NOOB with 3 questions. - TTORA Forum
post #1 of 11 (permalink) Old 07-08-2005, 10:02 AM Thread Starter
drewcruikshank's Avatar
greetings from southern MD. noobie here. first post and all. go easy on me.
i have 3 questions for you guys.
Just got a 98 sr5 TRD. it has the 2.7L, manual trans. and 115k on the odo.
Need help in the following 3 areas:
-Clutch
-Timing set
-header/exhaust
-clutch is about ready to go. considering a centerforce stage 1. just wanna know if this will last for another 115000. should I just go with OEM which i think is LUK. no real performance mods. by the way running 31-10.5-15 MT's.
-I have heard of timing sets with metal backed followers that are supposed to be guarenteed for the rest of the life of the vehicle. where can I get one and how much. This may be a stupid question but are the stock chains already double rollers stock and if not is there a conversion kit.
-i have heard that LCE and NWOR have the best headers out there. My question is will these bolt up to the stock exhaust system and do they have O2 sensor bungs in them. If they dont, does anyone know of one that does. I guess i could just purchase the full stainless system from NWOR and not have to worry about it for the rest of the life of the vehicle but the price makes me feel funny in my pants. kinda like after i eat lotsa taco bell and corn.
are there any decent trails in MD and anyone that feels like taking me out and showing me the ropes. my experience is limited to running the power lines and swamp. nothing like the pics i have seen guys in CO and Cali.
I have been to the maryland TTORA and it seems kinda slow around there.
thanks in advance and sorry for the huge post
drewcruikshank is offline
post #2 of 11 (permalink) Old 07-08-2005, 10:59 AM
Nullifier's Avatar
well the LCEheader has everything you need It will mount right up, Good quality and price.
I think that if you are planning on wheeling hard then an upgraded clutch is a good way to go. If your wheeling is casual then a factory clutch should suffic. I got 133k on mine and it is just needing attention. Of course I only really use my clutch to get into 1st or reverse.
"96 Taco with to many mods. Currently awaiting a Xcab swap and flat bed.
www.canoeescape.com
Nullifier is offline
post #3 of 11 (permalink) Old 07-08-2005, 11:03 AM
LavosTRD's Avatar
you dont need to touch the timing chain on that engine unless something goes wrong, and its not something that happens at all
LavosTRD is offline
post #4 of 11 (permalink) Old 07-08-2005, 12:59 PM
I would not recommend the Centerforce I clutch. Too much grab on those clutches for your truck. Either go Centerforce DF (I don't think they offer this for the 2.7L engine), kelvar composite (big $$$) or a stock replacement. The stock clutch from the factory is Aisin, but Luk or Valeo are equals.
No guarantee on the guides, but they do last a long ass time. I replaced my 2.7L after 230k miles and the guides looked like new.
As for double rollers, I only see the need if you are building a performance engine with high compression, aftermarket cams, etc. For a stock engine, the stock timing chain should outlast the engine. Your head will crack before the chain takes a shit.
I know for sure the LCE header has the O2 flange and is a direct bolt-on replacement for your model. I'm sure the NWOR has the flange as well, it would be idiotic for them not to have O2 flange when all the Tacoma models have a front 02 sensor.
post #5 of 11 (permalink) Old 07-08-2005, 01:56 PM
Critt50's Avatar
Send a message via AIM to Critt50
I just put on a CenterForce D/F and it is the S**t. I highly recommend going with this for any replacement.
"When you lose, say little... When you win say less"
"Good people sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf."
"America is not at war. The military is at war. America is at the mall."
Critt50 is offline
post #6 of 11 (permalink) Old 07-08-2005, 11:17 PM Thread Starter
the D/F is the dual disk right? how much more is that than the regualr stage one unit? Anyone have high miles on a centerforce unit? i know they have better holding power and all that jazz initially but will they last for 100k+ like the stocker? thanks for the rest of the info and not just saying "use the search function".
post #7 of 11 (permalink) Old 07-09-2005, 02:04 AM
Like everyone else said, you shouldn't have to worry about the timing chain with the 2.7L. The older 22RE 4 cylinder had a plastic timing chain guide that would eventually crap out. But these newer 2.7L's don't have that problem.
I installed an LCE header on my 99, and it was an easy, direct bolt-on. Although they supply a replacement Toyota OE gasket for the header - cylinder head, they don't supply a Toyota OE gasket for the EGR tube flange. I would suggest getting one since the LCE EGR gasket blew out on me 3 times.
Don't know anything about the clutches, though, so I can't comment on 'em.
Ed Q.
'15 Toyota Tundra SR5 TSS DC 4X4
equin is offline
post #8 of 11 (permalink) Old 07-09-2005, 06:40 AM Thread Starter
sweet. thanks
post #9 of 11 (permalink) Old 07-09-2005, 11:48 AM
the nwor header has the O2 sensor mount but if you have the dual CAT you'll have to have it relocated back a few inches to mount up to the header pipe.
the LCE has a better rep of being a direct or damn-near direct bolt-on application. There are issues with the nwor but it does provide better low-end performance. the LCE and Downey headers are for hi-end gains.
post #10 of 11 (permalink) Old 07-09-2005, 03:45 PM Thread Starter
is the NWOR header ceramic coated?
post #11 of 11 (permalink) Old 07-10-2005, 01:04 AM
the one I tried wasn't but call them and see if there has been a change...that was 3 yrs ago
Final Suspension Questions (Hopefully) ShadyRevelation Suspension 7 10-21-2005 02:23 PM
Extreme noob suspension questions nilson Suspension 11 06-29-2005 07:05 PM
Fabtech Lift Questions.. PhateX1337 Suspension 10 06-23-2005 11:12 AM
self install questions...please help. ck_taco Suspension 16 06-02-2005 08:15 PM
Few Questions Before Ordering Lift Tacoma4Life06 Suspension 7 12-31-2004 03:28 PM
