Body Squeaks - TTORA Forum
post #1 of 6 (permalink) Old 04-26-2005, 11:51 PM Thread Starter
Body Squeaks
My stock 99 Tacoma 4 x 4 regular cab with 51,000 miles has an annoying squeak that appears to be coming from under the bed behind the passengers seat. Sounds like 3 canaries chirping......and only occurs under slight deceleration at speeds between 20 and 45. I would appreciate any imput that anyone might have. Thanks! Steve
StevenK is offline
post #2 of 6 (permalink) Old 04-27-2005, 01:12 AM
spill_02's Avatar
my truck would do the exact same thing and still does once in a while, i have the slightest idea what it could be though so guess im in the same boat
spill_02 is offline
post #3 of 6 (permalink) Old 04-27-2005, 04:31 AM
Average member
Fishbone's Avatar
Maybe a bad u-joint? Grease all your u-joints, see if it goes away.
PA President
D44 3 Link W/coilovers
Dual cases Triple shifters
37" MTR's 4.88's Locked F&R
Fishbone is offline
post #4 of 6 (permalink) Old 04-27-2005, 09:08 AM
The Road Less Traveled
Lagarre's Avatar
Like Fishbone said, grease all the U-joints also you may want to spray a little WD40 near the ends of the leafs where they rub each other. You may need to jack the truck up a little so you can spray in between the leafs.
2000, 4x4, 2.7, Kennesaw bumper, Warn 9000i winch, manual hubs, TRD rear, 265x75x16 BFG AT's.
Gary
Lagarre is offline
post #5 of 6 (permalink) Old 10-28-2005, 09:39 AM
I know this post was a long time ago, but I recently encountered the same prob. Mine only squeaks when you let of the gas and coast, as soon I hit the gas again, it goes away. U-joints probaly?
2001 Tacoma TRD 4x4 Xtracab w/Stepside
2006 Tacoma TRD 4x4 Doublecab in near future
BamaTRD is offline
post #6 of 6 (permalink) Old 10-28-2005, 09:47 AM
River Rat
hawaiianbro's Avatar
is this when you put it in neutral and coast? or you deaccelerating with the clutch engaged?
it could also be a bad center support carrier bearing.....i just replaced mine a month ago....squeaking never came back. and it only took about 30 mins to install.
hawaiianbro is offline
