Good towing service - TTORA Forum
post #1 of 9 (permalink) Old 04-09-2012, 02:13 PM Thread Starter
Don't get Wenzeled
nastynate's Avatar
Good towing service
I'm stuck in the galleria with fuel leaking out of my fuel rail. I need to get it back to Pearland.
Anyone have a good wrecker service you can recommend?
nastynate is offline
post #2 of 9 (permalink) Old 04-10-2012, 08:58 PM Thread Starter
Don't get Wenzeled
nastynate's Avatar
There's your problem right thar:
So when you go to put your injectors in the fuel rail, make sure to seat them properly so as not to cut the o-rings!
post #3 of 9 (permalink) Old 04-11-2012, 04:36 PM
BamZipPow's Avatar
What did you use to lube the O-rings when you installed the injectors?
BamZipPow is offline
post #4 of 9 (permalink) Old 04-12-2012, 09:45 AM Thread Starter
Don't get Wenzeled
nastynate's Avatar
I didn't.
I also didn't install the injectors into the fuel rail before installing the fuel rail. That was the critical mistake. It's a tight fit and I didn't think I could install it with the injectors in place.
post #5 of 9 (permalink) Old 04-12-2012, 01:03 PM
Playing with radiation
Ricks72's Avatar
Send a message via AIM to Ricks72
I didnt do it in the correct order, but I did lube mine with gas when I put mine in.... no leaks
-Brandon
Formula Toy #36
Ricks72 is offline
post #6 of 9 (permalink) Old 04-17-2012, 02:01 AM
fast frank's Avatar
Hint #1:
Use silicone spray.
just squirt it on the O-ring. It's slippery as fuck and will let you get the O-ring in the rail without even coming close to pinching them.
Don't worry about contamination or anything like that. I do it regularly and have never seen it cause any sort of problem whatsoever. I don't even pretend to try to keep it out of the inside of the injector.
Hint #2:
When an O-ring goes into it's hole properly, it's smooth and easy.
If it fights you even the tiniest little bit, it's not going in correctly.
Whatever you do, don't force it! That sudden release of tension you felt when it finally went in was the O-ring being sheared off between it's groove and the fuel rail.
Most injectors have locators that keep the wires pointed in a specific direction, but there's almost always a few degrees of rotation available within those locators. Use it! If the injector doesn't want to slip right in after being lubed with silicone, rotate the injector left and right as much as the locator will allow. It's not much rotation, but it's enough to get the O-ring to seat properly in it's grove so it will slip in like it's supposed to.
2017 Gen3 Tacoma TRD Off Road 4X4 Double Cab
Bone Stock and Loving Every Minute Of It.
fast frank is offline
post #7 of 9 (permalink) Old 04-17-2012, 08:35 AM Thread Starter
Don't get Wenzeled
nastynate's Avatar
Good tip Frank, thanks!
I used a bit of gasoline to lube them and then rotated them into place. No resistance was met at all.
post #8 of 9 (permalink) Old 04-17-2012, 01:27 PM
notyourmomslx450's Avatar
was that on the lx? why you making her look bad?
Jason
'99 Ford F-250 - Tow Rig slowly morphing into most excellent overlander
'98 4Runner Limited- SAWs, Camburg uppers, rear OME, Schrockworks front, 33" BFG A/T
"I got the jeep thing, now it burns when I pee!!"
notyourmomslx450 is offline
post #9 of 9 (permalink) Old 04-21-2012, 03:48 PM Thread Starter
Don't get Wenzeled
nastynate's Avatar
Yup. Had to clear the P401 by redoing the EGR system. She's back in business now. Running great, got the inspection done this morning.
Capistrano Toyota good service! rocket-scientist Maintenance & Parts 0 12-03-2011 08:53 PM
Good Friday....Good Beerday, Eastern Region Meeting !!! Jomentum Eastern Region 10 04-23-2011 06:52 PM
Good shop or dealer for service in Orlando, FL cabbage Off Topic 1 02-12-2011 08:11 AM
Good shocks for towing NickJ Newbie Tech 11 09-25-2008 02:18 AM
4x4 out of service norcaltaco33 Early Tacoma Tech 1 01-25-2008 02:13 PM
