Go Back   TTORA Forum > General Tech > Suspension
Old 04-28-2012, 09:05 AM   #1
kala
kala's Avatar
Default 2005 taco SAW/AllPro-height/weight settings
I installed an AP front bumper on my 05 with SAW 2.5s and 305/70R16 Swampers. The tires were only put on the other day and rub on full lock. I was previously running 265/75s and had no clearance issues. Im also running no sway bar. I just bought a 10k winch and want to install it.
With the smaller tires I didnt have a need to go higher on the c/o. Its still at stock settings, except the nitrogen is only filled to 120psi in the front. Im thinking of adjusting it an 1-1.5"s higher to help clear the tires. Am I going to run into any problems with the SAWs? Is the winch/bumper too much weight to be running on SAWs adjusted that high? Anyone use this set up in the desert/dunes?
If I need to, i'll go back to 265/75s and keep the ride height lower. I understand this set up may be a lil harsh on stock susp components, but fck it, I cant afford LT right now.
I'm Dirk Diggler and you're not.
kala is offline   Reply With Quote
Old 04-28-2012, 10:55 AM   #2
johnecon2001
Tiny red truck
johnecon2001's Avatar
What height were you running previously? Do you have aftermarket UCA's?
ARB ~ Bilstien ~ Doug Thorley ~ AllPro ~ Desert Fab ~ Hankook ~ PowerMaster ~ Stubbs ~ Tom Woods ~ Total Chaos ~ TRD Trail Team ~ Bovads ~ Wheelers ~ Nitro Gear
johnecon2001 is offline   Reply With Quote
Old 04-28-2012, 06:46 PM   #3
kala
kala's Avatar
Stock uca's and didnt adjust it. it was a good height installed. now i need to make it higher. I didnt plan for extra weight.
Old 04-28-2012, 08:56 PM   #4
johnecon2001
Tiny red truck
Just be careful how high you go. The max you can go with stock UCA's is 2.5". Taller than that, and you won't be able to get a proper alignment out of them.
Old 04-28-2012, 11:27 PM   #5
kala
kala's Avatar
Yeah, that's what I was going for, maybe slightly lower, but just around that height. I'll get to adjusting it tonight and i'll take it out tomorrow. I just didnt wanna be busting my saws!
keeping stock height with winch/allpro bumper hockeyplayer4 Suspension 7 10-07-2011 06:56 PM
Coil Length/Weight vs Ride Height questions blkrstr21 Long-Travel Suspension Tech 3 12-10-2009 11:35 AM
2005+ AllPro LT Hayhauler Wheels/Tires/Suspension 32 06-12-2009 11:42 AM
My Taco needs some height XJMedic Suspension 31 04-23-2006 06:52 AM
Weight of your sas taco... Tacominator Solid Axle Swap Tech 9 03-11-2006 12:28 AM
