Truck wont start - TTORA Forum
post #1 of 8 (permalink) Old 06-09-2011, 03:03 AM Thread Starter
Truck wont start
I have a 2002 toyota tacoma 3.4L V-6 S/C 7th inj. and all the shit to go with it. Alright my truck will turn over and even start for about 2 seconds but dies even when I try to give it gas. I can hear the fuel pump whining in the back ground. I need to get this fixed. Any clue guys. Ill take any advice. Thanks
-Clint
dennic is offline
post #2 of 8 (permalink) Old 06-09-2011, 05:47 AM
Hawaii's Damage Control
me_tu05's Avatar
Start simple, check the vacuum lines and make sure none are leaking. Kinda sounds like there is a huge air leak to me. If you can hear the fuel pump, you might want to find the test for it in the fsm and check its condition. a S/C can put a lot of wear on the stock components.
94 SC300 She boogies
86 4runner turbo diesel swap Now has a 1UZ
me_tu05 is offline
post #3 of 8 (permalink) Old 06-09-2011, 07:06 PM Thread Starter
Alright..update to my post. So my buddy towed me back home. It was only like a mile or so. But when we got to my house... the fucking truck started. So something is loose and the tow must have jared it back into place....now I have to find the fucking needle in a hay stack. Im going to start this weekend. I dont feel like I can trust my truck to start still. Thanks for the help and I will keep you guys posted. Thanks.
Clint
dennic is offline
post #4 of 8 (permalink) Old 06-10-2011, 12:31 AM
me_tu05's Avatar
Start with any modifications you have done to the engine and fuel system. Especially the wire harness.
me_tu05 is offline
post #5 of 8 (permalink) Old 06-10-2011, 01:27 AM Thread Starter
I replaced my clutch a while ago so the trany had to come out. Think it could be anything with that? Well also the whole S/C thing and all fuel mods. So I guess Ill be checking the whole truck from head to toe.
dennic is offline
post #6 of 8 (permalink) Old 06-10-2011, 03:25 PM
me_tu05's Avatar
Start with everything that was touched when you did the super charger.
me_tu05 is offline
post #7 of 8 (permalink) Old 06-12-2011, 12:01 AM Thread Starter
So I checked my engine light. I have a miss fire. Its not saying what cylinder just a 300 code. So Ill check the spark plugs maybe and can a bad coil pack cause this? If so how do I check if a coil is bad? Im also putting the stock intake back on as URD says the after market ones can cause you to run lean which I am.
dennic is offline
post #8 of 8 (permalink) Old 06-12-2011, 06:31 PM
Did you try switching the coil packs between cylinders yet?
Do you have the TRD 7th injector or the URD one? I would think that the URD one could tune for the CAI and eliminate the lean condition. Are getting a lean code or are you reading the AFR from a gauge. The code could be a vacuum leak. And that might contribute to a starting problem.
2000 Tacoma
3.4 TRD
ICON C/O
Marlin Clutch
Wainiha is offline
Truck wont start dennic Early Tacoma Tech 17 07-21-2011 05:51 PM
Truck Wont Start Burns85 Performance/Engine/Exhaust 4 09-08-2008 07:55 AM
truck wont start HillBilly_Young01 Tech 29 05-09-2008 01:00 PM
help truck wont start trent123 Early Tacoma Tech 3 04-17-2008 09:49 PM
Truck Wont Start Help! riseagainst88 Newbie Tech 11 04-08-2008 01:00 PM
