Swaybar, removing pemanently - TTORA Forum
post #1 of 4 (permalink) Old 04-16-2005, 09:03 AM Thread Starter
99TanTaco's Avatar
I've searched and have found at least 3 people have permanently removed their swaybars, I broke my link in the process of deciding whether or not disconnects are worth it (see my other thread http://www.tacomaterritory.com/forum...ead.php?t=8052 ) and after driving it without the sway bar I don't think I need it. How many people have done this? also I read in one of the other threads I found that this could cause uneven tire wear, any truth to that? Any other side effects than the obvious (body roll) ?
Side Note: I created this thread because my other thread was dealing with disconnects
99TanTaco is offline
post #2 of 4 (permalink) Old 04-16-2005, 09:06 AM
Mike's Avatar
I haven't had a sway bar for years. Just make sure you know what your truck is going to do when you hang a tight corner or make a panic move to avoid trouble.
Later,
....Mike
Mike is offline
post #3 of 4 (permalink) Old 04-16-2005, 09:11 AM
ELI
ELI's Avatar
Send a message via AIM to ELI
I've had mine off for 5 years now. I've had no problem so far. You will feel a difference on turns and in winds. Like Mike said, be aware of your turns...especially if you're lifted.
ELI
[list]
1995.5 Toyota Tacoma 4x4 Reg. Cab
- 6" of lift
- 15x8 Black Rockcrawlers
- 33x12.50 BFG M/T KMs
- Lockright Rear
- 4.88's
- SAS shopping started...again!
2006 Tacoma Access Cab PreRunner
-Daily Driver
1985 Toyota Pick-Up 4x4
- Stock...for now.
ELI is offline
post #4 of 4 (permalink) Old 04-16-2005, 11:07 AM
Not really here...
synovus's Avatar
I've had mine off for about a year now with no problems. No uneven tire wear that I've noticed. If uneven wear is a concern for you, then make it a point to rotate your tires more often. Most importantly, like the others have said, be sure to take note of how your truck handles in tight and/or quick turns. Although it may not feel drastically different to you without the sway bar, it can become VERY noticeable come time to avoid an accident.
synovus is offline
