Window rattle!!! How do i stop it?? - TTORA Forum
post #1 of 6 (permalink) Old 02-07-2006, 06:38 PM Thread Starter
Razor1616's Avatar
Send a message via AIM to Razor1616 Send a message via Yahoo to Razor1616
Angry Window rattle!!! How do i stop it??
I have been looking for a while now (almost 3 hours), to find an answer and i cant.
My driver's side window rattles like crazy when it is all the way up on my '02 ex cab. I have tried tighting everything. I have taken the door panel off to see what the problem is.... Still it rattles. DRIVING ME NUTZ. I roll the window down just a hair, and it stops rattling for the most part.
Thanks for the help.
~Nathan
Razor1616 is offline
post #2 of 6 (permalink) Old 02-07-2006, 08:19 PM
hk'dontoys's Avatar
~Nathan
i dont know if this helps your problem, but worked on mine. i had a rattle as i put the window up and down. bothered the crap out of me. the bolt on the side of the door was loose that holds the track. i removed the panel and at certain points during travel bolts line up in the access holes. one of mine was so loose it was ready to fall out, the other just a little loose. tightened every bolt i could see or find, sprayed everything down with lube, reinstalled and now its rattle free. checked all other doors too and some were a little loose but not like the driver door. go to search box and type "window rattle" and read some of the posts about it.
2001 tacoma d/c, with never enough extras!
hk'dontoys is offline
post #3 of 6 (permalink) Old 02-07-2006, 09:16 PM Thread Starter
Razor1616's Avatar
I looked through all the posts that had to do with window rattling... and they all seemed to be about when the window was in travel or completly down... and everything that was said i have done... and still the rattling... I want to get a new door.
My window only rattles when it is all the way up.
post #4 of 6 (permalink) Old 02-08-2006, 03:48 PM
hk'dontoys's Avatar
maybe try replacing the weather strip before you do the whole door.
post #5 of 6 (permalink) Old 02-08-2006, 04:20 PM Thread Starter
Razor1616's Avatar
I thought about that, but it is comming from inside of the door.... I can push hard on the arm rest and it will stop, but it still does it when i hold the window. I am just goin to tear the door apart when the weather warms up, and i dont have to work.
post #6 of 6 (permalink) Old 02-27-2006, 02:08 PM
elellilrah's Avatar
Foam
Fill it with insulating foam, that way it never rattles again. Seriously, you'll have to tear apart the door. I've got a rattle in my back door and have to hunt it down and kill it.
elellilrah is offline
fixed window rattle! hk'dontoys Newbie Tech 8 12-01-2005 03:59 PM
Window rattle? ElBandito Early Tacoma Tech 6 04-21-2005 09:17 AM
Master Window Switch augator Wanted 0 04-04-2005 02:39 PM
Window Control panel rattle SandyUT Interior/Electrical/Electronics 0 02-07-2005 11:04 AM
Got a ticket for Window Tint TacomaNova Off Topic 14 01-20-2005 10:43 AM
