Go Back   TTORA Forum > General Tech > Tires/Wheels
Old 10-11-2006, 11:46 AM   #151
ELI
ELI's Avatar
Send a message via AIM to ELI
Originally Posted by jon_7248
I know, I'm beating a dead horse!
ELI
[list]
1995.5 Toyota Tacoma 4x4 Reg. Cab
- 6" of lift
- 15x8 Black Rockcrawlers
- 33x12.50 BFG M/T KMs
- Lockright Rear
- 4.88's
- SAS shopping started...again!
2006 Tacoma Access Cab PreRunner
-Daily Driver
1985 Toyota Pick-Up 4x4
- Stock...for now.
ELI is offline   Reply With Quote
Old 10-12-2006, 10:17 AM   #152
EMPIRE
Banned
Originally Posted by Horns
Just put some wheels on my 05TRD sport without any problems. Baja champs 185 Ultra wheels 16/8. They are sittin on a 3in tuff counrty ezride suspenion lift. Tires are coopers discoverer STTs 285/75R16 Some minimal rubbing.
http://www.ultrawheel.com/wheel_deta...brand=1&id=111
they dont rub the frame near the body mount at full turn ???
EMPIRE is offline   Reply With Quote
Old 11-30-2006, 01:45 PM   #153
MT4Runner
MT4Runner's Avatar
Has anyone found a longer lug stud for the front -- especially if you're using a 1/4" spacer? Damn near every Toy 4x4 since 86 uses the Dorman 610-266 stud; (and now Chevies do, too), there doesn't seem to be an equivalent but longer stud out there.
MT4Runner is offline   Reply With Quote
Old 11-30-2006, 03:58 PM   #154
007
when I put my 2001 reg cab 16" factory steelies on my 06 dbl cab there was a slight clearance problem on the calipers.
The wheel barely touched the caliper so that it made a very very slight noise in three spots but did not actually impede the rotation of the tire.
I drove it around the block once and it became silent. So it must have made its own clearance.
007 is offline   Reply With Quote
Old 12-06-2006, 02:55 PM   #155
Tufemup
Default Pro Comp 8179 16x8 fit
You can add Pro Comp 8179 16x8 wheels with 4" backspacing to the list. I just put them on an '01 xtra cab 4x4 3.4liter with 4" lift. Tires are Toyo Open Country A/T 295/75R16. See pictures here:
http://community.webshots.com/album/556252275HqAjLQ
Tufemup is offline   Reply With Quote
Old 12-06-2006, 05:38 PM   #156
tcummings
A Toyota tech at my local dealership mentioned that changing from 17"s to 16"s can cause the fron discs brakes to warp on the 05-06 Tacoma Sports. Has anyone that owns a Sport with 16" wheels experienced this problem?
2006 Tacoma 4WD Double Cab TRD Sport
Stubbs Sliders, Donahoe extended CO’s, Donahoe UCA's, Deaver 11 pack, Doanhoe Rear Res, Black Steelies, 265/75/16 BFG ATs
tcummings is offline   Reply With Quote
Old 12-08-2006, 05:49 PM   #157
Mikevr007
Mikevr007's Avatar
Send a message via ICQ to Mikevr007 Send a message via AIM to Mikevr007
Originally Posted by 1990dlx
I think there is an error on the list. I tried American Racing type-23 in a 15x8 and they DID NOT fit my 99 4x4, non-trd. They definitely hit the calipers. I had them on my 1990 so I tried to swap them when i bought the Taco and they were a no go.
The list says that the contributor of the info didn't list the Taco info. It fit someone's taco or it wouldn't be in the fit list.
I'll add your combo to the do not fit list.
Please remember that when using the list that you compare apples to apples when looking at the truck specs etc.
2004 Tacoma X-Cab 4x4, V6/Auto, TRD.
A.R.E Topper
Deckplate &elbow mods
DR 2.5" spacers/AAL/Bil 5125's
4Crawler 1" Body Lift
32x11.5 BFG MT's
15x8 American Racing Diamond Lock II's
Electric Fans . Blue Top
Mikevr007 is offline   Reply With Quote
Old 12-08-2006, 06:07 PM   #158
Mikevr007
Mikevr007's Avatar
Originally Posted by NTAPHSE
FYI I just put on American Racing Daytona 84 series wheels. They are the black D hole wheels in 16x7, 4" backspace. Fits perfect, no rubbing on brakes or frame with TrXus MT 285/75/16. I bought them at Summit online for $58.88 each, plus $9.95 shipping, total was $245.47. Discount refused to mount the 285/75/16 on a 16x7 rim, they said it had to be a 16x8, so I went to a Llantera (Mexican tire shop) and they did it for me. Honestly, I think the look good on a 7" rim, its not nearly as bulged as I expected.
Truck is a 2001 ext cab Tacoma, TRD 4x4.
UPDATE: After running this combo for 3 months I am still happy with it. I have noticed some very light rubbing on the frame, as evidenced by small rub marks on the frame, but I have never heard it rub. Also, I lost a bead once, but I was hauling through a sandy wash getting sideways on 13 psi. When I stopped there was sand in the bead allowing it to leak. This might have to do with the 7" wide wheel, but I think I just got a little too crazy for 13psi.
I also found out that one of the wheels came bent from Summit (Discount told me when they tried to balance them). Summit was very cool about it and I wound up keeping the bent wheel for a spare and buying a new one for half price.
Added. Thanks for the info!
A.R.E Topper
32x11.5 BFG MT's
Old 12-08-2006, 06:16 PM   #159
Mikevr007
Mikevr007's Avatar
Originally Posted by NorcalPR
You can also add this:
2001 Tacoma Xcab V6 4WD TRD no ABS: 15X8" Pro Comp alloys 1079
Phil, this combo is already covered by:
"-Procomp Xtreme 1079, 15x8/3.75bs, 1999 Tacoma PRE V6."
The '01 XC V6 4WD and the '99 PRE V6 are in the same caliper list...list B.
FYI-
A.R.E Topper
32x11.5 BFG MT's
Old 12-08-2006, 06:25 PM   #160
Mikevr007
Mikevr007's Avatar
Originally Posted by lmrym
I believe it's safe to add 16x8 w 4' bs ref:468412. It has worked for others in the past w 2001-2003 prerunners in either 2wd or 4wd w ABS.
Added with quote for Tacoma model(s). Basically any Taco in Caliper list B.
A.R.E Topper
32x11.5 BFG MT's
Old 02-10-2007, 08:39 PM   #161
tacomawheeler98
tacomawheeler98's Avatar
Originally Posted by Zsasbo
Just noticed the following post on 4WP website for the Series 152 Street Lock wheel..."15x8" 6 on 5.5" bolt pattern w/3.75" backspacing Does not fit Toyota Tacoma
PCW152-5883"
So you can probably put that on the list. They don't specify year or type though.
Those fit my 1995 tacoma with ground calipers and no spacers. I did have to trim and beat with a hammer though.
tacomawheeler98 is offline   Reply With Quote
Old 05-29-2007, 11:54 PM   #162
toycoma732
toycoma732's Avatar
Default Street Lock Rims
Procomp Street Lock series... 16x8 8x6.5s 4.5" BS (Stock)
Will these replace stock rims for my '04.... just looking to keep same size tire in replacement of stock rims...
Thanks,
Derek
History: '85 4runner Dual... the works
'96 SAS'd taco with goodies
04 Double-Cab ...
oh yeah......just remebered why i never got into surfing at least on my bike im not gonna get chased down and eaten by a grizzly
"Hey, forward me that monkey sex video, I need to forward it like its hot" -The Office
toycoma732 is offline   Reply With Quote
Old 06-08-2007, 08:30 AM   #163
arrowpilot
arrowpilot's Avatar
15x10 Nipper Flames fit.
Unfortunately.....one of em has a hairline crack in it.
06 TRD Sport, Dub Cab, 4x4
285/70/17 ATR's on ProComp 17x9 8179's
Shrockworks Winch Bumper, Sliders and Bottle Opener
OME 886 Front, AirLift Rear
arrowpilot is offline   Reply With Quote
Old 06-10-2007, 01:18 PM   #164
caveman
caveman's Avatar
There doesn't seem to be many 16x8's that will fit an 02 dubcab TRD. Are there any others?
caveman is offline   Reply With Quote
Old 11-02-2007, 04:43 PM   #165
kneetoski@yahoo.com
Default '05 Tundra stock steel to '99 taco EC TRD 4x4?
Is it possible to use the stock '05 tundra steels 16x7 (not sure of offset) on my 99 taco? I intend to use a 265 70 R16.I know newest of the newbie ?'s
kneetoski@yahoo.com is offline   Reply With Quote
Old 01-25-2008, 09:09 AM   #166
misterjason
what about the 15" aluminum wheels from wheelers? will they fit a 2002 factory-equipped 16" wheel truck?
thanks
misterjason is offline   Reply With Quote
Old 01-29-2008, 08:14 AM   #167
sirsaechao
sirsaechao's Avatar
My Rig: 2002 Toyota Tacoma
Send a message via AIM to sirsaechao Send a message via MSN to sirsaechao Send a message via Yahoo to sirsaechao
Wheels I've owned that fit my 02 TRD:
16 X 8" Ultra Type 164 4.25" BS
16 X 8" Pro Comp 6059 4.5" BS
2002 Toyota Tacoma SR5 TRD 3.4L 4WD ext cab:
King Off-Road Racing Shocks 2.5" coilovers
Wheeler's Off-Road Inc. 5-leaf rear leaf pack
Old Man Emu NitroCharger Sport rear shocks
16" x 8" Pro Comp 7069's w/ 265/75R16 Cooper ATP's
Magnaflow muffler, AEM Bruteforce intake
Full JL Audio sound system
See below...to much to list
Click Here To See My Junk
sirsaechao is offline   Reply With Quote
Old 01-29-2008, 11:00 AM   #168
NickJ
NickJ's Avatar
Does anybody know if these will fit?
SSC style 73
15x7
Can be found at sears autocenters, a very good price for a chrome plated rim, also one of the few 15" chrome rims out there. $112 ea.
They do not list back spacing or lug patterns, I contacted and got nothing in return. But I really like the look of them and the price for a chrome wheel, polished aluminum sucks in MN with all of our salt.
So basically wondering if anyone else has used them or seen them on a tacoma
1996 2.7 5 speed Xtra cab
K&N filter, Header, Magnaflow
235/75/15 cooper ATR
ø„¸¨°º¤ø„¸¸„ø¤º°¨¸„ø¤º°¨
¨°º¤ø„¸ In Flames¸„ø¤º°¨
¸„ø¤º°¨ We Trust! ``°º¤ø„¸
¸„ø¤º°¨¸„ø¤º°¨¨°º¤ø„¸¨°º¤ø
NickJ is offline   Reply With Quote
Old 02-11-2008, 02:52 PM   #169
Boomtacoma01
Boomtacoma01's Avatar
My Rig: 85 Ext Cab
Send a message via Yahoo to Boomtacoma01
Moto Metal 955 16x8 with 4.5 BS fit my old 07 Tacoma DC TRD Offroad 4x4 with no rubbing issues. Might be a little late on an old post
________________
-Chris
'85 Yota on 37's and Dual Ultimates
09 DC 4x4 Tacoma on 285's DDer
Boomtacoma01 is online now   Reply With Quote
Old 02-19-2008, 10:56 PM   #170
Turkish1
Turkish1's Avatar
Will Crager 15x10's with a 3.75" BS Street Lock D's fit? I'll be running a 33x13.50 tire so I may need a spacer to clear the upper balljoint. Whatya say?
Turkish1 is offline   Reply With Quote
Old 02-26-2008, 03:10 AM   #171
snowmansimon
Anyone know if the procomp 8069 15x8.5 will fit an 02 tacoma?
http://www.4wheelparts.com/PDT246416.aspx
snowmansimon is offline   Reply With Quote
Old 02-26-2008, 10:16 AM   #172
NorcalPR
NorCal Chapter Pres
NorcalPR's Avatar
My Rig: SAS'd 01 Tacoma
Send a message via AIM to NorcalPR
It's 15X8 and yes it will fit since it's the same exact rim as a 1069. A 8079 is the same exact thing as a 1079......
Hi, my name is Phill, above are things I say
W6FTW
Do you live in NorCal? Have you checked out the NorCal Section located here? If not check in today!
NorcalPR is online now   Reply With Quote
Old 07-01-2008, 10:02 AM   #173
JOEPRUNC
JOEPRUNC's Avatar
My Rig: 2004 Taco
Default 15X8 Mojave Teflons
I just put on 15X8 3.75 BS Mojave Teflons on my
2004 Tacoma Ext Cab 4X4 V6 w/ abs (No VSC) and they look quite nice . They fit tight, but no rubbing anywhere.
2004 Ext. Cab V6 5spd. 4X4
Camburg CO & Dakars
15x8 Mojaves w/32 KMs
DO Sliders / R. Bumper
On the hunt for:
R. Locker; On board Air; F. Bumper
JOEPRUNC is offline   Reply With Quote
Old 07-01-2008, 02:07 PM   #174
NORTHWESTTACOMA
NORTHWESTTACOMA's Avatar
I am not scrolling thru all 6 pages to see if these are already on here but, these fit my 05 DC 4x4. They are 16x8 Mickey Thompson Classic Locks II with 285/75 Mickey Thompson MTZ's. The wheels fit without any mods. The tires however rubbed like mad at full lock, so I was forced to trim some plastic and they scrubbed the body mount quite a bit so I removed a chunk to clear it.
05 Silver Tacoma DC 4x4, Extang tonno, TRD Skid Plate, N-FAB lightbar w/4 Hella 500's, Cornfed spacer, Black Raceline Renegade's on 33" M/T MTZ's
91 Jeep XJ, 4.5" Rusty's lift, 33" ProComp
http://tinypic.com/r/dbruwh/7
66' VW DRAG BUG - 9.90@124.57 in the 1/4.
http://i149.photobucket.com/albums/s...d/IMG_1296.jpg
http://i149.photobucket.com/albums/s...d/IMG_1321.jpg
NORTHWESTTACOMA is offline   Reply With Quote
Old 09-25-2008, 11:40 AM   #175
dhol100
So in my ignorance, I just ordered/recieved the rock crawler series 97 16x8 for my 07 prerunner. As im sure you all know they dont fit due to caliper clearance. Will 1/4" spacer fix the problem? Ive read the entire thread and i only see assumptions/opinions on this particular problem. First hand experience please? Anyone get the series 97 to fit a 05+ tacoma?
dhol100 is offline   Reply With Quote
Old 09-25-2008, 11:50 AM   #176
EMPIRE
Banned
Originally Posted by dhol100 View Post
So in my ignorance, I just ordered/recieved the rock crawler series 97 16x8 for my 07 prerunner. As im sure you all know they dont fit due to caliper clearance. Will 1/4" spacer fix the problem? Anyone get the series 97 to fit a 05+ tacoma?
can you shave the caliper rib down some so wheels will fit ??? i did on mine to fit pro comp 1079's.
Old 09-25-2008, 11:53 AM   #177
EMPIRE
Banned
even with a 3" lift up front 285/16's will hit the frame at the front body mount. many folks slice that area off on a angle and weld a plate over the hole left behind.
if you want to see how ad 285's rub just take your truck and get 'er tweaked over some rocks/terrain, etc, and you'll quickly see there's not much room for 285's to articulate and clear everything.
do you have new UCA's?
Old 09-26-2008, 06:35 AM   #178
Quattro15
Will this 16" TRD wheel fit my 99 Tacoma with no issues? Does anyone know the backspacing on this wheel? A friend on here is selling them to me and I'm just curious as to what issues may arise.
Thanks!!
Quattro15 is offline   Reply With Quote
Old 05-25-2012, 11:51 AM   #179
TheosTaco
TheosTaco's Avatar
Originally Posted by Mikevr007 View Post
Good point.
In that case, that combo is alread covered.
-Mickey Thompson Classic II, 15x8/3.3125bs, 2001 Tacoma 2WD V6 DC.
and...
The 2001 Tacoma 2WD V6 DC is in the same caliper list (B) as the 2004 Tacoma 2WD Prerunner V6 XC.
Thanks Juicy.
Thanks Norcal.
So do the Prerunner & 4WD Tacomas have different calipersizes? Sorry if the questions come across stupid...I'm just trying to make sense of all this. I'm wanting to fit 15x8 6-5.5 3-5/16BS Mickey Thompson Black Classic II's but am not too sure if they will fit. I was told the 16'' Wheels will fit but not too sure about the 15's. Can anyone elaborate on this for me? I'm sick of my wheels & tires and want to get the ball rolling.
T
Manual
v6 3.4L
4WD
TRD
SR5
Spray In Bedliner
Stock(for now)Taco
WANTED: Icon Coilovers, 2 x Bilstein 5125 Rear Shocks, Pair of Leaf Springs, Stainless Rear Extended Brake Line, Etc
TheosTaco is offline   Reply With Quote
Old 08-10-2012, 09:48 AM   #180
TheosTaco
TheosTaco's Avatar
I found some Mickey Thompson Classic 15x8's with 3.5" BS
They have "Et-28" on them
Will they clear my calipers?
I'm driving a v6 3.4L 4WD 2004 Tacoma Extended Cab.
I need to know asap so I can buy them before someone else does....Your help is most appreciated.
Manual
v6 3.4L
4WD
TRD
SR5
Spray In Bedliner
Stock(for now)Taco
