Noob synth oil question - TTORA Forum
post #1 of 10 (permalink) Old 05-19-2005, 05:30 PM Thread Starter
Howdy all,
I am changing over to M1. I have 81k on my '99 2.7l 4x4.
I have heard some stories about the synthetic oil removing "shellac" upon the first dose of synth. I have also heard that an oil cleaner before the change to synth. is a good idea. SO........
Is an oil cleaner a good idea before changing to synth.?
What cleaner is a 'good' cleaner? I was going to use seafoam...?
Is there anything else I should do / know before changing to M1?
I have read much on this site and I am sorry if this is overly redundant.
Thanks
Mike
aquacryptid is offline
post #2 of 10 (permalink) Old 05-19-2005, 07:25 PM
River Rat
hawaiianbro's Avatar
Switching over to synthetic oils can potentially be a bad thing. The thicker regular oil can cover up and seal cracks inside your engine. Switching to synthetic which is a less viscosity will sometimes seep through those cracks making oil leaks. I'm not positive this will happen, but i've heard multiple cases of this happening. On cleaning agents i've personally used Sea Foam and have nothing but good results come of it! It's also pretty cool to watch the look on your neighbors faces as they come outside to see all the smoke your truck is pouring out.
Kaleo
hawaiianbro is offline
post #3 of 10 (permalink) Old 05-19-2005, 08:51 PM Thread Starter
Thanks. I think the oil was changed regularly before I bought the truck, So I'm hoping for minimal build-up on the seals. I guess I'll do it.
post #4 of 10 (permalink) Old 05-19-2005, 08:56 PM
RedOh3's Avatar
Switching to synthetics is a very wise choice. It will definitely improve the longevity of your engine, not to mention break your wallet every 5000 or so miles.
I switched to synthetics when my truck hit 10000 miles, hoping to get the best of that 400K mark.
RedOh3 is offline
post #5 of 10 (permalink) Old 05-19-2005, 09:10 PM Thread Starter
I was using O.C. Henrys so the price is about equal. I can't imagine 400k. If i can get to the payoff point I'll be happy. Thanks again
that is - happier than i already am
post #6 of 10 (permalink) Old 05-19-2005, 09:37 PM
ciollika's Avatar
yeah synthetics are awesome stuff. unless you're engine is leaking real bad i would go for it. your best bet will be a multigrade 5w30 or 10w30. don't buy that racing oil stuff they sell 50w or 60w whatever it is. had somebody come in just yesterday with a 04 sequoia at the shop and brought their own oil, it was valvoline vr1 50w racing oil... fortunately i was able to talk him out of it. haha sorry for the dumb story, i'm hella bored. later
2001 Toyota Tacoma Ext Cab TRD v6 auto 4x4
4" DeckPlate, Ams Filter, Magnaflow 18", Hayden 678
ciollika is offline
post #7 of 10 (permalink) Old 05-19-2005, 10:46 PM
River Rat
When you switch to synthetic motor oil, do you have to do anything special? Or just drain out the old regular 5w-30 and add in full synthetic? Or should I do half synthetic and then switch to full the next oil change?
BTW, could I still add in lucas oil treatment with synthetic oil?
Thanks,
Kaleo
post #8 of 10 (permalink) Old 05-20-2005, 10:32 AM
Breathegood's Avatar
Just do the SeaFoam treatment a hundred miles or so before your next oil change, then drain the old oil and add the full synthetic. Don't mix full syn with dino juice...might as well buy a blend if you're going to do that. The synthetic will help clean the engine, but you shouldn't need to change it before your regularly scheduled routine as long as you use a quality oil filter. Gaskets and seals that have become saturated with dino oil MAY pose a leakage problem with full syn oil, but IMO the benefits outway the risk.
2002 V6, X-Cab,TRD SUPERCHARGER, IK22 plugs, URD 2.0" pulley, URD 7th injector kit w/ AFR Calibrator, TRD Headers, TRD Cat-Back, AEM Brute Force w/ Dryflow, ported & polished throtle body, URD Crankshaft pulley, 4.56 Motiv gears, ARB RD-90 locker, 255/85/16 TRXuS MT's, DR Coilovers, Camburg UCA, Skyjacker 2.5" leaf springs, Wheeler's SS rear brakeline, Bilstien 5100's, on board air
Breathegood is offline
post #9 of 10 (permalink) Old 05-20-2005, 10:37 AM Thread Starter
Thats what I was looking for. I kinda figured the advantages were worth the possible negatives. I'm disc golfing this weekend so I'll treat the oil before I leave.
I said it before and i'll say it again.....Thanks =)
post #10 of 10 (permalink) Old 05-27-2005, 11:33 PM
Send a message via AIM to Icepuck72
Kaleo
If he is leaking oil at 81k miles he's got much bigger problems on hand. It's not a bad thing to switch to synthetic, no matter what the mileage.
E Pluribus Unum -- Out of many, One
Icepuck72 is offline
