Any pics of ground calipers? - TTORA Forum
post #1 of 9 (permalink) Old 02-20-2006, 04:37 PM Thread Starter
The Dude's Avatar
Send a message via AIM to The Dude
So I can get an idea of how much I can grind?
1997 FZJ80, Factory Lockers, 285s, OME lift.
The Dude is offline
post #2 of 9 (permalink) Old 02-21-2006, 07:47 AM
Send a message via AIM to JDUBTacoMUD
i had to do that also to fit the mickey thompson IIs.i bought washers from hardware store to place over lugs and then put wheels on spun them a few tiomes and the caliper and wheel rubbed allowing me to see exactly what i needed to shave down.i wanted to shave as little as possible to clear the wheels.....be careful....ive seen it done on 2 tacos and it worked.......no pics though...sorry....but i know that ridge on the caliper will have some removed
JDUBTacoMUD is offline
post #3 of 9 (permalink) Old 02-21-2006, 10:11 AM
this is just a bad idea all together. it would be in your best interest to just get a different rim. Grinding calipers runs the risk of some serious problems.
Just my
tacoman13 is offline
post #4 of 9 (permalink) Old 02-21-2006, 03:50 PM
YoTRacer158's Avatar
There are enough wheels out there that will fit, why dont you just get some that are known to clear the calipers?
youtube.com/YoTRacer158
YoTRacer158 is offline
post #5 of 9 (permalink) Old 02-21-2006, 03:58 PM
05 taco access cab's Avatar
i had to do a minimal amount of grinding on mine. i just used a file it was so small of an amount of metal to remove. heres a pic of where i did mine, need to put a little paint on the spot. you can see a little flash rust on the spot.
Just wheel it 05 superwhite trd access cab , tinted windows K&N air filter. 2.0 saw wheelers aal wheelers alloy"s 16x8 285/75/16 cooper stt. line-x"d rockers an flares http://photobucket.com/albums/e370/2005tacotoy/
05 taco access cab is offline
post #6 of 9 (permalink) Old 02-21-2006, 04:26 PM
jon_7248's Avatar
Or even heck, get those 1/4 spacers from PepBoys. A buddy and I ran those for a time and never had them break.
My 2 cents = 1 peso
-Jon
jon_7248 is offline
post #7 of 9 (permalink) Old 02-21-2006, 04:48 PM Thread Starter
The Dude's Avatar
have some and they cause vibration
The Dude is offline
post #8 of 9 (permalink) Old 02-21-2006, 05:04 PM
Resident offroad Doc
02tacotim's Avatar
What wheel size ar eyou guys running that your having this prob. I run 16's w/o any probs. On a side note I have a pair of calipers for an 01-04 I can sell you if you need a set to work on.
Tim
02 Tacoma V6 Dana 44 SAC, chromo's, BL 300M joints, full float rear, chromo's, disk's, ARB's F&R, PSC ram assist and a bunch of other stuff
Originally Posted by FURACERMAN
I do this for a living, stacking lifts isn't that bad.
02tacotim is offline
post #9 of 9 (permalink) Old 02-22-2006, 10:22 AM
its not the size that matters. its the offset and how the rims are honed(spelling). tacomas are known for their large calipers and aftermarket companies have started honing the rims differently to fit the tacoma.
Moab 2005 Pics TRD4ME / PARKSOFFROAD.COM Past Events 33 12-12-2005 11:57 PM
Moab Utah and Silverton Colorado Vacation Pics dstrbdone Lets Talk About Wheelin! 5 08-07-2005 07:18 AM
Pics of BAJA 500 prerun w/ donahoe pics BLOWNYOTA Desert Wheelin' and Racing 7 05-21-2005 04:22 PM
How do i post pics or links to pics? RCPractitioner Off Topic 1 03-19-2005 10:52 PM
Ground calipers for 15" steel rims? Peanut Butter Tires/Wheels 10 01-28-2005 08:45 PM
