3 link options - TTORA Forum
post #1 of 13 (permalink) Old 09-20-2008, 01:26 AM Thread Starter
chris85053's Avatar
3 link options
am trying to find a good 3 link set up.. just seening whats stronger using a cross member or mounting off of frame.. opinons what be cool.. and pics whould be even better.. thanks
chris85053 is offline
post #2 of 13 (permalink) Old 09-20-2008, 09:27 AM
awsumdc's Avatar
go to these links to see a three link system that goes to the frame. We have done them on two early model Taco's, a late model Taco and an FJ cruiser. Strong as hell and awesome flex with good road manners.
http://rides.webshots.com/album/378870315SnHRiA
http://good-times.webshots.com/album/564203253zyajmq
http://www.villagephotos.com/members...der_id=2024806
Project 07 FJ Cruiser SAS
Here are some pictures for you of the trucks. They all have the same three link system on them. The FJ nd the older Taco use's Johny Joints at both ends of the links and the '05 Taco use's huge 11/4" hiem joints at the axle end and johny joints at the frame on the links.
They all three use different front axles for the swap. The '02 Taco use's the tried and true Dana 44 out of a Jeep Wagoneer.
The Fj Cruiser use's an awesome Diamond axle housing with an FJ80 high pinion center section with elocker.
And the '05 Taco use's a Massive Currie Enterprise's Rock Jock 60 with 35 spline axles 5.38 gears and ford F-450 1 ton knuckles and unit bearings. Super Super strong.
Three different axles on three different trucks that all use the same three link system.
'05 "SAC" Double Cab TRD Sport 4x4 with Marlin Crawler "Taco" Box and a bunch of other stuff.
Linked, Locked & Large!
"THE BEAST"
AKA "THE BIG SEXY"
Wyatt Scott
3.4 auto crawler install
Installing an FJ Case into an 05+ Tacoma
My Build thread. Building "The Beast"
GOT SAC?
awsumdc is offline
post #3 of 13 (permalink) Old 09-20-2008, 05:40 PM
BOVADS's Avatar
Originally Posted by awsumdc View Post
just saw this pic, nice pic, and i know exactly where it is
BOVADS is offline
post #4 of 13 (permalink) Old 09-23-2008, 09:33 AM
Symon623's Avatar
Chris, here are some pics of my set up. I went off the frame, sacrificed some ground clearence for streetability. The ground clearence really hasn't been an issue.
Here you can see the passenger side frame mount and the upper link mount bolt through the frame;
Drivers side;
All 3;
More pics are here;
http://s78.photobucket.com/albums/j1...ota/?start=all
If you do a crossmember then it has to be removable and then you have to unhook the front suspension for trans removal????
Good luck.
Sy
High Country Renegades
Symon623 is offline
post #5 of 13 (permalink) Old 09-25-2008, 12:01 AM Thread Starter
chris85053's Avatar
anyone out there runs a upper link on the pass side frame with out hitting exhaust?
post #6 of 13 (permalink) Old 09-25-2008, 08:01 PM
awsumdc's Avatar
Yep. All of our top links are on the passenger side at the frame and none hit the exaust. I'll try to get some pics up fr you.
"THE BEAST"
AKA "THE BIG SEXY"
Wyatt Scott
GOT SAC?
awsumdc is offline
post #7 of 13 (permalink) Old 09-26-2008, 12:28 AM Thread Starter
chris85053's Avatar
how should the upper link sit? try to get it level? or at same plane as your lowers?
post #8 of 13 (permalink) Old 09-26-2008, 08:33 AM
awsumdc's Avatar
My top link is almost level with the bottom links. This weekend I'll get some numbers for you so you can have an idea of how we set it up.
"THE BEAST"
AKA "THE BIG SEXY"
Wyatt Scott
GOT SAC?
awsumdc is offline
post #9 of 13 (permalink) Old 09-26-2008, 12:21 PM Thread Starter
chris85053's Avatar
ok cool thanks
post #10 of 13 (permalink) Old 10-14-2008, 08:10 PM
Hutch98's Avatar
Possible for some more pics of the pass side??
"Beer is proof that god loves us and wants us to be happy" Benjamin franklin
Hutch98 is offline
post #11 of 13 (permalink) Old 10-14-2008, 09:34 PM
awsumdc's Avatar
Sorry... ended up busy that weekend. I'll pm you my number. Call me saturady and I'll get some pictures of mine and the '02 Tacoma for you.
"THE BEAST"
AKA "THE BIG SEXY"
Wyatt Scott
GOT SAC?
awsumdc is offline
post #12 of 13 (permalink) Old 10-14-2008, 09:37 PM Thread Starter
chris85053's Avatar
ok cool .. thanks alot...
post #13 of 13 (permalink) Old 11-03-2008, 11:42 AM
awsumdc's Avatar
Here are some of the pictures from Dans Three link.
"THE BEAST"
AKA "THE BIG SEXY"
Wyatt Scott
GOT SAC?
awsumdc is offline
4 Link and 3 Link kit Progress thread DrVic@BallisticFab Suspension 57 10-26-2009 08:37 PM
Link ? ? roll-bar Bob Early Tacoma Tech 3 12-01-2006 09:36 AM
3 link upper link placement roktaco Solid Axle Swap Tech 2 11-25-2005 10:32 PM
4 Link. Factor Suspension 19 09-27-2005 01:35 AM
So how come there is no link Dick Foster News/Error Reporting/Suggestions/Help 4 08-02-2005 05:51 PM
