Go Back   TTORA Forum > Vehicle Specific Tech > Pickup/4Runner Tech
Old 06-02-2012, 08:48 AM   #1
BBCoffroad
BBCoffroad's Avatar
Default om 617 swap tons of pictures
well after toasting two 22re and always stalling them out i got the idea to put a diesel under the hood. i thought about a 4bt but to much power id have to swap in a 1 ton drive train with a little reserch the om617 was the anwser for me so here we go with the pictures.
got it from a local junk yard it was sitting in a pile of engines it was rough looking i really didnt think it was gunna run.
after cleaning it up a little i found that the upper oil pan was cracked.
i cut off the cracked section of the pan to fabricate a new lower pan.
i have a welding hobby shop on the base im stationed at i do all my work there.
these are just a few randon shots of me cleaning the engine up.
i didnt get a glow plug controller with the motor so i made my own its manual i used heavy guage wire a starter relay and i push button switch its simple and effective.
i made the fuel shut vavle out of one of my old toyota VCV off the 22re emmision system.
couldnt find AN adapters for my oil cooler so i modified the originals
i built the tranny adapter out of two pieces of .25 steel plated welded to each other a total thickness of .50 i located the engine mounting holes with the original merc adapter plate.
i made a pilot bearing adapter at work out of tool steel it came out nice
i aligned the tranny by inserting the input shaft into the pilot bearing and clamping the tranny to the plate and marking the holes its not the most precise way to do it but its proven so far to be just fine im working on a .75 thick aluminum plate currently that one will be blue printed to be precise.
this is my fly wheel sitting on the adapter i had it re surfaced and a new bolt pattern drilled by south bend clutch those guys a the best to work with great prices and fast turn around. the picture is before i had it machined.
got most of the engine clean and inspected it was time to test it to see if it worked or not it took a bit to get it to fire. the injection system was gunked up pretty bad.
the noise was the starter it was to close to the fly wheel and stayed engaged you can see it arking on the block.
BBCoffroad is offline   Reply With Quote
Old 06-02-2012, 09:01 AM   #2
BBCoffroad
BBCoffroad's Avatar
got the engine bay all clean up for the swap i ended up only using 3 wires to controll the start up and shut down of the engine.
i got moving pretty quick once i got to the point of putting the engine in so theres not a hole lot of pictures to show progress.
got it there its a little tight had to put the rad in the rear didnt feel like finding a small one to fit in the front i could have moved the crossmember back and gained to inches but that would have been a lot of drive line mods and money so i mounted it in the rear.
Old 06-02-2012, 09:19 AM   #3
BBCoffroad
BBCoffroad's Avatar
i plated the frame from the front cross member to the cab with .25 plate on the inside and top motor mounts are 1.75 poly bushings there stiff as hell the hole vehicle shakes. i used 1.5 stainless pipe for the rad tubes goin to the rear i have plate style coolers for the oil and steering coolers i also used a steel vacuum can from summit. i made the exhuast out of 3'' mandrel bends it was my first time using mandrels it was fun fitting them all.
i have a boost/vac guage mounted on the roll cage pillar i also have a oil pres mounted just not mounted in the picture.
Old 06-02-2012, 09:37 AM   #4
BBCoffroad
BBCoffroad's Avatar
got all the kinks worked out and it was time to go wheelin to see if it would survive.this is a good before shot. the closest place to go wheelin is uwharie national forest its a good recreaction area 20 miles of trails, hiking its a fun place its near charlotte NC if your on the east coast its worth the trip.
a couple videos not the greatest though
at the end of the trip it did very well the only thing that broke was one of the tie rod ends and the vavle cover gasket started to leak really badly.
Old 06-02-2012, 10:45 AM   #5
lrgrnr
lrgrnr's Avatar
Nice build!
I've seen you at URE before.....I remember hearing the diesel as you drove past.
lrgrnr is offline   Reply With Quote
Old 06-02-2012, 12:19 PM   #6
Scuba
Looks really good! Nice build.
99 Single Cab 2.7. Awaiting 3 Link SAS.
Scuba is offline   Reply With Quote
Old 06-02-2012, 01:39 PM   #7
orange crusher
#1 Member
orange crusher's Avatar
My Rig: 87 runner
Very nice! Well done. Love diesel swaps.
87 runner on 42s "bad luck"
orange crusher is offline   Reply With Quote
Old 06-02-2012, 03:12 PM   #8
RickerRicker19
RickerRicker19's Avatar
My Rig: 1998 4runner 4x4
Send a message via AIM to RickerRicker19 Send a message via MSN to RickerRicker19
Looks good man!!
Semper Fidelis
1998 4cyl 5spd 4 Runner
1982 mini 4x4
Slowly learning one repair at a time
RickerRicker19 is online now   Reply With Quote
Old 06-02-2012, 03:52 PM   #9
BBCoffroad
BBCoffroad's Avatar
Originally Posted by lrgrnr View Post
Nice build!
what were you driving?
Old 06-02-2012, 07:50 PM   #10
MandAtaco
MandAtaco's Avatar
Send a message via AIM to MandAtaco
That's amazing, great build!
Just your average ttora backyard engineer.
01 Taco
96 Runner
MandAtaco is offline   Reply With Quote
Old 06-02-2012, 08:21 PM   #11
lrgrnr
lrgrnr's Avatar
Blue '06 Tacoma...
Old 06-03-2012, 07:13 AM   #12
BBCoffroad
BBCoffroad's Avatar
i dont think i saw u there
Old 06-03-2012, 02:00 PM   #13
lrgrnr
lrgrnr's Avatar
I think it was during the Zuwharrie event.
no worries..........I'm sure I'll see you around.
Old 06-04-2012, 11:28 AM   #14
me_tu05
Hawaii's Damage Control
me_tu05's Avatar
My Rig: 86 4rnr 1ton, 1UZ
Nice job. They are stupid simple to wire up.
94 SC300 She boogies
86 4runner turbo diesel swap Now has a 1UZ
me_tu05 is online now   Reply With Quote
Old 06-07-2012, 09:09 AM   #15
BBCoffroad
BBCoffroad's Avatar
been thinkin about getting rid of it how much do you guys think i could get for it mods as fallows
5.5 SAS/rear leaf conversion
long travel front drive shaft
high steer conversion new P/S box not taped.
new T/C/clutch
yukon grizzly locker in rear diff 5.29 F/R gears
bilstien shocks 12''
xrc 8,000 lbs winch
custom bumpers
4xinnovations full roll cage
rear end cut off behind rear doors flat bed in its place
1982 OM617.952 5 cyl turbo diesel swaped with stock tranny and tcase adapted heat still works
120 amp alt/ dual batteries
cj bakini top covering rear cargo area
all guages work except rpm and oil pres auto meter oil pres installed and works
what do you guys think?
Old 06-07-2012, 01:15 PM   #16
marco99trd
marco99trd's Avatar
nice swap, what did the engine cost ya?
89 Reg Cab 22RE
88 $runner
marco99trd is offline   Reply With Quote
Old 06-07-2012, 02:24 PM   #17
Wainiha
My Rig: 2000 Tacoma
new T/C/clutch
xrc 8,000 lbs winch
custom bumpers
You just built it! It looks good to me. Why?
3.4 TRD
ICON C/O
Marlin Clutch
Wainiha is online now   Reply With Quote
Old 06-09-2012, 04:22 AM   #18
me_tu05
me_tu05's Avatar
Because the cool factor wears off when you wheel it and realize it is no better than a 22re.
Old 06-09-2012, 05:00 AM   #19
Wainiha
My Rig: 2000 Tacoma
That's gotta hurt
3.4 TRD
ICON C/O
Marlin Clutch
Old 06-28-2012, 04:29 PM   #20
frorunner
how much do you want for it???
frorunner is offline   Reply With Quote
tons Mr.B Solid Axle Swap Tech 30 10-24-2011 11:40 AM
pictures from a frame swap F22Nrptr Off Topic 9 04-19-2010 06:13 AM
Tons of Tons. Symon623 Classifieds 0 07-09-2008 07:08 AM
2 1/2 tons 01taco4x4 Wanted 4 09-23-2005 07:49 AM
D-cab swap pictures (finally) Deserttaco Early Tacoma Tech 42 08-22-2005 12:09 AM
