Go Back   TTORA Forum > General Tech > Suspension
Old 05-26-2012, 11:11 AM   #1
ajfritzler
Default front end noise or clunking
Hey searched the forums to see if anyone else had this issue but no results. I have a 2.5'' spacer kit in the front of my 2001 4x4 with diff rotation. After the kit was installed i get a clunking on the rebound of a bump. Like a tapping out sound when the suspension is rebounding off a speed bump or roller on a dirt road. Always when the front end becomes unweighted. I cant seem to find why this is happening. Is it a cheap kit? Would an upgraded kit solve this? Please let me know if anyone had encountered this in the past. Thank you for your help.
ajfritzler is offline   Reply With Quote
Old 05-26-2012, 11:20 AM   #2
ajfritzler
is the front travel maybe over extended? would a 5100 series shock maybe solve this?
Old 05-26-2012, 01:14 PM   #3
Wainiha
My Rig: 2000 Tacoma
Is the spacer on the top plate of the shock?
3.4 TRD
ICON C/O
Marlin Clutch
Wainiha is offline   Reply With Quote
Old 05-27-2012, 09:08 AM   #4
ajfritzler
yes, the kit on the truck now is just one of those spacer kits that mounts on top of the strut
Old 05-27-2012, 09:30 AM   #5
1990dlx
1990dlx's Avatar
ball joints ok?
99 Tacoma, bug-shield, and air freshener. Rusty tailgate mod, oxidized paint mod, cracked windshield mod.
1990dlx is online now   Reply With Quote
Old 05-27-2012, 09:34 AM   #6
ajfritzler
ill check. with a spacer kit like this, is it just tapping out on the rebound from being over extended?
Old 05-27-2012, 09:35 AM   #7
ajfritzler
The other thing was it just did this after this kit was installed. I had a 1'' in before and this never happened
Old 05-29-2012, 12:27 PM   #8
hossmaster
MASTICATOR
hossmaster's Avatar
what kit did you use and are your swaybar endlinks tight?
02 dbl cab 2.5 dirt logics Just another wanna be
"we had us some fun"
"Blue Water Inn, We Got Pyramids!!!"
hossmaster is offline   Reply With Quote
Old 05-29-2012, 02:41 PM   #9
dalethemail
bottom balljoint is geting reddy to break
dalethemail is offline   Reply With Quote
Old 05-30-2012, 06:37 PM   #10
davidw2337
Default Had the same problem
Jack your front up to hang your tires. Check to see if your springs are not hitting your upper portion of the strut. I had this happen to me. I went with all-pro's upper a-arms to fix the problem. They are an inch longer than stock.
davidw2337 is offline   Reply With Quote
Old 06-07-2012, 07:16 AM   #11
fourwd
fourwd's Avatar
Sounds like your coil is slapping at the spindle, near the top, dump the spacer & it goes away or if you want to keep the spacer, you'll have to get some aftermarket UCA's...
Lead....Follow....Or get the Fuck Out The Way !!
fourwd is offline   Reply With Quote
Old 06-09-2012, 03:58 AM   #12
Plasstik
Main Man's TRD
Plasstik's Avatar
My Rig: 03 Tacoma
Send a message via Yahoo to Plasstik
I've had this same problem for the last 8 years. I've changed the front shock set up a few times. Changed the UCA, ball joints upper and lower. Go to your front shafts and try to shake the portion that goes into your front diff. If you have a lot of play there it may be the source of your noise. I'm working on setting up a camera try to confirm if I'm correct.
If you are offended…..It’s not my fault you put yourself in that category!
Bilstein 5100, Toytec 3" spring lift , 33 M/T, Camburg UCA, Daystar 1" body lift BLa Bla Bla do you really give two shits to what is on my truck? NO! I didn't think so, but more to come when I get the chance.
Peace and a bag of chips!
Plasstik is offline   Reply With Quote
massive lift noise and clunking and front end sag trd98tacoma Suspension 6 02-21-2011 12:59 AM
Front end poping/clunking noise AJStaco2000 Early Tacoma Tech 10 10-30-2010 02:09 PM
Clunking noise? MYTOY Early Tacoma Tech 7 10-17-2006 10:19 PM
clunking noise ciollika Early Tacoma Tech 3 06-29-2005 08:25 AM
Clunking noise from the front left wheel when turning right Aviators Early Tacoma Tech 12 04-04-2005 07:25 PM
