and older 4runners actually had a real frame compared to the tin can the tacomas have for a frame. There is no need for frame plates.
Originally Posted by Jomentum View Post
I drink everclear for the flavor.
Originally Posted by Spacecwboy View Post
I'm still a homo!
http://toyotaoff-road.com/
Randy
2006 Tacoma x-cab, flat bed, leaf sprung Dana 44, Dana 60/ 14 bolt coming soon
1992 Chevy C-1500 swapped D60/14bolt 454 and th400 (wrecked it)
taco4x4rar is offline
post #10 of 29 (permalink) Old 02-18-2012, 08:54 PM Thread Starter
wsxpos54's Avatar
thanks.
i had ordered the set from trail gear but they did not line up very well. i am going to make my own soon. once i finish my rear bumper.
wsxpos54 is offline
post #11 of 29 (permalink) Old 02-19-2012, 08:35 AM
Supra TT's Avatar
Still can't go wrong with plating it, beef
SAS Gathering
SAS Build Thread
Supra TT is offline
post #12 of 29 (permalink) Old 02-19-2012, 08:59 PM
Old sleepy guy
Jomentum's Avatar
I ordered my front driveshaft from Tom Woods, he asked a few questions and shipped it out quick. I swear he started building it when we were talking on the phone, and finished it before we hung up.
I Sas's mine in 2007, still need to frame plate mine, and add under engine cross-member .
Joe P....
My T100: http://www.tacomaterritory.com/forum/showthread.php?t=76817
www.yotaranch.com/home
its spelled BITCH and thats exactly what u are
Originally Posted by TOYMINATOR View Post
my girlfriend works
Jomentum is offline
post #13 of 29 (permalink) Old 02-20-2012, 05:56 AM Thread Starter
wsxpos54's Avatar
Thats where i called for mine. i used the print out sheet they had on-line for the measurements.
wsxpos54 is offline
post #14 of 29 (permalink) Old 02-20-2012, 09:11 PM
bigarms23's Avatar
good job nice and clean sas
1988 4.3cpi v6 full width 4runner 37mtrs duals and a happy owner
bigarms23 is offline
post #15 of 29 (permalink) Old 03-02-2012, 02:53 PM
AlienXtx's Avatar
Send a message via Yahoo to AlienXtx
Nice Rig!!
AlienXtx is offline
post #16 of 29 (permalink) Old 03-20-2012, 05:17 AM
Did you do any changes to the axel for caster and camber or pinion angle?
Thanks! Truck looks great.
97 T100 37/12.50/15 MTR's on Chevy alloys, bj spacers, 1 inch body lift, lots of trimming
Under the knife!
I am the toe cutter!Have you seen the night rider!
01 Tundra Stonewell Body ready for shoeing!
hotshoe is offline
post #17 of 29 (permalink) Old 04-21-2012, 09:07 PM Thread Starter
wsxpos54's Avatar
thanks. i have not done much to the truck since i swapped it because racing started. i did use 6* shims but i think the caster is still wrong.
i ordered 4" shackles from inchworm to drop the height and they should be in monday. from there i will work on the caster and see if i have to turn the knuckles. the camber is also off, the tires lean \-----/ pretty bad. i read about off set ball joints and may try those.
wsxpos54 is offline
post #18 of 29 (permalink) Old 04-23-2012, 12:12 PM
AlienXtx's Avatar
I'm about to have to start thinking about this too, I'm running 5" shackles right now and my pinion is almost flat with the trucks weight on it. I was thinging 6* shimswould prob get it just about right.
AlienXtx is offline
post #19 of 29 (permalink) Old 04-23-2012, 04:38 PM Thread Starter
wsxpos54's Avatar
mine was pretty flat as well. i will take some before and after pics with the 5" shackles and 6* shims then the 4" with 6* shims. my caster is well past 6* towards the back of the truck so hoping the smaller shackle will fix that
wsxpos54 is offline
post #20 of 29 (permalink) Old 04-24-2012, 11:38 AM
AlienXtx's Avatar
Cool, I wanna get it set right before I start messing with the drive shafts. I'm running TG 5" springs front/rear and I'm thinking I will be removing some leaves to drop it some, I'm sure they will settle some.
AlienXtx is offline
post #21 of 29 (permalink) Old 04-25-2012, 08:26 PM Thread Starter
wsxpos54's Avatar
i put on the 4" shackles i had josh at inchworm gear make and i am very happy with how it sits. it fixed my caster problem and realized the camber problem was actually the toe of the tires. with the caster so far back the tires looked \----/ but with the correct caster the toe was way off. tires were facing away from each other. i no longer get a wobble and it steers alot better. it also handles the bumps better.
wsxpos54 is offline
post #22 of 29 (permalink) Old 04-25-2012, 08:29 PM Thread Starter
wsxpos54's Avatar
this is how it sat with the 5" shackles, the front was about 1 3/4" higher then the rear.
wsxpos54 is offline
post #23 of 29 (permalink) Old 04-26-2012, 07:21 AM
AlienXtx's Avatar
Looks good, glad that fixed your problem. Mine sits level right now, but I'm not running a bed out back yet, so no weight. I put the TG 5" shackles on Tuesday and they are way better then the one I made.
AlienXtx is offline
post #24 of 29 (permalink) Old 10-08-2012, 04:52 AM Thread Starter
wsxpos54's Avatar
Finally ordered and installed a front drive shaft from Tom Woods. They made it and shipped it not even 24 hrs after i placed the order. Took her out for a test run and need some help with the steering. With the hubs locked in and the t case in 2wd i cant turn at all. ( it is locked in the front). I also need to fool with the rear suspension more.
wsxpos54 is offline
post #25 of 29 (permalink) Old 10-24-2012, 07:07 PM
Question
Love the truck!! I have a 95 T100 Reg cab and was thinking bout changing the suspension in the front. How much you got into this project approx just on the front end??
Otto'stoy is offline
post #26 of 29 (permalink) Old 10-25-2012, 05:13 PM Thread Starter
wsxpos54's Avatar
Thank you. I did the project over time. I just waited until i got good deals and had extra cash. Its really not horrible if you space it. If you want a complete list of parts prices and where i got everything from PM me and i can write a list out.
wsxpos54 is offline
post #27 of 29 (permalink) Old 09-12-2013, 04:22 PM Thread Starter
wsxpos54's Avatar
[URL=http://imageshack.com/i/0o4m2kj][/URL
since the t100 is now a trailer queen I have been doing a lot of local fair mud bogs and small rock crawl courses. The rear does not droop enough and the frame behind the gas tank is junk so instead of wasting time and money on leafs and fixing the frame i want to chop it behind the cab and 4 link it. Would the trail gear 4 link rear kit make a good starting base or should i start from scrap and make it all my own?.
wsxpos54 is offline
post #28 of 29 (permalink) Old 02-02-2014, 03:28 PM Thread Starter
wsxpos54's Avatar
Little progress on the 4 link.
wsxpos54 is offline
post #29 of 29 (permalink) Old 05-27-2015, 04:48 PM Thread Starter
wsxpos54's Avatar
Took a long time but it's finally ready for its first run this weekend.
wsxpos54 is offline
Chevy Dana 44, Ford outers, Dana 70u MandAtaco Parts/Electronics/Wheels/Tires 1 10-17-2010 08:56 PM
hello t100 here keenspeed94 Tell us who you are 1 01-21-2010 01:36 PM
Dana 60 Front and Dana 70 Rear Narrowed FLORIDA apimpdad For Sale/WTB in FL 2 04-13-2009 08:01 PM
Dana 44 and Dana 60 Axles, $50 each NorCalTRD Parts/Electronics/Wheels/Tires 3 05-23-2007 06:48 PM
T100 Oil Pan (YES the one you need for a SAS) DrVic@BallisticFab Parts/Electronics/Wheels/Tires 6 07-26-2006 12:04 PM
