I've had a bad experience with this shop in Hemet, CA. called XTREME PERFORMANCE and FABRICATION. Had them do an install and they botched the job by not ordering the right parts/rear shocks. And then denying that they screwed up when I pointed out their mistake. I ordered Bilstein 5100's for the rear and they put Fabtech's on. After I pointed that out they re-ordered the Bilsteins but got 5125's instead of the 5100's. That would be ok except the didn't order the the correct part numbers again. Both are BES 6253's and this causes more droop to the drivers side. BES 6252 is the correct length for the drivers side. All Taco's have unequal shock lengths in the rear... 1/2 shorter on the drivers side. Plus they installed my Fab 2.5's and scratched the crap outta them installing them. I knew I should have done the install myself... I'm still waiting for them to correct this. But geezzz I have to prove to them they are wrong... so... after the holiday I gotta take the truck and original shocks back to them so that they may make their own inquery. Hey, all they gotta do is make one phone call to Bilstein to get the facts... When a shop is that lazy... it tells a lot about their work... When I finally get it corrected, I gotta find a new shop... sigh...
I believe there is only ONE lenght to the 5125. So, before you attack them, just be sure. The Donahoes, the same. So, I wouldn't sweat that too much. As to the scratches, I wouldn't worry too much unless they hammered the threads, or gored up the shaft. Then, Id have an issue. :2cents:
I've seen a couple of trucks around with stickers for that place....sucks to hear you had a bad experience....you were better off installing all that yourself....
Thanks rojodiablo, but then I feel they should have put the shocks on that I requested during the install. I ordered 5100's and got 5125's... how's that my fault? If the 5125's are not applicable to the Taco then I should have been advised and I would do my business elsewhere or just order them myself. I'm not trying to badmouth this shop for any other thing except the fact they don't know the differences between a Chevy and Toyota. The shop owner questioned me when I told him the Taco has unequal rear shock lengths... He states, " I've never heard of that. Bring it down to the shop so I can see". And I will. But in all fairness... I heard these guys really know how to tune a engine and that is their best skill. But suspension work is not their forte. Yet they took my money... So I was just warning others so they might be aware of my issues...
are the billed differently because the 25s come in two different valving as opposed to the singled-valved 5100s? Bil's site lists the part# slightly different as well.
I was hoping you'd get in on this one
a 5100 is a stock length 5100, basically its a 5125 that will fit without any lift or anything... its the same thing as a 5100 except that they have general sizes, for those applications where nothing else applies.. IE a lifted truck.. other than that its the same dam shock... you wont find a 5100 for lifted application toyota tacoma shock.. You will find 2 different part number 5125's aka lifted application 5100 shocks that come in multiple sizes that will work the same....
This guy is crying because teh part # isnt 5100 its 5125.... notice the 51 and 51, the only reason bilstein put 25 is because of the annodized cans...
well, I know 5100 isn't a part # I was refering the BES- for 5100s vs the BE5 for 5125s that shows up on the website. Or, are they the same and the 'S' is actually a '5'?
depending on how much lift is added it looks like there are 3 that would work for 2-4" of lift; 6252, 6253 and A465.
they are a decent shock for what your doing... The one thing to think about is, are you actually going to spend the time playing with valving or are you just getting it for bling factor, if your not getting it to actually modify it just stick with 5100's or excuse me 5125's LOL
I will need a shock that will work for both wheeling (max travel) and hauling so I will have to play with how they are relocated. I will not be doing the usual / \ pattern since that kind of negates the purpose of having them there in the first place I'm not interested in bling, just what will work best.
What about going with something that is adjustable? ie, soft for trail riding but max support for hauling.
if your in Hemet next time call John at AllPro offroad. great guy.
as others said, 5100 stock replacement, 5125 offers other lengths from stock. don't complain if your getting a more $$$ shock!!!
do a relo by kicking shocks backwards and tilted in toward each at top. hope that makes sense. I can email you pics if you want. rides better then A-pillar type relo / \ I had that at first.
adj shocks control compression only. I have the rancho 9K's adj, they suck.
jsut ordered fox with their new CD adjuster on them. yes they are $$$.
doubt you'll find a shock that works great for both wheeling and hauling, except for airshocks.
Did anybody actually read my thread? The 5100's are the Taco stock replacements (add about an inch travel) The 5125's are longer travel about 8 inches... My question was the length of the shocks... I never said valving!!! Taco's use unequal length shocks in the rear. I know the 5100's come (if ordered for a Taco) in unequal lengths. But since I got the 5125's instead I was trying to confirm that the 6252 and the 6253 were the proper unequal lenths for the Taco to allow for equal droop on the rear springs... instead all I got was folk bangin' on me and callin' me a dumbass... If you think trying to get clarification for something is whining then so be it. But if you don't really understand what I'm asking don't bother to say anything at all.... Geezzzzz.....
I like the advice of relocation. However I don't have the proper machine tools and I'm disabled with Carpul Tunnel Syndrome in both hands (makes it difficult to turn a wrench) I'm not complaining it's just a fact of life... That's why I have to pay someone to install my components in the first place. If my hands worked properly then I'd do it myself... because I'm anal about doing things right...
I listed the part #'s I was inquiring about... I know the difference between a 5100 and a 5125... That's not what I was asking... If you don't understand the question it's better to say nothing at all....
Why is it if a dude has got senior or veteran under there name, they feel the need to blast some guy for asking a question. After all I though this was the newbie forum! the moderators should help this guy out. As for internet tuff guys give it a rest, impress us with an answer to the question; rather than with your rapier like witt!
The "droop" of a same length after market shock on a Tacoma does not affect anything as far as driving feel. I doubt you could notice it at all. Most aftermarket applications for the rear of the Tacoma do not come in different lenghts anyway. The only way it would be noticed is if your truck is on a repair rack or if you drive like "DesertTRD" in his avitar......lol
Bill
PS. The difference in the 5100 (if ordered for a Tacoma) and 5125, is that the 5100 comes with the 3/4" bushings installed in the shock (because it is a specific application for your truck), and the 5125 (is considered a "universal" application and comes in many lengths) has the 1/2" bushings (which you will have to change to put on your truck).
Related Threads
TTORA Forum
2.4M posts
75.5K members
Since 2004
