3.4 with 3.0 4wd trans - TTORA Forum
post #1 of 6 (permalink) Old 05-03-2012, 06:35 PM Thread Starter
kala's Avatar
yeah...did some searching..didnt find what I needed and got sidetracked.
1998 or 99 4Runner 3.4 4wd automatic. trans is going out and I have leads on a 5spd swap, except the person whos going to be primarily driving it can barely drive standard, let alone a dual friction one.
I have a set of 84 complete axles I was rebuilding for my hunting truck, but I can rebuild the sfa on there now and I can use the non-ifs rear. I have the brake lines, beam, cross over steering and shackles for another project that I can use.
I have a 1990 3.0 auto 4wd 4Runner I fixed up but only drove to work once and around the neighborhood.
My question is...is the 3.0 4wd auto trans a bolt up, plug n play swap into a 3.4 4wd 4Runner? If it is..I can use a toyota sfa instead of a waggy 44.
I'm Dirk Diggler and you're not.
kala is offline
post #2 of 6 (permalink) Old 05-03-2012, 07:06 PM
A guy with a pretty sick truggy by me did it. He said the 3.4 bolts right up to the 3.0 tranny. clutch from either one will work too he said there is only a cunt hair difference not enough to effect anything.
01 turd. all pro 3 inch, 33's, homemade everything, Aussie front locker. - dead and chopped the fuck up.
Another 01 turd, 3" puck/block lift,285s, grey wire/2lo mod. Some steel bolted on. Eventual 1 ton and links build
84 std cab 22r POS. home brewed sliders and bumpers, cage, walk through cab. 63's/RUF .elocker rear/Aussie front, 5.29s. 4.7. 35 km2s.
valon5150 is offline
post #3 of 6 (permalink) Old 05-03-2012, 08:33 PM Thread Starter
kala's Avatar
thanks but that's standard. I was seeing if the auto 3.0 trans bolts to a 3.4. My Uncle said no and me and my friends arent too sure. Only way i'd know is if we do it or if someone online has had the experience doing it.
kala is offline
post #4 of 6 (permalink) Old 05-03-2012, 08:59 PM
Richmondo's Avatar
Send a message via Yahoo to Richmondo Send a message via Skype™ to Richmondo
The A340H from the 3.0 will bolt up but it's going to be difficult figuring out a way control the transmission as the 3.4 ECM doesn't really get the job done all that well from what I've read
1980 LWB 5 Speed 20R
Jake
Richmondo is offline
post #5 of 6 (permalink) Old 05-03-2012, 10:56 PM
You have to use the bellhousing, Torque converter and the pump from the 3.4 a340f.
He is correct about getting things ECT, The A340H uses a manual control to divert the overdrive pressure to the transfercase (Which is why you cant use the OD in 4WD on the A340H), Which the 3.4 ECT does not know how to do.
It can be done still.
VooDooV is offline
post #6 of 6 (permalink) Old 05-16-2012, 11:32 PM
vasinvictor's Avatar
It's been done plenty of times. It bolts right up and is about ready to run right away. You'll need to use a T100 ECU to correctly control lockup. Try taking a look in the Yotatech 3.4 swap section. I don't know if I'm allowed to link to it.
Gah, noticed the post date- just like a noob to bump and old thread
1995 4Runner|5vze|a340f auto swap, 'bout done|How to: A/C for your 3.4 swap|G144 4.88s|loaded|work in progress
2001 Toyota Sequoia Limited|160k|4x4|235/85/16 Michelin X|Magnaflow|loaded|black|wife's
old rig 92 4Runner|3.0|auto|4.88s|33x12.5 BFG AT|no lift| no swaybars|HID flood lights| PICTURE ALBUM LINK
vasinvictor is offline
w56 trans DANNYCROSS352 Good Deals/Freebies 1 11-20-2010 06:10 PM
WTB w56 trans Toxic For Sale/WTB in GA 0 01-26-2010 02:56 PM
trans out xsvt Early Tacoma Tech 2 05-15-2007 04:14 PM
What Trans Do I Have roll-bar Bob Early Tacoma Tech 10 07-08-2005 12:57 PM
