throttle and intake question - TTORA Forum
post #1 of 3 (permalink) Old 08-09-2016, 12:23 PM Thread Starter
Question throttle and intake question
I have just recently gotten a 91 Toyota 4runner with the 3.0 v6 EFI I want to delete the air box and the throttle deal on top of the airbox not sure what its called and do a cold air intake is It possible or do I need that piece on the air box
jmilam is offline
post #2 of 3 (permalink) Old 08-27-2016, 03:29 PM
04dblcab's Avatar
Yes you do need that. I believe the part you're referring to is the mass air flow meter...k/n sells an intake for the 3.0 that uses that part when you install the intake. Google search Toyota 3.0 k/n intake. When you install the intake, the mass air flow meter goes between the filter and the intake tube. If that makes sense. But yes, you do need that.
Sent from my iPhone using Tapatalk
04dblcab is offline
post #3 of 3 (permalink) Old 08-27-2016, 03:32 PM
04dblcab's Avatar
http://www.knfilters.com/mobile/mPro...x?prod=57-9006
I had this is my 3.0 pickup. Worked great!
04dblcab is offline
throttle and intake question jmilam Newbie Tech 0 08-09-2016 12:13 PM
throttle body and intake plenum tacoma_2002 Parts/Electronics/Wheels/Tires 3 01-09-2010 08:02 PM
BG throttle body and intake cleaner CanTaco Newbie Tech 1 05-19-2008 07:07 AM
Air Intake and Throttle body spacer NcYota99 Performance/Engine/Exhaust 23 02-26-2007 03:22 PM
Adding deckplate on top of intake and throttle body? Wheelin taco2131 Newbie Tech 24 01-06-2007 12:39 PM
