Stinger? - TTORA Forum
post #1 of 35 (permalink) Old 06-24-2005, 10:24 AM Thread Starter
truck ~n~ tow
TacoDell's Avatar
Stinger?
For those who have 'em... (anyone else can keep quiet!!) I operated Scrapers (57's) for years and know what a stinger is used for in that regards... But on these fixed custom tube bumpers with the extra high stinger... what is the purpose? They look odd to me... Maybe if I could lower it down and hook up to my buddy on the trail I could save gas? LOL We could push/pull through anything... Maybe a train of 5 or 6 goin' thru the Sluice Box? LOL.... Really though... please enlighten me.... I put this in the noobie forum so you wouldn't so loudly over this retarded question... SKMB... Cheers...
Yes I read the search threads... to prevent a frontal roll over? WTF... That never worked that way on my 57....
Truck...
Trailer...
Truck build --- Trailer build
TacoDell is offline
post #2 of 35 (permalink) Old 06-24-2005, 10:58 AM
Desert Moderator
Tweeter's Avatar
Yes, it's to prevent a front roll over, or help "vault" up onto rocks or other obstacles. I wouldn't flame you if this wasn't in the newbie section, because not a lot of people ask this over and over again
Tweeter is offline
post #3 of 35 (permalink) Old 06-24-2005, 11:06 AM Thread Starter
truck ~n~ tow
TacoDell's Avatar
So that weak looking loop could support the weight of the whole truck? OK.... I'm a retard.... flame away!!! LOL... Some body got some pics of this in action? I'm getting ready to have a bumper made and want to be sure I don't need to add this bling!! LOL Cheers...
Truck...
Trailer...
TacoDell is offline
post #4 of 35 (permalink) Old 06-24-2005, 12:59 PM
tbplus10's Avatar
A correctly built bumper with a stinger isnt as weak as you seem to think, the side bars support the center, which is usually boxed, and there are at least 4 attachment points to the frame, the whole bumper is usually made from 2" .120 wall tube, the same material that a good pair of sliders is made from, and those appear to support a trucks weight very well.
If it's just "bling" to you then dont add it, no rule say's every bumper has to have a stinger on it.
Tim
tbplus10 is offline
post #5 of 35 (permalink) Old 06-24-2005, 01:10 PM
Desert Moderator
Tweeter's Avatar
I agree if you're not crushing rocks in the Rubicon every other weekend don't bother. But if you are rockcrawling at steep angles you might consider some "weak metal" that could save your front end or even roof of your car. I have a custom bumper with 10 bolts holding it in all grade 8 because if I face plant I'd rather be safe than sorry. Plus it's detachable
Tweeter is offline
post #6 of 35 (permalink) Old 07-29-2005, 11:26 PM
I think I remember where Moab is?
mr.trd's Avatar
They also come in very handy when crossing large cracks. They stick out and catch the other side of the crack so you don't fall as far in or to make the crack passable at all.
Brant Luckow
INACOMA
'06 d-cab TRD Off-Road
Lift Me, Lock Me, Use Me, Abuse Me
mr.trd is offline
post #7 of 35 (permalink) Old 07-30-2005, 12:13 AM Thread Starter
truck ~n~ tow
TacoDell's Avatar
Well I better get one then... as my girl has a big crack I keep falling in... I tied a rope to a tree and around my ankle but the suction from that crack was too much and it just sucked me in... Maybe it's just my poor crack crossing skills.... fawk....
Truck...
Trailer...
TacoDell is offline
post #8 of 35 (permalink) Old 07-31-2005, 09:52 AM
They are great if you are climbing a very steep ledge and someone can attach a strap to it to help pull down your front end, also in a roll it can keep you from damaging your radiator, so that you have more of a chance of driving your truck home rather than not because your radiator got jacked. added lazy man bonus, after winching up a ledge and using a tow strap around a boulder or tree to anchor to and you know you are gonna need to winch a little farther down the trail again, you can leave winch line attached to strap and then loop strap around stinger, for ease of access later on down the trail, thus the lazy man use
Truck specs:2001 D-cab Taco with solid axle conversion, front and rear 65" wide Diamond axles, Tundra 8 inch rear w/ARB, H.P. front w/ARB 30 spline Long's, full floating rear from FROR and blah blah blah, IE lots-a cool stuff.
Later~captkirkyota~Kirk
Captkirkyota is offline
post #9 of 35 (permalink) Old 07-31-2005, 10:04 AM
saves the radiator in a rollover
booger weldz is offline
post #10 of 35 (permalink) Old 07-31-2005, 10:05 AM
it sticks above the hood 8-12'' or so...
post #11 of 35 (permalink) Old 07-31-2005, 10:28 AM
mr.trd's Avatar
Just strap a 2x4 across your ass and that should prevent you from falling into any womans crack. If not, then that crack is deffinately wore out!!!!
Brant Luckow
INACOMA
mr.trd is offline
post #12 of 35 (permalink) Old 07-31-2005, 10:41 AM
Hey booger, is that steel tube or pipe for your exo?
AND have you ever needed to remove your bumper?
Most around here say to go bolt on, but I say phooey, how often do you REALLY NEED to remove your front bumper????? IF it ever becomes absolutely necessary, one could cut a few welds and then re-weld it. I am of the belief the a welded on front bumper is stronger than bolted for all the reasons one would need a strong bumper. your thoughts?
post #13 of 35 (permalink) Old 07-31-2005, 10:58 AM
mr.trd's Avatar
I know that this question isn't for me, but here are my thoughts. Welded is much stronger than bolted. The only reason for a bolted on bumper is if you have any plans of pulling out the motor or you are still IFS. If you are still IFS and plan to do a SAS then bolted on is good so that you can remove the bumper do your brackets, hangers, and frame plating, then modify the bumper mounting to fit on with all of that stuff, then weld it on!!!! Although Steve at CBI has only done two from bumpers on SAS'ed tacomas, they are both welded on!!!
Brant Luckow
INACOMA
mr.trd is offline
post #14 of 35 (permalink) Old 07-31-2005, 11:01 AM
Agreed.
post #15 of 35 (permalink) Old 07-31-2005, 01:22 PM
mr.trd's Avatar
So are you going to be able to make it to Moab over Labor Day or has the Dusy trail broke the bank??? Just wondering to get a feel for how many people will be there..Would love to have you there man!!!!
Brant Luckow
INACOMA
mr.trd is offline
post #16 of 35 (permalink) Old 07-31-2005, 01:31 PM
Need I say more?
post #17 of 35 (permalink) Old 08-01-2005, 06:52 PM
weld on for sure, not ehough places to get enough bolts in enough places to ever make it worthy. my junk is made outta schedule 40 pipe(not the junk from ace hardware). i gave up on HREW and DOM tubing a few destroyed vehicles ago. ive never had to remove the bumper, but it is a pain in the arse to check the oil, adjust valves, etc without standing on a milkcrate or crawling up into the 'stinger' area.
post #18 of 35 (permalink) Old 08-01-2005, 07:04 PM
Cool, that's what I thought. Mine is REALLY tight up against the body in order to remove the winch I'll have to remove the grille which is those snap thingy's. My stinger is definitely not as far out and high as yours, I basically put it just high enough to see a little over the hood and to protect my radiator. Thanks again.
post #19 of 35 (permalink) Old 08-02-2005, 10:39 AM
Desert Moderator
Tweeter's Avatar
I know I said 10 bolts, my bad I must've been sniffing too much glue that day...there are only 4 bolts in the front since it comes through the OEM bumper, in case I ever need to take it off and get to the radiator.
Tweeter is offline
post #20 of 35 (permalink) Old 08-02-2005, 11:05 AM
Dick Foster's Avatar
Tsk, tsk, tsk.
I just don't know what I'm going to do with with you, Kirk.
Dick Foster is offline
post #21 of 35 (permalink) Old 08-02-2005, 03:28 PM
Tsk, tsk, tsk.
Huh? Why The Dick........ whatever do you mean???
post #22 of 35 (permalink) Old 08-02-2005, 03:54 PM
Don't stand there and play dumb with me mister!! You know exactly what I mean.
That sounds kinda like how your dad talked to you, huh? Probably immediately preceding a whoppin for some dumb stunt that you'd pulled and figured that you'd get away with. LOL
post #23 of 35 (permalink) Old 08-02-2005, 04:18 PM
HUH???????? Now I'm really confused, and I really don't know what you meant. Please explain.
post #24 of 35 (permalink) Old 08-02-2005, 04:21 PM
You know I'm agin welding stuff that you are going to beat up to the frame, things like sliders and bumpers. It was a JK.
You startin to slip on me, Kirk? You usually pick up on stuff like that.
post #25 of 35 (permalink) Old 08-02-2005, 04:39 PM
Oh, yeah I should've huh? I'm running on empty the past week and feelin puny today, so i guess I'm not as sharp as one should be to keep up with The Dick!
Oh and , bolt on sliders and bumpers suck! Weld on's rule!
( I now run for cover as I've prolly unleashed the wrath of The Dick. )
post #26 of 35 (permalink) Old 08-02-2005, 05:09 PM
Talking
It quite alright with me if you want to build a ghetto rig. As long as I had the change to warn ya . You go right on ahead with your mule headed ways. It'll just give me all that more ammo to work with down the road when you go and bash em up on th rocks. That is when you ain't got it all buried up to the frame rails.
Ya thought that was all over didn't ya. Three times in one day for the trail lead, indeed.
post #27 of 35 (permalink) Old 08-02-2005, 05:25 PM
post #28 of 35 (permalink) Old 08-02-2005, 05:34 PM
post #29 of 35 (permalink) Old 08-02-2005, 06:35 PM
c/mon dick. if hes gonna build a rig at least let him build it right(bolt on hard parts??). it obviously wasnt intended to be all show no go with those axles
post #30 of 35 (permalink) Old 08-02-2005, 06:42 PM
Mike's Avatar
Tell Dick that welding rock sliders to the frame is the best way. Then duck, LOL!
Later,
....Mike
Mike is offline
