Welcome to the TTORA Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. ATTENTION: In an on-going effort to keep this forum spam free, the Forum Admin approves every new account before giving any posting rights to new users. Accounts are normally approved within 24 hours. Sorry for any inconvenience, but verification of every new account is what will continue to keep this forum spam free. |
Thread Tools | Display Modes |
#1 |
hey, pretty new here to the board and to the so cal area. Have a 1989 toyota ext cab with sas and 6" front and rear lift. the front driveline is currently not on because the angle from the t-case to the axle is too big.... the driveline won't match up. I just bought the truck, and previous owner told me that the 6 degree shims would make the angle work. Was curious if there is anybody in the area with any experience with this sort of thing. Would really appreciate any and all help, maybe somebody with a welder to help me weld in the shims. I don't think it will take long, just take apart the front end and put it back together, just don't have a lot of tools or room... the auto shop on base is pretty backed up and I'm a little iffy on doing it by myself. PM if you are up to helping me out.... I'll even throw in a 6 pack of your beer of choice haha
![]() here is an awesome link, that i have been going through and trying to understand more... http://www.4crawler.com/4x4/CheapTri...n-Measurements I measured myself and the length from the top of the tcase flange to the top of the axle flange is 30 7/16. from bottom to bottom is 29 1/2. the only problem is that's for a single cardan driveshaft, i don't really understand how to get the measurement for a double cardan driveshaft. bottom line, would love help if somebody is willing. Like i said, i have 6 degree shims that the previous owner said would work, but i wanted to figure it out myself before i welded them on.... heres my driveshaft i intent to put on... ![]() any help is appreciated... sorry for the long read... I know that rotating knuckles is the best, but seems a lot harder. |
#2 | |
Just another newb....
![]() Join Date: Jul 2006
Where are you located? (driveshaft says Banning)
If you are in the San Diego area, Try Bengels Off Road
SoCal TTORA Forum SoCal TTORA Website |
#3 |
thanks... I am located in laguna niguel... just north of san clemente.... I'll give them a call... thanks.
#4 |
6* shims seems like way too much to me. 2* shims helped on my buddy's truck, the angle is still off, but the combo of shims and clearancing the cardan joint made it work for the time being. shims will affect your caster too, don't forget that. does the truck have dual cases? do you plan on doing dual cases if not?
'98 tacoma extended cab SAS Dana 44 with the works |
#5 |
truck does not have duals and I don't plan on going with duals for a while. Currently it is my DD, which is another reason I am trying to get this right, i do not want to effect my caster too much or steering.
#6 | |
#7 |
i think its a 92 or 93 with a 5" all pro kit, i'm not 100 % sure though
what front axle are you running? is that a 15* joint? a 30* joint might solve the problem
#8 |
6* shims are a bad idea they will effect the way ur truck handles immensely not to mention put ur tierod alot closer to the spring pack itself
honestly ur best bet is get a highangle driveline or go dual cases give yotamasters a call 1 951 279 0220 they will be able to better explain tell eric cheezy told u to call |
#9 | |
#10 | |
Messing with the drive shaft will be one way to fix your problem but not the best. Duals and another drive shaft with the cv clearenced will be your best bet if your not going to rotate the knuckles. I live in Westminster, not too far from you really if you need any help.
'05 "SAC" Double Cab TRD Sport 4x4 with Marlin Crawler "Taco" Box and a bunch of other stuff. Linked, Locked & Large! "THE BEAST" AKA "THE BIG SEXY" Wyatt Scott![]() 3.4 auto crawler install Installing an FJ Case into an 05+ Tacoma My Build thread. Building "The Beast" GOT SAC? |
#11 |
You might also want to consider switching the front CV to a u-joint as the u-joint will give you more of an angle. We recently did this with my brothers front driveshaft...
This was the advice we got from Yotamasters...Like Justin (84SoCal) said Yotamasters knows their shit!
#12 | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| sas driveline ? | LILTACO | Solid Axle Swap Tech | 28 | 12-26-2010 07:43 PM |
| Driveline | louis | Solid Axle Swap Tech | 6 | 07-09-2009 07:01 PM |
| Driveline Rattle | yotafab1415 | Late Tacoma Tech | 7 | 08-22-2007 09:26 PM |
| Driveline Q's | 1moreyota | Tech | 40 | 06-10-2007 08:46 PM |
| driveline | gmrwizard | Wanted | 2 | 12-13-2005 07:07 AM |
