6 x 9's In Rear of Taco? - TTORA Forum
post #1 of 18 (permalink) Old 07-13-2005, 03:06 PM Thread Starter
River Rat
hawaiianbro's Avatar
Just wondering if anybody has tried fitting 6x9's in the stock rear speaker location. I have some nice Infinity Reference speakers just sitting here from my old civic.
Thanks,
Kaleo
hawaiianbro is offline
post #2 of 18 (permalink) Old 07-14-2005, 01:53 PM
Crime and Punishment
zosimov21's Avatar
If it's an extended cab they are already 6x9.(at least on my 04) You'd have to remount the factory clips to new speaker.
04 Taco
1980 1st Gen
Detroit Front / Welded rear
NC TTORA
http://www.ncttora.com/
zosimov21 is offline
post #3 of 18 (permalink) Old 07-14-2005, 01:59 PM
absolut taco's Avatar
I haven't looked at mine but I thought they were 6.5"...I have a sweet pair of old Boston Acoustic 6x9 that I want to use...
2004 Tacoma Extended Cab 4x4 TRD | 3.4 Liter V6 | 5-speed manual
absolut taco is offline
post #4 of 18 (permalink) Old 07-14-2005, 03:05 PM Thread Starter
River Rat
I'm pretty sure my 98 has 6.5"'s in the rear. I was just wondering if anyone has put 6 x 9's back there.
post #5 of 18 (permalink) Old 07-14-2005, 04:34 PM
Toyotajoe's Avatar
My '98 ECab has the 6.5" rears...
Toyotajoe is offline
post #6 of 18 (permalink) Old 07-14-2005, 04:47 PM
nilson's Avatar
Send a message via AIM to nilson Send a message via Yahoo to nilson
Later model Tacos come stock with 6x8s (I believe 01-04?) but I hear that with minor plastic trimming that 6x9s will go.
1996 4Runner Limited / 3.4L V6 / 4x4 / E-Locker / 204,000mi and counting
2005 Honda CRF250R
nilson is offline
post #7 of 18 (permalink) Old 07-14-2005, 11:22 PM
KempoStyle's Avatar
I have a 98 x-cab and put eclipse 6x9's in the back. I basically took the factory speaker guard and traced it onto a 3/8" piece of wood. Then cut it to fit where the factory speaker guard use to be and cut out the middle for the speaker mounting. This gave me enough backspacing to mount the speaker from the front. I then screwed the wood directly into the pannel and mounted the speaker on the wood. You can run a router around the edge to smooth it out.
Looks nice and no screws are visible.
KempoStyle is offline
post #8 of 18 (permalink) Old 07-15-2005, 12:48 AM Thread Starter
River Rat
Sounds great! Do you have any pics of the install or what it looks like now?
Much appreciated!
Kaleo
post #9 of 18 (permalink) Old 07-15-2005, 01:41 PM
KempoStyle's Avatar
Hawaiianbro, These are the picts I have of the install. Sorry bout the quality, but that's what I get with a camera phone.
I did the install about 3 years ago with some scrap wood from a shelving project. I know it doesn't match, but the idea is there. Been meaning to redo it and make it match.
I took some rough measurements and it looks like the dimensions are 9 1/2" x 9 1/2" for the total size. I used 3" screws to attach to the inside of the panel and attach the speaker to the wood. I recommend flat head.
There are 2 screws that hold the wood to the panel. I placed them top and bottom with a countersink so the speaker would hide the heads and mount flush.
I then attached the 6x9.
I have a slight overhang of the 6x9 on the sides. Nothing that affects the seal/performance of the speaker.
I've haven't had any problems with this install. Hope this helps
Name:	6x9 instal without speaker.jpg
ID:	1146   Click image for larger version
Name:	6x9 install.jpg
ID:	1147   Click image for larger version
Name:	6X9 Finish.jpg
post #10 of 18 (permalink) Old 07-15-2005, 01:51 PM
Send a message via AIM to TRD SyRuP Send a message via MSN to TRD SyRuP
you know youre a redneck when...
TRD SyRuP is offline
post #11 of 18 (permalink) Old 09-05-2005, 07:55 AM
sploosh's Avatar
It's got that nice wood grain accent.
2001 Tacoma, slightly modified
sploosh is offline
post #12 of 18 (permalink) Old 09-06-2005, 11:05 AM
TacoRat's Avatar
Git'er dun!
TacoRat is offline
post #13 of 18 (permalink) Old 09-06-2005, 11:38 AM
J*C*M's Avatar
Most stereo shops are going to do the same thing, except they'll wrap the wood in carpet first then over charge you for a "custom" job... If you cut the wood down so Just about a 1" oval, so it doesn't stick out past the speaker on the sides, then just wrap a strip of carpet all the way around it looks ok, on the cheap
2005 4X4 Access Cab 2.7 Locked and Lifted on 285/75's
J*C*M is offline
post #14 of 18 (permalink) Old 09-06-2005, 05:18 PM
AngryAndy's Avatar
Send a message via AIM to AngryAndy Send a message via Yahoo to AngryAndy
Thanks,
Kaleo
Hey Kaleo....
I put 6x9's in the back of my xcab...it was the first mod I think I did. If your in the area this week, or are going to Barney RIley, I will be glad to pop off the grill and show you my ghetto hack job....I seem to recall using a dremel, and cutting out the existing plastic piece....and turning the speaker so it sits at a 45 degree angle. It fit in there, and with the stock grill back on you cant even tell its in there.
"Soupbowl Challenge Winner 2006"
1997 Xtracab SAS Tacoma
1989 SAS 4runner "Project Angry"
2007 FJ Cruiser
AngryAndy is offline
post #15 of 18 (permalink) Old 09-06-2005, 05:21 PM Thread Starter
River Rat
lol mine are also ghetto rigged....but they are in a box sitting on the back seat.
I'll check em out at barney.
kaleo
post #16 of 18 (permalink) Old 09-07-2005, 12:22 PM
george.arnold's Avatar
Send a message via AIM to george.arnold
if you go to crutchfield.com and go to the section "What fits my car?" you can enter in your year and model and it will tell you everything that fits in what location. hope that helps
george.arnold is offline
post #17 of 18 (permalink) Old 09-08-2005, 04:06 PM
audiofreak97's Avatar
Send a message via Yahoo to audiofreak97
I think the size is 6.75 for all 4 speakers. I have 5x7s in the rear, and they fit using only two screws to hold them in without any modifications to the grill or mounting hole. If I remember exactly, but I think the mounting hole for the speaker will unscrew without taking the whole back end apart (if that makes sense). Good luck with it!
audiofreak97 is offline
post #18 of 18 (permalink) Old 09-08-2005, 04:11 PM Thread Starter
River Rat
thank you captain obvious
just messin with ya, but i had these 6 x 9's sitting in my room after i had totaled my rice rocket. they are really good speakers so i decided to throw them in the taco. they sure sound great! but take up a little more space than i wanted them to.
Stock Rear Leaf Springs for '98 Taco drewcruikshank Wanted 9 08-01-2005 12:21 PM
need ABS taco rear axle shaft Mace Wanted 10 07-14-2005 01:26 PM
4" lift taco rear springs and rs9000x shocks FS: oztaco Parts/Electronics/Wheels/Tires 9 04-24-2005 06:46 AM
Rear end clunk (not axle wrap?) BajaTaco Early Tacoma Tech 28 04-07-2005 05:30 PM
Taco rear end kyle Wanted 4 03-27-2005 08:08 AM
