31x10.50 R15 - wheel sizing - TTORA Forum
post #1 of 4 (permalink) Old 06-15-2005, 12:30 PM Thread Starter
oregonmoss's Avatar
I'm considering getting some MT Classic II's for my 1998 2.7L.
I want to run 31x10.50 R15 Toyo Open Country tires on them.
MT Classic II's come in 3 sizes: 15x8, 15x10, or 15x12.
I am pretty sure I want 15x8, but I am wondering at what point do you go to 15x10?
Does anyone else have this combo? I know there are a lot of classic II users out there.
Thanks
oregonmoss is offline
post #2 of 4 (permalink) Old 06-15-2005, 12:35 PM
Thanks
stick with 8" rims for your 10.50s, 4.5" back spacing. 10s are for 12-14" wide tires and those require quite a bit of lift to clear.
post #3 of 4 (permalink) Old 06-15-2005, 01:24 PM Thread Starter
oregonmoss's Avatar
Thanks, appreciate the patience with a wheel rookie.
post #4 of 4 (permalink) Old 06-16-2005, 11:25 AM
shortbus's Avatar
Agreed, stick with 8" wide and about a 3.75" offset.
Running a 15x10 without any lift will cause some serious rubbing issue, plus good luck airing down a 31x10.50 tire on a 15x10 wheel. You'll easily pop a bead. Most people who run a 15x10 have a good amount of lift and run 33x12.50 or 35x12.50.
The only true wisdom is in knowing you know nothing.
-Socrates
shortbus is offline
RTP Funding Letter Mike Land Use Issues 16 07-26-2005 04:36 PM
POP! goes the Wheel Bearing! PappaF2 Early Tacoma Tech 35 06-08-2005 01:32 PM
Wheel Flares? cisobe PreRunner Tech 12 05-31-2005 05:28 PM
31x10.50 r15 or wider mud tires jdiesel Wanted 0 01-31-2005 05:09 PM
Front wheel bearing on 88 4Runner CornbredNE Pickup/Early 4Runner Tech 3 12-22-2004 02:31 PM
