Two 2-way radios on one speaker? - TTORA Forum
post #1 of 8 (permalink) Old 02-10-2006, 06:58 AM Thread Starter
vanguard's Avatar
I just got my ham license and I have a radio one the way. I threw in a cheap speaker while I was at it thinking that even a cheap speaker would be a big improvement over an internal speaker located under my seat.
My question is, "Is there a way to hook up both the CB and 2 meter radio to that speaker?"
vanguard is offline
post #2 of 8 (permalink) Old 02-10-2006, 07:52 AM
Crime and Punishment
zosimov21's Avatar
Showstop would be a good one to ask regarding this.
04 Taco
1980 1st Gen
Detroit Front / Welded rear
NC TTORA
http://www.ncttora.com/
zosimov21 is offline
post #3 of 8 (permalink) Old 02-10-2006, 08:34 AM
Ubernerd to the rescue
Here's one way of dealing with it:
http://www.aaroncake.net/circuits/mixer1.htm
guttapercha is offline
post #4 of 8 (permalink) Old 02-10-2006, 09:30 AM
wrooster is offline
post #5 of 8 (permalink) Old 02-13-2006, 07:06 AM
fourwd1's Avatar
Just use a switch. If you try listening to 2 audio sources thru one spkr at the same time it will be unintelligible.
Better yet get a 2nd spkr.
As seen in FOUR WHEELER magazine July 06, and OFF-ROAD magazine Feb 07
'84 4Runner ARBed 5.29s F&R, 4.7 & 2.28 t-cases, 2" drive train lift, AP hy-steer, BudBuilt x-member/skidplate, 36" TSLs, 30 spl Longs, Chevys
'80 something Toy P/U, Buick 231 V6, Holley 4 bbl, Weiand intake, Downey headers, TH350 L/U w/700R4 low gearset, dual tanks & batterys...
fourwd1 is offline
post #6 of 8 (permalink) Old 02-13-2006, 01:09 PM Thread Starter
vanguard's Avatar
It's mostly a space issue in the cab. I figured two feeds into one speaker would sound a lot like two speakers going at the same time but I'm not sure.
vanguard is offline
post #7 of 8 (permalink) Old 02-13-2006, 02:18 PM
Dick Foster's Avatar
You could try some big caps but you have to be careful with CBs as many of them switch the speaker with the PTT switch and use the final audio amp to modulate the TX. Get the unpolarized kind that are used in audio crossovers. Radio Shack has them. CBs are all so cheap that they will do anyting to save a nickel. I'd start by looking at both speaker outputs with a volt meter and see if you see any DC bias voltages. They don't always use a common ground return in the audio final so check to see if one side of the speaker goes to ground.
Dick Foster is offline
post #8 of 8 (permalink) Old 02-24-2006, 10:39 PM
1DERWHEELS's Avatar
either use the FET setup or a "on-off-on" style switch to listen to one at a time, the only other option is 2 speakers, think if one speaker fails it could cause damage to both radios or at the very least you wouldn't hear either one.
1DERWHEELS is offline
Toyota to factory-install XM Satellite radios in 2006 Valkyrie Off Topic 1 05-03-2007 02:57 PM
Toyota Genuine Parts OEM Tacoma Rear Speaker Grills - NOS - $35 Shipped thedeatons Miscellaneous Items 6 02-27-2007 08:24 PM
Two radios, one speaker BigBro Interior/Electrical/Electronics 6 09-19-2005 10:12 PM
PA Speaker TACORICAN Interior/Electrical/Electronics 23 03-18-2005 03:38 PM
External CB speaker ideas??? TacoCrazy Interior/Electrical/Electronics 5 03-17-2005 05:24 PM
