Brake Light On? - TTORA Forum
post #1 of 10 (permalink) Old 04-07-2005, 08:35 PM Thread Starter
Question Brake Light On?
My brake light is on almost all the time. Sometimes it goes out for a minute or two but them comes bake on. I adjusted the parking brake and that did not help. Any ideas? Do our trucks have dummy light that tells you you need new brakes?
Thanks.
99 TRD V6 Auto
Owyhee is offline
post #2 of 10 (permalink) Old 04-07-2005, 08:39 PM
Have you checked the fluid level? if not you might try that.
L8R
rojo22 is offline
post #3 of 10 (permalink) Old 04-07-2005, 08:48 PM
Sam Damage's Avatar
Thanks.
don't know if this will help you at all but when i was test driving my tacoma it's brake light would stay even though the parking brake was released ... the dealership fixed it as one of my conditions to buy it ... the mentioned it something about a spring needing to be tightened ... the problem has happened a few more times since then but i find that if i just squeeze the trigger and give it a turn and push in slightly it will turn off ... best of luck fixing your problem
2001 Tacoma 3RZ standard cab SR5 manual
power to the people!
Sam Damage is offline
post #4 of 10 (permalink) Old 04-07-2005, 09:00 PM
mudferret's Avatar
Sounds like your dealer was referring to the parking brake return spring, which is attached to a linkage, just aft of the cab. In all likely hood they just adjusted the tension on the parking brake cable.
Nice and easy to do, and is also a brake light culprit, along with low fluid level.
Originally Posted by Some chick from American Dad
It's true what they say about geologists, they're the coolest, sexiest men alive.
Originally Posted by mudferret
Suck my penal system.
[photos]
mudferret is offline
post #5 of 10 (permalink) Old 04-07-2005, 09:22 PM
Sam Damage's Avatar
thanks for letting me know what they did ... my dealer was dumb and a stubborn prick. getting the truck from them was like pulling teeth ... not a good first dealership experience, now i fully understand the stigma that goes with being a used car salesman.
post #6 of 10 (permalink) Old 04-07-2005, 09:24 PM
mudferret's Avatar
Even if they had to replace the spring, it's not really a big deal. Go peak under your truck and you'll understand.
[photos]
post #7 of 10 (permalink) Old 04-07-2005, 10:55 PM
Deal Master
grillmasterp's Avatar
Thanks.
http://www.tacomaterritory.com/forum...ng+brake+light
http://www.tacomaterritory.com/forum...3&postcount=15
http://www.tacomaterritory.com/forum...18&postcount=1
grillmasterp is offline
post #8 of 10 (permalink) Old 04-10-2005, 11:20 PM
Like someone else said, check the fluid level. Mine did the same thing and I just needed to add a little bit of fluid. The sensor is pretty sensitive.
SOLD 00 tacoma single cab ~ 2.7L~5-spd~ 31's
OME 881's/custom AAL and Bilsteins all around
Deckplate Mod (sucks)
Cobra CB
Custom Front/Rear bumpers
77 Bronco
*Cant find a good body shop to weld in the new panels...any help would be appreciated!
mudwisr2 is offline
post #9 of 10 (permalink) Old 04-11-2005, 10:22 PM
NorCal Chapter Pres
NorcalPR's Avatar
When I test drove a lifted tacoma, the light wouldnt go off unless I pushed in the handle in all the way.
W6FTW
NorcalPR is offline
post #10 of 10 (permalink) Old 04-11-2005, 10:31 PM
mudferret's Avatar
Sounds like a case of ALTWPAOTPBL.
[photos]
