Welcome to the TTORA Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. ATTENTION: In an on-going effort to keep this forum spam free, the Forum Admin approves every new account before giving any posting rights to new users. Accounts are normally approved within 24 hours. Sorry for any inconvenience, but verification of every new account is what will continue to keep this forum spam free. |
Thread Tools | Display Modes |
#1 |
After spending hundreds of hours on the forum and sending a ton of PM’s its my turn to try and help someone out. The truck is my DD 97 T100. With the 3” body lift Ball joint spacers and AAL in the rear on 35s I was destroying CV shafts like crazy and bent 2 idler arms.
![]() ![]() After breaking or bending something on every trip I decided it was time to start gathering parts. A huge thanks goes out to Zac at Rustys Off Road and also Josh at Inchworm Gear. Once you deal with companies like those its hard to call anywhere else. Parts List: Front Chevy D44 passanger side drop axle Re-geared to match the rear 4.56 with aussie locker, warn hubs Skys Off Road Full size axle front hanger Rustys Off Road RX300 shocks Trail Gear 47” long 3” lift front leaf springs, shock hoops, 5” shackle, shackle mount (from josh @ inchworm gear) Independent 4x Right side flat top knuckle This is how the front sat the night the swap started. (cell pic sorry)
97 t100 SAS 4.56 aussie front lockright rear 35s My build-http://www.tacomaterritory.com/forum/showthread.php?t=185319 |
#2 |
Since both Cv’s were blown, the idler arm was bent, and the control arm bushings were frozen allowing for no caster adjustment I took out the plasma cutter and went to town.
The front diff with 4.56 gears and aussie locker is still available for sale. It works great and has never given me a problem. After an hour fri night I had the front cut off and was ready to start grinding. ![]() ![]()
#3 |
Saturday a few buddies of mine stopped over to help out. Since the plasma cutter is 20 years old and I never used it before, I left a lot of over hang from what was cut off.
![]() The upper control arm mounts are also a part of the motor mount. I did not want to leave them open so I cut them as flush as I could with a sawzall and made some caps from some 3/16” scrap. ![]() ![]() ![]() I never really saw any rear shackle mounts/setups so I decided to try my own way. I used a piece of 3/16” plate steel about 9” long 5” wide to make the base for the rear shackle mount. The rear mount is a Trail-Gear (from inchworm gear) shackle mount and the gussets were from rustys off road. ![]()
#5 |
i just joined northeast toyota crawlers, i also have a small group of 12 that wheel with us every other week during the summer. i can Pm you a schedule as soon as we line the dates up.
#6 |
I pushed the front hanger as far forward as I could and after double checking everything was straight tacked everything in place.
![]() I couldn’t wait any longer and wanted to see a little flex. Set the truck on its own weight and went up with one lift arm under the axle. I stopped before it got to close to the lift incase it slid off. ![]() I used the pre-made 14” travel shock hoops from Inch worm Gear and Rustys Off Road Rx 300 remote reservoir shocks in the front.
#7 |
After a whole weekend of nonstop work the front end was done and ready for paint. Imho the truck is way too tall for 35s. my plan is to remove the body lift and let the front settle before doing any suspension changes. It rides down the road awesome and has way less body roll then the ifs did. It handles the normal bumps a lot better as well. I did have a problem on my first road trip. The front leaf springs had a lot of play in the hanger and caused a serious death wobble. I made some small spacers a little wider then a washer for each side of the leaf spring bushings. This took up 98% of the play and stopped the death wobble. I am still waiting on a front drive shaft but took some poser shots in my back yard.
#8 |
How come you didn't add any reinforcement plates to the frame? Nice work non the less
2000 Taco Ext. Cab 2.7L, SAS D44 Leaf Sprung and Ford 9" Full widths. Never ending cycle... 38.5's BITCHES! SAS Gathering SAS Build Thread |
#9 |
The T100s, non tacoma trucks, and older 4runners actually had a real frame compared to the tin can the tacomas have for a frame. There is no need for frame plates.
http://toyotaoff-road.com/ Randy 2006 Tacoma x-cab 12" bobbed bed and the usual 3" lift with a locked rear and a lot of broken parts. Dana 44 soon 1992 Chevy C-1500 swapped D60/14bolt 454 and th400 (wrecked it) |
#10 |
thanks.
i had ordered the set from trail gear but they did not line up very well. i am going to make my own soon. once i finish my rear bumper.
#11 | |
#12 |
Old sleepy guy
My Rig: 97 T100 Sas on 36's
I ordered my front driveshaft from Tom Woods, he asked a few questions and shipped it out quick. I swear he started building it when we were talking on the phone, and finished it before we hung up.
I Sas's mine in 2007, still need to frame plate mine, and add under engine cross-member .
Joe P.... My T100: http://www.tacomaterritory.com/forum/showthread.php?t=76817 www.yotaranch.com/home Last edited by Jomentum; 02-20-2012 at 09:24 PM. |
#13 |
Thats where i called for mine. i used the print out sheet they had on-line for the measurements.
#14 |
good job nice and clean sas
1988 4.3cpi v6 full width 4runner 37mtrs duals and a happy owner |
#15 |
Nice Rig!!
#16 |
Did you do any changes to the axel for caster and camber or pinion angle?
Thanks! Truck looks great.
97 T100 37/12.50/15 MTR's on Chevy alloys, bj spacers, 1 inch body lift, lots of trimming Under the knife! I am the toe cutter!Have you seen the night rider! 01 Tundra Stonewell Body ready for shoeing! Last edited by hotshoe; 03-21-2012 at 01:58 PM. |
#17 | |
i ordered 4" shackles from inchworm to drop the height and they should be in monday. from there i will work on the caster and see if i have to turn the knuckles. the camber is also off, the tires lean \-----/ pretty bad. i read about off set ball joints and may try those.
#18 | |
#19 |
mine was pretty flat as well. i will take some before and after pics with the 5" shackles and 6* shims then the 4" with 6* shims. my caster is well past 6* towards the back of the truck so hoping the smaller shackle will fix that
#20 |
Cool, I wanna get it set right before I start messing with the drive shafts. I'm running TG 5" springs front/rear and I'm thinking I will be removing some leaves to drop it some, I'm sure they will settle some.
#21 |
![]() i put on the 4" shackles i had josh at inchworm gear make and i am very happy with how it sits. it fixed my caster problem and realized the camber problem was actually the toe of the tires. with the caster so far back the tires looked \----/ but with the correct caster the toe was way off. tires were facing away from each other. i no longer get a wobble and it steers alot better. it also handles the bumps better.
#22 |
#23 |
Looks good, glad that fixed your problem. Mine sits level right now, but I'm not running a bed out back yet, so no weight. I put the TG 5" shackles on Tuesday and they are way better then the one I made.
#24 |
Finally ordered and installed a front drive shaft from Tom Woods. They made it and shipped it not even 24 hrs after i placed the order. Took her out for a test run and need some help with the steering. With the hubs locked in and the t case in 2wd i cant turn at all. ( it is locked in the front). I also need to fool with the rear suspension more.
#25 |
My Rig: 1995 Toyota T100
Love the truck!! I have a 95 T100 Reg cab and was thinking bout changing the suspension in the front. How much you got into this project approx just on the front end??
#26 |
Thank you. I did the project over time. I just waited until i got good deals and had extra cash. Its really not horrible if you space it. If you want a complete list of parts prices and where i got everything from PM me and i can write a list out.
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Chevy Dana 44, Ford outers, Dana 70u | MandAtaco | Parts/Electronics/Wheels & Tires For Sale | 1 | 10-17-2010 08:56 PM |
| hello t100 here | keenspeed94 | Tell us who you are | 1 | 01-21-2010 01:36 PM |
| Dana 60 Front and Dana 70 Rear Narrowed FLORIDA | apimpdad | Classifieds | 2 | 04-13-2009 08:01 PM |
| Dana 44 and Dana 60 Axles, $50 each | NorCalTRD | Parts/Electronics/Wheels & Tires For Sale | 3 | 05-23-2007 06:48 PM |
| T100 Oil Pan (YES the one you need for a SAS) | DrVic@BallisticFab | Parts/Electronics/Wheels & Tires For Sale | 6 | 07-26-2006 12:04 PM |
