F-Toy #096 Build Up - TTORA Forum
post #1 of 24 (permalink) Old 03-09-2008, 01:14 AM Thread Starter
muddemon_06's Avatar
F-Toy #096 Build Up
Finally got this thing started today as I got back home with a '90 Toyota regular cab frame, rear leaf's, V6 rear diff, and a 21 spline RF1A T-case. I didn't waste any time slicing the independent stuff out from under it and getting it ready to cleanup. Got fortunate on this frame to not have very much rust..since about 100k it has sat with a 4.3 swap but no wires hooked up decently enough for it to run..someone did it right and coated the frame with quite a bit of rustoleum. This frame has less rust than my original 99 frame from Illinois, so I'm excited that there isn't a lot of rust to clean up. Going to make a call over to Memphis this week and see about when the F-Toy chassis can be ordered.
Here is the specs so far:
99 3RZ and W59
Centerforce Dual Friction Clutch Kit
Marlin W59 to RF1A Adapter
Trailgear Dual Adapter
Front Mini Axle/ Rear V6/Turbo
TRD e-lockers front and rear 4.30 or 4.56
Longfields, IFS hub conversion, Hydro Assist
39.5 IROKs
Perfect IFS Frame
Not anymore..
The transfer case and AA's Adapter(for sale)
Hadn't flexed anything up in awhile so I decided the old John Deere would have to do.
-=Greene County Crevice Crawlers=-
muddemon_06 is offline
post #2 of 24 (permalink) Old 03-09-2008, 01:15 AM Thread Starter
I'm going to get the rest of the scrap metal off the frame tomorrow..so should have more updates tomorrow night.
post #3 of 24 (permalink) Old 03-09-2008, 11:50 PM
midd's Avatar
good travel on the JD. good idea to take the hood off ,so it wont get damaged on the trail.
midd is offline
post #4 of 24 (permalink) Old 03-10-2008, 01:59 PM Thread Starter
Same thing I was thinking...I was wondering when it was gonna lift the rear. Grandpa hit the fire hydrant with it and cracked the hood in like 3 pieces. We checked for a replacement and it was like 500 new.
post #5 of 24 (permalink) Old 03-10-2008, 02:46 PM
Bear's Avatar
Damn Bo! it didn't even occur to me on your other thread! I have an FJ40 frame I need to get rid of, I was going to do something similar with it as you are but it needs to be gone out of my garage.
If I would have thought about you needing a frame you could have probably had it for cheap! you would not have had to cut off the IFS with it!
BEAR
Originally Posted by abbott
GO SPURS GO!!!!
Bear is offline
post #6 of 24 (permalink) Old 03-10-2008, 07:36 PM Thread Starter
Lol well I got a really good deal on this one and too boot, it has way less rust than my original 99 Tacoma frame. Got the frame, tcase, Advance 4.3 Adapter(For Sale), Rear springs, power steering box, and a v6 rear axle. And will hopefully make my money back just on the adapter.
post #7 of 24 (permalink) Old 03-10-2008, 07:47 PM Thread Starter
Slow go..still dragging arse on getting the scrap shiz off the frame. I think all the torching is done and now on to the grinding portion. Good news is I made a call to Trailgear today and ordered the front spring hanger kit, the TG Axle truss, and the creeper gussets. That oughta get me setting on the tires..probably gonna pull some leaves out of the 44044's and see what I can do with them. 300 (44044) vs. 220 (TG) spring rate. Think I'll pull out the bottom 3 leaves and see if it'll flex..if not later on I'll switch to TG springs after I get it fully built.
post #8 of 24 (permalink) Old 03-30-2008, 11:59 AM Thread Starter
Finally an update..
UPS finally came through wednesday before last with my parts from trailgear.
The following day my wheels (courtesy of spacecwboy) came in and I immediately mounted them up. Might I add how hard it is to mount tires on aluminum wheels with steel tools. And before anyone says anything about me using stock 16x7 wheels with 13.50 tires, I have the reasoning. One, for some reason I love toyota factory wheels, I never was satisfied with the black wagon wheels I had on the taco, and even if I had beadlocked them I still don't think I would have loved them. Two, even though the 16's don't have the safety beadlock I will be running stauns in the future so I should not have any problems with blowing beads inner or outer. You can note how later on, sitting with the weight of the frame on them they still don't have much of a contact patch with the concrete but keep in mind they only have 500 lbs on them right now, they have 15lbs of pressure compared to 5-7lbs, and that when i'm finished they should be holding up 3000lbs or better.
And here's the axle mocked into place. I mounted the front hanger 1/4" forward of the stock crossmember using the 44044's with the 3 upper leaves left in the pack. The only place I F'd up was I went ahead and welded the front hanger complete.
Not a bad approach angle.
Got everything bolted up enough where I could roll it around. Havent inboarded the springs yet either, but I believe it will be a must. The only thing striking my curiosity at this time is how close the rear tires are to the frame. I believe they may rub a bit so I may have to use a little spacer on the rear or something. I like the way it sits right now and don't believe I'll change it much.
Here's the only issue I have right now. Like I stated earlier, I F'd up and welded the front hanger solid, and with the weight of the frame I have a 90* shackle angle. Even with the weight of me and the motor on top of the frame it's about an 80* or so. I went by tg's instructions stating, if you use a 4" lift spring or more then mount the hanger 1/4" forward or so, now it seems flush or even a 1/4" back from the stock crossmember might get me around the 50* range.
Lock to lock isn't too bad.
Front
Rear
Ride height right now at the stock trans/tcase crossmember. I'm expecting in between 25-26" with the hanger relocation and the total weight of the rig.
post #9 of 24 (permalink) Old 03-30-2008, 12:01 PM Thread Starter
Another update..called John at Alpine in Memphis friday and he got me the info to get a chassis ordered, expecting 6-8 weeks. Sent my deposit in friday also to guarantee myself one on the truck.
post #10 of 24 (permalink) Old 03-30-2008, 06:01 PM
Machinist Extraordinare
jester_motorsports's Avatar
Bo, what's the wheelbase going to be?
jester_motorsports is offline
post #11 of 24 (permalink) Old 03-30-2008, 06:13 PM Thread Starter
Well from my guesstimates with the tires on measuring by myself its around 105", I believe stock wb is 106", and hendrix's website shows 103". I'm shooting somewhere in between those numbers. Main thing I'm wanting to keep is a low center of gravity. So I've been looking at the trail gear buildup alot.
post #12 of 24 (permalink) Old 04-01-2008, 03:59 PM Thread Starter
Got my invoice back from hendrix... SN #096 wish it would have been 099 hence the year model motor and trans.
post #13 of 24 (permalink) Old 04-01-2008, 11:51 PM
Bear's Avatar
Bo, fixing your shackle angle maybe pretty easy since you went through the frame.
I am guessing you sleeved the hole correct? If you didn't here is the chance to do so.
All you need to do is move your hole for the shackle forward approximately 2 inches and that should correct your angle. Give me a call if you have questions on how you need to go about moving it.
But if you work with that end, you won't need to move your front cross member.
Once you move the shackle position just leave the sleeve in the original hole or if you feel so inclined just cap it and you should be okay.
BEAR
GO SPURS GO!!!!
Bear is offline
post #14 of 24 (permalink) Old 04-13-2008, 04:03 PM Thread Starter
A little more progress.. I got the motor tacked in place yesterday 6" back..really don't have a figure on how much it was dropped. I cut the stock motor mounts off before I measured. Going to get a transmission crossmember fabbed up this week.
post #15 of 24 (permalink) Old 04-14-2008, 01:28 PM
Desert Turtle
Kaistie's Avatar
Wow! I see a lot of work in your future! But, it will be nice when its done.
Pictures:
Kaistie is offline
post #16 of 24 (permalink) Old 04-14-2008, 04:58 PM Thread Starter
Yea the small stuff is what will add up money and time wise..I'm sure that the fun times in the future will make it all worth it.
post #17 of 24 (permalink) Old 04-16-2008, 09:32 AM
Bear's Chauffeur
98taco4x's Avatar
Send a message via AIM to 98taco4x
Looking good man. Actually those big tires look great on the stock rims, I like the look.
98 Tacoma 4wd xcab Sr5 2.7 auto, 265/75/R16 Kelly Safari TSR's, Mossyrock's Sliders, 881's and billy's, OME dakar leafs and shocks.
83 4wd pickup 22r some sort of lift, 5.29's, 36 tsl's, lockrite and spool, and a complete disregard for body damage alot more mods in the works
98taco4x is offline
post #18 of 24 (permalink) Old 04-16-2008, 03:53 PM Thread Starter
Thanks..postponed the trans. crossmember until I get the cases setup and get a look at the driveline angle. Going to get the rear most crossmember/ spring hanger in tomorrow.
post #19 of 24 (permalink) Old 04-16-2008, 11:33 PM
thehackman15's Avatar
Rig is coming along nicely, Anybody ever buy that cab off of you?
thehackman15 is offline
post #20 of 24 (permalink) Old 04-17-2008, 06:50 AM Thread Starter
Thanks..No I still have it. I'm needing to part it out but don't feel like I have the time to post every part and actually get out there and pull the stuff out, I guess one day I will when I start needing the $ bad enough.
post #21 of 24 (permalink) Old 04-17-2008, 05:01 PM
I don't get why nobody has jumped all over that. Get it out to california and i'll take it all off your hands
post #22 of 24 (permalink) Old 04-17-2008, 05:56 PM Thread Starter
Well if Mike delivers my formula chassis he might could drag it back with him if you paid me some freight to get it there. Assuming your close enough to his shop to drive and get it.
post #23 of 24 (permalink) Old 04-17-2008, 08:23 PM
Where is his shop at?
post #24 of 24 (permalink) Old 04-17-2008, 08:45 PM Thread Starter
Santa Margarita, CA
My 98 SAS Build muddertrucker99 Solid Axle Swap Tech 98 03-16-2010 03:14 PM
05 TC 5 lug build 05tacorunner Desert Race Rig Builds 86 03-21-2008 02:38 PM
7sx build up 7sx_Tacoma Tech 2 08-13-2007 05:04 PM
BYB build day on Sat.? 88beeryota Events 0 03-16-2007 01:45 PM
44 Build up Ricks72 Solid Axle Swap Tech 11 01-19-2005 11:44 AM
