vibrations - TTORA Forum
post #1 of 2 (permalink) Old 04-11-2005, 06:32 AM Thread Starter
vibrations
i used the search function already and didn't come up with what i am looking for. what i want to know is will the vibration hurt or do anything to the truck in the long run. i just lifted my truck up 3" with the cornfed spacer all is good what i have an assuming is the vibration but what it sounds like is like tires rubbing or tires riding on the edges at between 15 to 40 mph, not to bad but i notice it but i can live wih it if it won't hurt the the truck. still have stock tires and no alignment down yet. the wheel is pretty straight but it does want to pull to the left a little and that is where i feel the vibration or noise coming from.
tumor is offline
post #2 of 2 (permalink) Old 04-11-2005, 08:36 AM
Get your alignment done, then see what vibrations you have left.
I did a search: vibrations /
http://www.tacomaterritory.com/forum...earchid=101054
Here's what's probably going on, you need to lower your carrier beam. I have about 1.5-2 inch worth of washers to drop down the carrier beam. The pics that are there show about 3 on each side. I think I really went away with 6-7 washers on each side.
http://www.tacomaterritory.com/forum...ght=vibrations
(I know this the newb section, but seriously, trying some searching on the main forum)
Hope this helps.
soundstudio315 is offline
Gear in this thread - Powered by O'Reilly Auto Parts
