1GR-FE 4.0 V6 Swap into 1987 4Runner - Page 2 - TTORA Forum
post #31 of 198 (permalink) Old 02-03-2012, 07:32 AM
That Guide looks bad. you can use the sleeve. The Release bearing is just one that do not use the fork. Check out the Howe Throw out bearings. I take a pic later and post.
SilverLux is offline
post #32 of 198 (permalink) Old 02-03-2012, 02:52 PM Thread Starter
Stoffregen Motorsports's Avatar
I've used those hydraulic throwout bearings before. They are a bitch to keep bled properly. For some reason they build up air bubbles. If they exert too much pressure on the back of the crank, for too long a time, the oil gets wiped off the thrust bearing and you can destroy your crank.
Stoffregen Motorsports is offline
post #33 of 198 (permalink) Old 02-05-2012, 02:33 AM
Did you use Dot 3 fluid only?
post #34 of 198 (permalink) Old 02-05-2012, 09:28 AM Thread Starter
This isn't an isolated problem. A lot of people don't like those for that very reason.
post #35 of 198 (permalink) Old 02-06-2012, 02:40 PM
that is interesting
post #36 of 198 (permalink) Old 02-06-2012, 02:43 PM
Motor
how is the conversion doing?
post #37 of 198 (permalink) Old 02-06-2012, 03:14 PM Thread Starter
I actually won't even start the conversion until March. I have a couple jobs to complete first.
But I'm glad I started this thread early. You guys are helping me along with the thought process.
post #38 of 198 (permalink) Old 02-06-2012, 10:05 PM
once you figure out all the issues make a kit
Hannibal is offline
post #39 of 198 (permalink) Old 02-06-2012, 10:35 PM
hmm, Matt and 'kit' don't quite go together
post #40 of 198 (permalink) Old 02-06-2012, 10:44 PM Thread Starter
I know, huh? I've been thinking about that lately.
post #41 of 198 (permalink) Old 02-18-2012, 04:13 PM
lrgrnr's Avatar
lrgrnr is offline
post #42 of 198 (permalink) Old 02-18-2012, 06:36 PM
Originally Posted by lrgrnr View Post
dang, that sure doesn't leave much room for oil Get tippy and the pump would be sucking air.
post #43 of 198 (permalink) Old 03-25-2012, 06:40 PM Thread Starter
So I finally started the project. The first thing I needed to do was take good baseline measurements, so I measured away with the stock motor (22RE) in place. With my rough numbers it looked like I wasn't going to be able to fit it under the hood. So I came up with a plan...
Pics to follow.
post #44 of 198 (permalink) Old 03-25-2012, 07:30 PM
Pics to follow.
swap front clips and make a Frankentruck?
post #45 of 198 (permalink) Old 03-26-2012, 09:47 PM Thread Starter
Nope. I did that on the last one...
I'm having Jim machine me a base for a new plenum. This is going to incorporate velocity stacks and enough material so I can finish it off with aluminum tubing welded together to make a plenum much like a Chevy TPI setup.
Like I said, pics to follow.
post #46 of 198 (permalink) Old 03-26-2012, 09:48 PM Thread Starter
I know other guys are doing this swap with a 3 inch body lift, but that's hardly possible in this case, because the customer just paid me to lower the truck so the last thing he's going to want is a body lift.
And I hate body lifts.
post #47 of 198 (permalink) Old 03-28-2012, 10:50 AM Thread Starter
One more thing I need to look into is the fly-by-wire throttle. I heard somewhere that guys are converting to a cable controlled throttle body from a 1UZ, but I don't know any more than that. Any info would help.
post #48 of 198 (permalink) Old 03-30-2012, 12:25 PM
wrmathis's Avatar
Send a message via Yahoo to wrmathis
a few guys have blown motors drifting there xrunners cuz of this pan. a member of on XRU made a spacer for the pan to get a little more oil in there to not have this happen
Icon Coilovers, OME Dakar Leaf springs w/ AAL, ICON Tubular UCA, All-Pro Front Plate Bumper, CBI Rear bumper, ATO Skid Plates, ARB Front Air Locker, Inchworm 4.7 Crawl box, FJ Transfer case w/ Twin Sticks, Gen 1 TRD CAI, UCON EMS, TRD Supercharger, Doug Thorley Long Tubes, URD Short Shifter w/ Coupes shifter
wrmathis is offline
post #49 of 198 (permalink) Old 04-01-2012, 10:32 AM
I just got laid... off.
wslytoy's Avatar
As much as it may pain you... making a custom oil pan might be the best way to go. I'm definitely interested in seeing how this turns out.
New(to me):
2006 Sport Edition 4WD 4Runner
2.5" Bilstein 5100 in front
1.5" spacer out back
265/75R17 Mickey Thompson ATZ's
Eagle Series 140 in 17x8
OLD:
05' TRD 4x4
96' Tacoma 2.7 Ext Cab 5spd w/ a mod or 2
85' 4Runner Build Up Thread
wslytoy is offline
post #50 of 198 (permalink) Old 04-16-2012, 12:28 PM Thread Starter
Well I modified the stock pan. We lost about a quart, but I can gain that back with a remote cooler, or, if we decide to, we can put a kickout in the driver's side of the pan.
post #51 of 198 (permalink) Old 04-16-2012, 12:45 PM Thread Starter
Here are some new pics.
Comparison of the stock 22RE and the 1GR-FE
Engine position, oil filter barely clears
Length of stock trans and dual cases
Length of 6 speed with adapter and dual cases
Pics of new trans and mock up trans
post #52 of 198 (permalink) Old 04-16-2012, 12:50 PM Thread Starter
The new motor was about 3 inches shorter than the 22RE and the 6 speed is about 2.5 inches longer than the stock trans, but with the adapter the motor was able to sit perfectly in the engine bay, and the t-cases were able to remain in their stock location, so no drive shaft mods or new holes in the floor were needed.
Here's some pics of the frame rails and new motor mounts
Cut these off
Cleaned up the frame and made some frame plates
And new motor mounts
post #53 of 198 (permalink) Old 04-16-2012, 12:54 PM Thread Starter
I had to cut the small pieces off the heads to clear the firewall
Then I set the motor in place, and this is what I found
So it was time to modify the pan...
post #54 of 198 (permalink) Old 04-16-2012, 12:59 PM Thread Starter
Modifying the pan took a bit of work. I first had to figure out what I was going to cut off. Some of the oil pan bolts are inside the pan, so I had to figure out if they were going to remain there or if I would put them on the outside.
I decided it would be better to keep them inside the pan, because there is a drain back hole that would also have to be modified to allow it to function. And with the new aluminum welded up on the outside of the bolts, there would be a bit more oil left in the pan. So I started cutting...
And machining
post #55 of 198 (permalink) Old 04-16-2012, 01:02 PM Thread Starter
More later...
post #56 of 198 (permalink) Old 04-16-2012, 02:30 PM
TaWComA26's Avatar
This is so sick.
02 2.7 D Cab aka "Stuck Machine"
32's, lifted
00 R6 "Blue Devil" for sale
Faster than your R1
TaWComA26 is offline
post #57 of 198 (permalink) Old 04-16-2012, 05:01 PM
please tell me that tcase mount is going away and some sort of new xmember with dual OE mounts are replacing it.
As usual...awesome work.
post #58 of 198 (permalink) Old 04-16-2012, 05:52 PM Thread Starter
Thanks Chris.
Yeah, I don't like the amount of leverage that puts on the trans assembly. Having the crossmember all the way in the back is ok on a stock W56 or whatever, but when you throw an adapter into the mix, and a 5/8" thick one at that...I am concerned.
I want to do like I did on the blue '06 DC, and have two x-members; one on the t-case and one on the trans, making t-case removal super easy and alleviating the stress in the middle.
post #59 of 198 (permalink) Old 04-16-2012, 08:58 PM
Thanks Chris.
you've seen my setup, right? single xmember but with two OE mounts, tranny and crawler. (which I need to pull and check for a busted mount at the moment )
post #60 of 198 (permalink) Old 04-16-2012, 09:03 PM Thread Starter
Yes, I remember yours. Does it have a removable skid?
1987 4Runner dcestnik For Sale/WTB in CO 3 12-26-2010 01:05 PM
1987 4x4 Pickup Wheel Swap 87XtraCabTurbo Tires/Wheels 1 12-07-2008 05:12 PM
FS: 1987 22ret turbo motor/5spd Ecu swap FlatBlak Parts/Electronics/Wheels/Tires 0 02-21-2008 03:35 PM
1987 4Runner SR5 rmacFJ62 Vehicles/Trailers 4 12-21-2006 08:18 PM
