how to tell difference between 22r 22re - TTORA Forum
post #1 of 26 (permalink) Old 03-10-2008, 11:10 PM Thread Starter
Nick998's Avatar
I have a 85 toyota that i believe is a 22re motor but it is carbed... The valve cover says 22re but people say if its 22re it has to be F.I. Is there a way to tell the difference such as different oil filters? Vin numbers on block?
1982 Toyota Pick-up, Bobbed bed, IFS rear axle housing, Weber and Header, Downey Shackles, 2in body lift, 4in springs up front 2in in rear, On 35's
1990 Honda CRX B16A swap, AEM Hybrid CAI, Holley Header, Full Skunk2 exhaust.
Nick998 is offline
post #2 of 26 (permalink) Old 03-11-2008, 12:14 AM
bray's Avatar
22r=carb-----22re=fuel rail.
Get a propane kit and you'll have better than both!
Originally Posted by miguelitro
fat chicks and scooters. they may be fun to ride but you dont want your buddies catching you on one.
bray is offline
post #3 of 26 (permalink) Old 03-11-2008, 07:35 AM
Moderator
dougtrd's Avatar
Somebody probly through a 22re valve cover on there at some point...I believe they are interchangeable...like bray said, 22r=carb, 22re=EFI
'11 Tacoma
dougtrd is offline
post #4 of 26 (permalink) Old 03-11-2008, 11:38 AM
Smoked Out!
DCabTaco's Avatar
or a sticker. Marlin sells them for 3 bucks.
DCabTaco is offline
post #5 of 26 (permalink) Old 03-11-2008, 03:42 PM Thread Starter
Nick998's Avatar
well is there a difference in oil filters? cause i think a 22re has a smaller style oil filter and 22r has a bigger oil filter can anyone verify this?
Nick998 is offline
post #6 of 26 (permalink) Old 03-11-2008, 04:26 PM
Rock Taco's Avatar
Look to be the same
http://www.power-21.com/honeywellpow....aspx?b=F&vt=1
Originally Posted by Rebuilt98
That's it I'm going to rip off my nuts so I can run faster, jump higher, and generally be way cooler.
99 Tacoma extra cab (currently under construction), 02 Tacoma 4-door
Rock Taco is offline
post #7 of 26 (permalink) Old 03-11-2008, 09:05 PM
Smells like tacos in here
Marc M's Avatar
Send a message via AIM to Marc M Send a message via Yahoo to Marc M
I believe they are very different...
Marc M
'06 Tacoma DUB-cab, 4X4, V6, 6-spd, SR5 / TRD Off Road
'90 4Runner SR5 5-Spd
'86 Shortbed 4X4 5-Spd,SAS'd ASAP
'82 Supra 5-Spd
Take your automatic and "Stick" it........
My Web Album in Progress
Marc M is offline
post #8 of 26 (permalink) Old 03-12-2008, 10:17 AM
82yotaboy's Avatar
The oil filters could be the same, it depends on the year but if there is a carb it is a 22r. it is not possible and rediculous to put a carb on a fuel injected model.
1982 4x4 toyota pickup, cb, 33 inch tires, 22r-e!
82yotaboy is offline
post #9 of 26 (permalink) Old 03-12-2008, 11:25 AM
Smoked Out!
DCabTaco's Avatar
Originally Posted by 82yotaboy View Post
it is not possible ... to put a carb on a fuel injected model.
Oh I wouldn't say that
... rediculous...
That, I would say.
DCabTaco is offline
post #10 of 26 (permalink) Old 03-12-2008, 11:40 AM
Smoked Out!
DCabTaco's Avatar
Marc M
I donít see the sarcastic smilie( ), but Iím pretty sure you were being sarcastic.
For 22r series(i.e. 22r, 22re, 22ret)
83-84 blocks are shorter than 85-95 blocks.
83-84 heads do not mate to FI intakes
Most 85-95 heads mate to both FI and carb intakes
FI and carb cams are different
All 22r and 22re oil filters are the same
22ret oil filters differ
That is to the best of my knowledge the major differences in the engine department, and yes I have an 83 truck that has an 85+ engine with carb and an 85 4runner with a 22re, so I have compared the two quite a bit.
DCabTaco is offline
post #11 of 26 (permalink) Old 03-12-2008, 03:50 PM Thread Starter
Nick998's Avatar
so how do i ultimately tell? I believe it is a 22r because my info tag in my engine bay says 22r and the computer says 22r on it also.
Nick998 is offline
post #12 of 26 (permalink) Old 03-12-2008, 04:02 PM
Smoked Out!
DCabTaco's Avatar
Not really sure what you are asking. Everyone is saying the same thing:
22R = Carb
22RE = FI
22RET = Turbo
engine blocks vary only by what I mentioned on top,
So you have a 1985 22R motor because it is carburated. Which uses the same oil filter as a 22RE because 22R and 22RE motors use the same filter. What other question are you asking?
DCabTaco is offline
post #13 of 26 (permalink) Old 03-12-2008, 04:14 PM
Deal Master
grillmasterp's Avatar
Toyota has streamlined the same oil filter across the line-up for the
20r,22r , 3vz, 2rz, 3rz, 5vz engines-
OK so it has a carb, plate says 22r......If it walks like & duck & talks like a duck......
Pg 77 (1999 Owner's Manual)
(!) Brake System Warning Light
This light has the following functions:
-Parking Brake Reminder
-Low Brake Fluid level Warning
grillmasterp is offline
post #14 of 26 (permalink) Old 03-12-2008, 05:14 PM
BrotherGrim's Avatar
If it has a carb. on it. it is a 22r. If it has a throttle body on it ,it is a 22re. If it has a throttle body and a turbo on it, it is a 22ret. It is that simple. Don't know any other way to say it.
Proud member of CA4WDC for 12 years.
Member of UFWDA, BlueRibbon Coalition and the SEMA Action Network
89' Custom four door PU
NorCal4Wheelers
BrotherGrim is offline
post #15 of 26 (permalink) Old 03-12-2008, 05:27 PM
Rock Taco's Avatar
Let me see if I can clarify this for you.
22R
22RE
Notice the big difference of that round thing on the top of the motor in the first pic and the lack of said round thing in the second pic that is the easist way to tell. Hope this answers all of your questions. Sorry if one of these pics are yours and you don't want it posted here. Send me a pm if you want it removed.
post #16 of 26 (permalink) Old 03-12-2008, 05:39 PM
Smoked Out!
DCabTaco's Avatar
Oh, oh, I know this one, I know this one. Don't tell me.... um if it has a beak, it waddles, and it has a tag with "DUCK" printed on it,... I think its a Duck,... oh I give up, how can I tell for sure what it is?
DCabTaco is offline
post #17 of 26 (permalink) Old 03-12-2008, 06:21 PM Thread Starter
Nick998's Avatar
Okay Im not a fucking dumb ass... Btw mine must have the 22re valve cover hence my confusion cause my valve cover looks exactly like the one in the second picture. I know what a carb looks like.
here is a picture of my engine
Nick998 is offline
post #18 of 26 (permalink) Old 03-12-2008, 06:35 PM
Smoked Out!
DCabTaco's Avatar
Thats what must have happened. With vehicles this old, you never know what the previous owners have done. I kept ordering stuff for an 83 22R motor until I realized it has a newer 85+ 22R motor in it. I would have never what it was had I not needed a new timing chain. Now I know what motor to order parts for.
DCabTaco is offline
post #19 of 26 (permalink) Old 03-12-2008, 08:25 PM
Rock Taco's Avatar
Not saying you are. But why the question in the first post I quoted? The valve cover doesn't make a bit of difference. My 86 that I used to have the same valve cover as yours but said 22R on it. Your valve cover may have been changed or some one put a different sticker on it as was said before. You can buy them here http://www.marlincrawler.com/htm/stickers.htm
post #20 of 26 (permalink) Old 03-12-2008, 11:37 PM Thread Starter
Nick998's Avatar
Okay but you were still coming off as a smart ass
My 85 doesn't have the smog fittings on the manifold like that 84 did either.
Nick998 is offline
post #21 of 26 (permalink) Old 03-13-2008, 12:07 PM
Bear's Chauffeur
98taco4x's Avatar
Send a message via AIM to 98taco4x
You have a 22r with what looks like a 22re valve cover, thus why you have had so much confusion
98 Tacoma 4wd xcab Sr5 2.7 auto, 265/75/R16 Kelly Safari TSR's, Mossyrock's Sliders, 881's and billy's, OME dakar leafs and shocks.
83 4wd pickup 22r some sort of lift, 5.29's, 36 tsl's, lockrite and spool, and a complete disregard for body damage alot more mods in the works
98taco4x is offline
post #22 of 26 (permalink) Old 03-14-2008, 07:54 AM
Moderator
dougtrd's Avatar
wow, its like rocket science...
'11 Tacoma
dougtrd is offline
post #23 of 26 (permalink) Old 03-15-2008, 11:37 PM
if your so smart carb = 22r fuel injected = 22re turbo=22ret its not rocket science you have to look at the intake not the exhaust
nick1860 is offline
post #24 of 26 (permalink) Old 03-16-2008, 01:55 AM
bray's Avatar
Man, I posted part of that and I wasn't thinking you were a dumbass at all. I was just giving out info to tell the difference. It does (after you posted pics) look like a 22re valve cover or just simply a stupid sticker. I wouldn't know the difference in those, so you see that I'm no expert. Why does these threads have to evolve to such flaming? It's kinda rediculous.
bray is offline
post #25 of 26 (permalink) Old 03-17-2008, 06:59 AM
Moderator
dougtrd's Avatar
Sorry dude, didnt mean to offend you, All I was saying is that the answer has been given, its obvious which motor this guy has, and even the explanation of why we say it is what it is...and yet the questions keep coming so we can re-state whats already in the thread
'11 Tacoma
dougtrd is offline
post #26 of 26 (permalink) Old 03-17-2008, 10:25 AM
*ROKTOY*'s Avatar
OK, drivers side of the block lower front pad will say either 22R or 22RE.
*ROKTOY* is offline
Difference in 22R? USAFMike Performance/Engine/Exhaust 11 09-16-2009 10:37 PM
What's the difference? frankwasabi Tires/Wheels 4 12-08-2006 01:27 AM
94 4x4 22RE and 85 4x4 22RE possibly for sale CHRINTHEDESTROYER Vehicles/Trailers 8 05-31-2006 11:08 PM
FTC and URD PCU...any difference? YoTRacer158 Performance/Engine/Exhaust 2 02-27-2006 09:40 PM
265/75/16 difference (looks) JustinT Tires/Wheels 5 02-07-2005 04:58 PM
