Toy Axle Swap - Page 2 - TTORA Forum
post #31 of 47 (permalink) Old 08-11-2011, 12:10 AM
NorCal Chapter Pres
NorcalPR's Avatar
What brake lines do you need? I have a pair that's the 10mm Flare on one end, and a 3/8(10mm) banjo on the other end. 28" long.
If you're going to use Tacoma Calipers, they'll work great. You can also use them for the tundra calipers. I also have the banjo bolts and the copper washers. Everything is new, enver been used
W6FTW
NorcalPR is offline
post #32 of 47 (permalink) Old 08-11-2011, 11:54 AM Thread Starter
Boonie Buster's Avatar
Thanks for the offer, i'll keep it in mind. I honestly couldnt tell you what brake lines i need yet, aside from just need longer factory lines, I'm going to reuse my tacoma brake calipers for sure, but as to the length of the lines i need, i just dont know yet.
Boonie Buster is offline
post #33 of 47 (permalink) Old 08-11-2011, 07:07 PM
NorCal Chapter Pres
NorcalPR's Avatar
They'll work if you're around 24" frame height on 35's
W6FTW
NorcalPR is offline
post #34 of 47 (permalink) Old 08-12-2011, 08:30 AM Thread Starter
Hmmm.... My goal was 37" Frame Height with 32's....
post #35 of 47 (permalink) Old 10-28-2011, 01:33 PM Thread Starter
I traded my flat pitman arm for a 3/4 drop arm last week. We shall see how long this lasts before i want my flat pitman arm back. But i figure this way, i can relieve the steering shaft angle when the time comes to set that up and also have the ability to throw a stock pitman arm on in a pinch.
I have this weird idea that keeping things to a simple and easy level of difficulty to replace, so i'm not hunting for a one-off custom part at the ma and pa's local mini-mart.
post #36 of 47 (permalink) Old 10-28-2011, 05:49 PM
NorCal Chapter Pres
NorcalPR's Avatar
Oh darn
Just let me know. I still have them...
W6FTW
NorcalPR is offline
post #37 of 47 (permalink) Old 01-07-2012, 02:05 PM Thread Starter
So I updated my list once again.
I have since bought a 4runner E-Locker rear axle with 4.10s. My plans have changed slightly in that i'll run 4.10s and my awesome 32's for a bit longer. Basically adding a step in the process. I'm going to run the stock open 4.10 diff in the front, or get an E-Locker right away for the front as well. Regardless it will have E-lockers front and rear with 5.29s. but I'm just adding a step to the process.
I also ordered the TG tacoma shackle kit. I'm commited now and hoping that my mathz are correct.
I also removed the gears and setup kits from the overall total price, since those are now being sold and not part of the build anymore.
post #38 of 47 (permalink) Old 01-23-2012, 09:32 AM Thread Starter
Just picked up a front housing w/ E-locker installed and Sky motor guard. I have axles coming to me in the mail from another TTORA member (thanks!) Now I need to buy outer knuckles and start building!
Pictures added to original post of front and rear axle.
post #39 of 47 (permalink) Old 02-28-2012, 09:45 AM Thread Starter
Just updated the list further. I have purchased pretty much everything I will need for the swap, aside from some front spring bolts and misc other small parts.
Now to start regearing the diffs....
post #40 of 47 (permalink) Old 04-09-2012, 09:34 AM Thread Starter
Bought some new rubber.
post #41 of 47 (permalink) Old 07-24-2012, 01:44 PM Thread Starter
Now I need to trim the fenders to clear the new rubber.
post #42 of 47 (permalink) Old 07-24-2012, 09:29 PM
Good luck with your swap... I have zero regrets with the yota axle and I'm sure you will feel the same way when it's all said and done!
alove0750 is offline
post #43 of 47 (permalink) Old 01-21-2013, 01:24 PM Thread Starter
So I bought an IFS rear axle housing and soem rebuild parts to house my rear e-locker diff, which will narrow up my overall WMS to WMS, but match the front toy axle with IFS hubs nicely. No need for spacers to match the rear axle width. I have built the front differential, but not really any progress has been made since then.
post #44 of 47 (permalink) Old 01-31-2013, 12:56 PM
Don't use an ifs housing no sense in making it skinnier. Also I wouldn't use a factory toy housing on a sas. They are way to narrow, leafs might be of but with links you will more than likely have to clearance the frame to make the coil overs fit. Then again if you link it just cut the front rails off and build new rails. Look into ruffstuff or some of the other company's that manufacture toy housings, with the exception of trail gear.
alove0750 is a buddy of mine and he still wishes he went with either a custom housing or 80 axles. Heres a link to his build which might help. http://www.tacomaworld.com/forum/1st...xle-3link.html
86 4Runner "The Turtle" - 22RE 5spd, Dana 60, 14 Bolt SAS on 4D's in the works
89 K5 - long term project
02 Tacoma - 3.4 5spd DD
Redneck92 is offline
post #45 of 47 (permalink) Old 06-06-2013, 10:35 AM Thread Starter
I'm going back and forth still on the IFS rear housing, I may give it to my dad for his truck. I'd rather rebuild the rear and toss it in.
I have started to build the front end, I'm finding a few parts I don't need and a few that i'm missing. I'm going to buy a set of taco rotors even though I have some on my truck currently. That way I can clearance the rotors for the wheel hubs without disturbing my truck in it's current state...which is running...
post #46 of 47 (permalink) Old 10-23-2013, 01:46 PM Thread Starter
Very slow progress as of late. But I installed new lug studs and started to assemble the wheel hubs. Bearing races pressed in. Need grease now!
post #47 of 47 (permalink) Old 12-05-2013, 08:41 AM Thread Starter
Plans have changed, anything in the list at the start of the thread is for sale, along with the truck.
PM me for details and pics of parts. I will let you know current asking price of the parts at that time.
Also the Truck is for sale.
?'s about TRD axle swap weltz99 Early Tacoma Tech 11 02-12-2011 07:24 PM
Axle swap littletacothatcouldnt Early Tacoma Tech 10 09-13-2010 11:19 PM
Axle Swap HUNTER_SLLRS Pickup/Early 4Runner Tech 14 11-30-2008 12:39 PM
98 / 97 axle swap jmitchell151 Early Tacoma Tech 9 11-01-2005 03:29 PM
TRD axle swap SAStoy Early Tacoma Tech 10 02-20-2005 08:49 PM
