If manual windows...
there is a better tool for removing the clip securing the window crank handle.
as well, lifting the clips mounted in the door's surround without ripping then out the door panel.
And they don't cost much.
Seems the OP of these videos tried using a home brew method of removing the window crank.
Tho' it can be made to work... it's not as easy as using the tool.
turn the crank so clip is vertical. get a shop rag and straddle crank from bottom. rock and
pull rag upwards clip should come out. did it this way with old school toyotas. not sure if the newer models are different.
