Coilover Corrosion - TTORA Forum
post #1 of 12 (permalink) Old 04-25-2005, 01:08 PM Thread Starter
Coilover Corrosion
Do all the major coilovers available (SAWs, Camberg, Donahoe, Kings, etc.) have the same problem with corrosion when exposed to the winter elements? Or is one more resistant? I know donahoe is developing a plated product, but without a expected release date in sight, I'm wondering if there are alternatives.
Thanks.
2002 Ext Cab 3.4L V6.
Donahoe Coilovers, Deaver AAL, and 5125s.
masst1 is offline
post #2 of 12 (permalink) Old 04-25-2005, 01:14 PM
x0ffr0adtac0x's Avatar
saw new coilovers are nickle plated but the older ones can corrode over time, and think they are now available
x0ffr0adtac0x is offline
post #3 of 12 (permalink) Old 04-25-2005, 03:52 PM
Donahoe's Avatar
Nickle plating is not any better.. Its just looks cool comming out of the box.
We are doing lots of testing on the Extream Weather plating right now and should have some answers for your guys in the next week or so.
hope that helps
2004 Score Champs (oh nothing, Just in a Tacoma!!)
www.donahoeracing.com
Best suspension on the market...
Donahoe is offline
post #4 of 12 (permalink) Old 04-25-2005, 04:19 PM
Stinks like fish
Bryanccfshr's Avatar
I am watching with some interest.
Bryanccfshr is offline
post #5 of 12 (permalink) Old 04-25-2005, 05:30 PM Thread Starter
Thanks for the reply.
If the extreme plated donahoes are available soon that's what I'll get, but if not, are the standard Donahoes any more or less resistant than the other available products? Does anyone from the Snow belt have experience they are willing to share about the various products.
Thanks.
masst1 is offline
post #6 of 12 (permalink) Old 04-25-2005, 09:27 PM
newbie
wisctaco04's Avatar
Thanks.
My adjusting collars on the Hoes are seized after one winter. The shaft is still shiny new though. I should have applied anti-seize instead of synthetic grease. I will be taking them off soon to free up and coat properly. There is just not enough room to with the coils on the truck to use the spanner wrench or I would have free'd them already. If you take the rig to the wash after a good road salting you should have no ill effects.
http://offroadworld.tenmagazines.com...ry.asp?id=4820
SC'd/URD 2.2"pulley H20 cooled/3.75"DR's/2"Alcans/32"M/T's/DR rear shocks/ARB Bull Bar/Demello wrap rear/Can-Back/10"Sub/CorbeauVX2000's
Hi-Lift mounts for sale $30
wisctaco04 is offline
post #7 of 12 (permalink) Old 04-25-2005, 11:11 PM
WD40. Spray your stuff oftenif the road is salted, nasty. It makes cleaning easier after a mud run, too.
rojodiablo is offline
post #8 of 12 (permalink) Old 04-26-2005, 08:24 AM
newbie
wisctaco04's Avatar
No thanks. That shiat collects more dust that by great great dead granmothers puss... I have damaged seals on cycles before from the dust acting like fine grit sandpaper. I think I'll pass and just keep going the frequent winter car wash route. If you have any suggestions how to keep my window from freezing shut I may use that tip.
post #9 of 12 (permalink) Old 04-26-2005, 09:14 AM
Triple BB's Avatar
Nickle plating does corrode in the form of surface rust. My new SAWS are easily cleaned. The first generation SAWS I had corroded ugly with our winter conditions. I also have a set of Bilsteins that are new in the box. And I helped a friend install some Hoes awhile back. Out of all of them, only the Bil's specifically instructed to coat the threads with anti-seize. My SAWS are gooped with the stuff. On my first generation SAWS, I was going to mark where the collars sat, then take them apart and have the cans up to that mark, Line-x'd. A local dealer was going to do it for $25. Figured it was better than looking at those heinous corroded tubes. Luckily they suffered a manufacturer defect and SAW took them back and I was able to get the new version from a supplier.
Triple BB is offline
post #10 of 12 (permalink) Old 05-10-2005, 09:06 AM Thread Starter
Thank you for the information regarding the antiseize. Are there any other opinions/experience out there regarding this issue?
masst1 is offline
post #11 of 12 (permalink) Old 05-27-2005, 10:37 AM Thread Starter
Is there any additional information on a release date for the plated donahoes?
masst1 is offline
post #12 of 12 (permalink) Old 05-27-2005, 11:04 PM
Triple BB's Avatar
I was checking out my SAW's the other day and I did see some surface rust. A little rust jelly and they're shining again.
Kreg if you're reading this, you need to make your cans out of stainless or the same metal that Bilstein uses on their shocks. They use a lot of nasty chemicals on our winter streets. I was checking out my Bilstein 5100 rear shocks and other than being dull from lots of surface road grime, they show no signs of rust. With a little polishing, they still look nice.
