Any Problems fitting 33s under 3" lift - TTORA Forum
post #1 of 24 (permalink) Old 03-24-2005, 01:04 PM Thread Starter
I have a 02 Tacoma Double Cab TRD. I want to know about any problems that might come up from putting 33s under a 3" Revtek lift. i.e. fender rub, wheel rub, drivetrain vibrations
midnight rider is offline
post #2 of 24 (permalink) Old 03-24-2005, 01:12 PM
sjvicker's Avatar
depending on the type of tire you get and the rim you have will determine how much you rub.... I rubbed 33x12.5x15's on a 10 inch rim with 4 inches of backspacing whenever I would turn with 4 inches of lift. I would say that if you wouldn't mind doing the pinch weld mod and running a skinny 33 you should be fine. But then again...
1989 Pickup - Extended Cab 22RE
sjvicker is offline
post #3 of 24 (permalink) Old 03-24-2005, 01:18 PM Thread Starter
do you think it'd be better to go with a 16X8 rim. and where was your tires rubbing at
post #4 of 24 (permalink) Old 03-24-2005, 01:39 PM
Re-Member 9/11
nhlbill's Avatar
Send a message via MSN to nhlbill
I had 4.5" of lift at one point (2" body, and 2.5" OME suspension) and 33 12.50 15's rubbed pretty good when wheeling. The pinch weld mod helped, as did some trimming on the front part of the rear flares. Most guys will tell you you can't run 33's on 3" of lift. It has been done, but mostly "mall runners".
I now have 9" of lift to run 35's without rubbing, so take that for what it's worth.
I have 3.75" backspacing and 15" wheels FYI
Bill
I got a Jeep....and a login and password to your forum.....
nhlbill is offline
post #5 of 24 (permalink) Old 03-24-2005, 02:46 PM Thread Starter
thanks guys. think i'll just go with 285/75/16s
post #6 of 24 (permalink) Old 03-24-2005, 02:46 PM
TacoCrazy's Avatar
I run a 33x10.50 on a 7" stock steelie, 3" or less lift with no rubbing issues..Backspacing and wheel width are critical to eliminate rubbing issues..
If you want to know if a trail is too hard - GO WHEEL IT! If your truck breaks, or you die - it was too hard.
PICTURES!!
MORE PICS!!
Photobucket password is: Tacoma
*'97 Std cab V-6
*Aussie locked front
*E-locked rear 4.88's
*35" Baja MTZs
*Warn M8000S
*Lots of armor..
TacoCrazy is offline
post #7 of 24 (permalink) Old 03-24-2005, 03:02 PM
Retired
AK98Taco's Avatar
3" Cornfed lift and 33x12.5s on 15x10s. I'm doing it quite successfully. The front rubs when turning and compressing the suspension. The rear rubs on the bedside. My pinch weld is obliterated, so the only way to go from here is to tub the firewall. The rear can be trimmed a lot.
The stability is awesome, as is the look.
Here are some recent action pictures:
http://img.villagephotos.com/p/2003-...7/P1010024.jpg
http://img.villagephotos.com/p/2003-...7/P1010025.jpg
Here are some great shots of the stance and the rear flex:
http://img.villagephotos.com/p/2003-.../bumpsmall.jpg
http://img.villagephotos.com/p/2003-...flex2small.jpg
-Thomas
AK98Taco is offline
post #8 of 24 (permalink) Old 03-24-2005, 03:02 PM
jimmytbud7's Avatar
i had 33's on with a 3 inch lift on a 15x10 rim, and they rubbed like a mfer
2005 TRD V6 black
stock
old truck:
http://home.comcast.net/~jimthomson/SIG.jpg
jimmytbud7 is offline
post #9 of 24 (permalink) Old 03-24-2005, 03:32 PM
ocdp2000's Avatar
Send a message via AIM to ocdp2000
personally speaking i think 33s look too big with just 3", if you add a 2" body lift then the tires look a little more at home. if your going to just stick with your 3" and not lift anymore get the 32's, like a MT or something and it fills in the wheel well nicely. i have a 2002 with 3" off lift with 32's and i love it. good luck. its a big investment so make sure you get the right tire. also some tire places will test fit tires for you and mount one of them and you can get a better look at them. always ask because the worst thing they can do is say no.
"Don't assume that everyone on this board enjoys dropping their truck off a bunch of rocks..."
2002 PreRunner
ocdp2000 is offline
post #10 of 24 (permalink) Old 03-24-2005, 03:36 PM
TacoCrazy's Avatar
Good looking truck by the way..and 33's can look too "big" on a 10" wheel for instance..Check out my pics of a 33x10.50 on a 7" wheel with about 3"..Not too big at all in my opinion..
PICTURES!!
MORE PICS!!
*'97 Std cab V-6
*35" Baja MTZs
*Warn M8000S
*Lots of armor..
post #11 of 24 (permalink) Old 03-24-2005, 04:33 PM Thread Starter
I'm really lookin' for a cheap lift so I can fit bigger tires and have stance that looks better and a wider than stock without goin' to high
post #12 of 24 (permalink) Old 03-24-2005, 05:26 PM
Chicks Dig Body Damage
jbstrd's Avatar
I am running that exact setup on my 98 (look at my signature). I took off the front mud flaps and pounded the pinch weld. I get minimal rubbing in the front when I turn slightly and compress the suspension. In the rear I only rub on the fender flare bolts at full flex. I am happy with running the larger tire. But, it is solely up to you. If you cannot stand rubbing at all, then you would probably be better off with 32x11.5's.
98 TRD Limited
Donahoe Coilovers/ OME Dakar's w/D6XL AAL
33" BFG KM2's
ARB Bullbar/Warn 9.5XP/Safari Snorkel
HID Conversion Headlights
Custom Sliders/ All Pro rear bumper
Budbuilt Skids/Bellypan
jbstrd is offline
post #13 of 24 (permalink) Old 03-24-2005, 06:04 PM
Truckless
Chadman's Avatar
I had 33x10.5-15 bfg muds on my 01' D-0cab with 3" and had to trim alot (front pinchweld, rear flares) but it's not noticable to the naked eye.
Chadman is offline
post #14 of 24 (permalink) Old 03-24-2005, 07:15 PM
TacoCrazy's Avatar
That's what's funny about different models...My 97' has the same tire with just under 3" and it doesn't even come real close to the pinch weld..It's been wheeled hard and flexed to the max in just about every situation and has never even touched it..Ooh well, go figure..Oh yeah, and on the rear, it'll tuck all the way and not touch a thing..Probably has alot to due with the stock 7" steelies..
PICTURES!!
MORE PICS!!
*'97 Std cab V-6
*35" Baja MTZs
*Warn M8000S
*Lots of armor..
post #15 of 24 (permalink) Old 03-24-2005, 08:32 PM
TACO 4X4's Avatar
Backspacing will make a big difference...the less you have the more likely to rub on the fenders 3.5"s...have to keep it at least 4" or you'll start hitting the upper arm. Mine are 4"'s....running the 285/75/16. I would have to do a lot more trimming running 12.5 wide. Also note with 33's you will feel a power loss though not horrible.
1987 - FJ60, 202k, OME lift, 32's and that it so far.
TACO 4X4 is offline
post #16 of 24 (permalink) Old 03-24-2005, 09:22 PM
33x10.50/15s or 285/16s, yes but you'll still rub
post #17 of 24 (permalink) Old 03-25-2005, 02:56 PM
spill_02's Avatar
i run about 3.5 inches of lift, 2 in bl and 1.5 suspension, i have a 15x10 in wheel not sure about the backspacing but its on a 33 12.5 15 mt baja claw i only rub in one place and thats due to a sheared schrader valve on the shock up front, i would say you could do it plus the 33's will look awesome with a 10 inch wheel, just do the pinch weld and possibley trim a little off the valance, you should be fine, but as stated above the backspacing on your wheel will definatly play a role.
spill_02 is offline
post #18 of 24 (permalink) Old 03-26-2005, 07:45 AM
jon_7248's Avatar
When you say 33s, you most likely want 33x1250s right? Because you can get a pizza cutter tire (which most dont like) under there and not have problems. Depends on rim width and backspacing. I have seen people rub with a 32x1150 with 3inch lift, but they had 15x10 rim and about 3.75 backspacing which rubbed the body nicely. I have also seen 33x1050 on 6" rim with stock backspacing and only slightly hit the pinch weld at full flex.
Besides the backspacing and rim/tire width. You also need to keep in mind the suspension. It maybe 3 or more inches.... but how well does it flex? If it flexes like an old cadillac, then you will have rubbing. If it's stiff.... less of a chance.
There are many of variables that you have to account for when asking about other people's experiances. You almost have to find exactly what you want, and see who has that and what they run into.
My 2 cents = 1 peso
-Jon
jon_7248 is offline
post #19 of 24 (permalink) Old 03-26-2005, 08:29 AM
do you think the will rub on a 15x8 rim
undefinederic
ERIC TACOMA is offline
post #20 of 24 (permalink) Old 03-26-2005, 09:09 AM
jon_7248's Avatar
What size tire? the 33x1050 would least likely to have problems than a 1250. It also depend on the backspacing again. And if you have a stock bumper or an ARB with winch or what not.
My 2 cents = 1 peso
-Jon
jon_7248 is offline
post #21 of 24 (permalink) Old 03-26-2005, 01:03 PM
MidwestTaco95's Avatar
Send a message via AIM to MidwestTaco95 Send a message via Yahoo to MidwestTaco95
NOPE!!! i have 15x8 with 3 5/8 in back spacing with 33x12.50's and they havent rubbed yet, and my truck is no mall queen what so ever. in my opinion i think that 33's look SWEET with 3in of lift. Just look at taco crazy's rig, its sweet as all get out.
Only my rear rubbs sometimes, just a little..LOL... http://community.webshots.com/photo/...93401055gVKyJf
If you ever sell you Toyota for something that is not a Toyota, then my friend, you are an idiot.
95.5 Ext. Cab V-6 3.4L 3" Donahoe Racing Coil overs, Deaver rear leaf pack. 33x12.50 Mickey T's Baja Radial MTX's, Black Street Locks, K&N Intake.
My truck
MidwestTaco95 is offline
post #22 of 24 (permalink) Old 03-26-2005, 04:22 PM
ocdp2000's Avatar
its also a good idea when you get your alignment done to have them move your front wheels foward and this will help you clear the pinch weld mod area.
2002 PreRunner
ocdp2000 is offline
post #23 of 24 (permalink) Old 03-27-2005, 12:53 PM
StemsCornfedTaco's Avatar
I have 4.5" of lift (2.5" Cornfed Spacers, 2" PA Body Lift) and I ran 33 x 12.50 Thornbirds on a 15x10 with 3.75 backspacing. The tires rubbed on my pinch weld and front bumper but most of that was b/c of the tire width (almost 14 inches wide) I sold the Thorns so i dont have to worry about rubbing.
~Robby
Too Much Peer Pressure...
MySpace!
StemsCornfedTaco is offline
post #24 of 24 (permalink) Old 03-27-2005, 01:08 PM
Isnt the Tacoma on the Bushwacker Fender Flares Website a Dub Cab with 3" Lift and 33's????
www.bushwacker.com
~Robby
MySpace!
