Transitioning from 3in body lift to a 1 in - TTORA Forum
post #1 of 5 (permalink) Old 05-01-2012, 10:30 PM Thread Starter
tacoma818's Avatar
As the title says I am tired of the body lift that came on the truck, I have read through several forums about completely removing the lift back to stock but my question is would there be any thing as far as steering spacers and things of that nature that would go on with the 1 inch or does the steering stay the same as the stock position on a 1 in. I hate the huge gap in between the bed and fram rails and also hate how the bed shakes more than it should when I go over an bumps while driving
02 taco 2.7 4x4
addicted offroad front bumper
tg sliders
saw 2.0
Bili 5125
OME Dakars
Open 4.88s
Mickey Thompson classic II 16x8 285/75/16 Nitto all-terrains
tacoma818 is offline
post #2 of 5 (permalink) Old 05-02-2012, 03:28 AM
Tacoma Jake's Avatar
Yes, there are a few things you dont need to do with a 1" bodylift. Take a look at 4Crawlers Instructions as well as Performance Accessories Instructions to get an idea of what needs to be done with different size lifts. Your bed shouldnt really be shaking any more with a bodylift, and that gap can be covered with gap gaurds...
01 ext cab - In Progress
99 ext cab SAS'd (Sold)
95.5 ext cab (Sold)
97 ext cab (Totaled)
-Oregon TTORA
Tacoma Jake is offline
post #3 of 5 (permalink) Old 05-02-2012, 08:02 AM Thread Starter
tacoma818's Avatar
Hmm you dont think with the extra height and no weight in the bed would make it shake more not being a smartass ha thats a legit question. What would be some things to look for that would cause it all the bolts are tight i wonder if it was installed incorrectly one of the pucks looks like it was melted or cut or something before installing.
02 taco 2.7 4x4
tg sliders
saw 2.0
Bili 5125
OME Dakars
Open 4.88s
post #4 of 5 (permalink) Old 05-02-2012, 12:04 PM
Check the bed mounts themselves. The bed will shake a bit on these trucks due to the weaker rear frame section.
post #5 of 5 (permalink) Old 05-02-2012, 06:46 PM
I guess if you think of the frame as a fulcrum, then yes the bed does move more, but only because its taller, so it travels a greater distance (side to side for example) at its peak.
If you think of the frame and bed as one entity, the bed wont "shake" any more or less with a bodylift.
There are a lot of things that can cause a bed to shake. If the bed bolts were loose that would certainly cause it to shake, although you would probably be getting some noise with that. An unbalanced tire, wheel, driveshaft, bad axle, or suspension, etc...
A little bed shaking independently from the cab is normal. The frames are made to flex and move slightly.
95.5 ext cab (Sold)
-Oregon TTORA
Original body bushings/body lift chelms27 Exterior/Paint/Body Panel Modifications 2 11-30-2008 12:47 AM
Con's & Pro's of Body lift compared to Susp lift Giggs Newbie Tech 17 09-21-2007 01:33 AM
Complete RB 2" Body Lift with Gap Gaurds and Poly Body Mounts Dunk Parts/Electronics/Wheels/Tires 11 12-04-2005 01:35 AM
4Crawler 1" Body Lift w/ Poly Body Mounts - $220 hawaiianbro Parts/Electronics/Wheels/Tires 14 10-24-2005 12:20 AM
Body Lift, 33” tires, Body Mounts, 2.7L supercharger, Header and LOTS MORE! Supercharged 2.7L Early Tacoma Tech 4 09-20-2005 11:25 AM
