Sponsored Ad
Go Back   TTORA Forum > General Tech > Suspension
Thread Tools Display Modes
Old 05-28-2008, 11:20 AM   #1
Jeffbro
Default Pull leafs from an Alcan pack
Hey so I bought an alcan leaf pack about 6 months ago and was expecting it to settle out alot more than it actually has. With a load of about 700lbs the truck will sit level but I don't have 700lbs in the back of my truck most of the time. Would it be bad for the leaf pack to pull a few leafs out so it will settle a little more. Also should I pull the smaller ones or take one from the top and one from the bottom? anyone?
- 95 RegCab 4x4
- 88' Rex
Jeffbro is offline   Reply With Quote
Old 05-28-2008, 11:38 AM   #2
02tacotoy
02tacotoy's Avatar
Default
I did this with my all-pro 5" leaf pack. remove the second to smallest one, and see if you like it. you dont really want to mess with the longer leafs and avoid the mini leaf that mounts the pack on the axle.
2002 ex cab taco
Bilstein 5100's and 5125s
5spd v6 4x4, e locker+cheap tricks
2004 double cab tundra
limited4x4
02tacotoy is offline   Reply With Quote
Old 05-28-2008, 02:42 PM   #3
devinsixtyseven
devinsixtyseven's Avatar
Default
I had my Alcans built for 500# and it took a while for them to settle in.
Put the 700# load in there, and leave it in for a few weeks...sandbags, water, gym weights, whatever. Once I did that with mine (actually it was a 1200 mile road trip with 1000# in the bed plus tongue weight of the trailer), they were pretty good. For the first few months after I got them and before I broke them in they were stupid stiff.
Load it up, forget about it for a while, go cycle the suspension in the dirt, they're not gonna sag much, but they will break in if that makes any sense.
If you have a 1st-gen Taco you should be able to run GVW 6500# with about a 50/50 weight distro, offroad, without breaking anything (unless you trade skinny pedal for skill). Go do that a few runs, they'll feel better!
devinsixtyseven is offline   Reply With Quote
Old 05-29-2008, 10:30 PM   #4
joel
joel's Avatar
Default
I contacted Alcan a while back about this exact situation and I was told to remove the leaf right after the one with the binders... I did and it seems to work real well so far... I have been flexing and dumping them HARD for the last few weekends without any negative results.
Later
Joel
FOR SALE
Built 95.5, std. cab, Manual, 3.4 v6 Tacoma
http://www.tacomaterritory.com/forum...d.php?t=146226
joel is offline   Reply With Quote
Old 05-30-2008, 07:37 AM   #5
Signalprick
Signalprick's Avatar
Default
HMMM? I have had the Alcan 5 leaf pack w/ overload made for Wheelers in for about 4 months now and they have already "settled" nearly 3/4" lower than the front which has OME 881's. I was thinking about calling Alcan and getting a AAL made to bring the rear up another 1" but maybe one of you guys could/would sell me the leaves you take out of your pack? PM me if anyone is interested?
1999 TACOMA W/ COOPER ST's & OME
MEMBER BRS LOCAL 20
FORMER SGT INFANTRY MARINE
Signalprick is offline   Reply With Quote
Old 05-31-2008, 10:28 PM   #6
JJackson
JJackson's Avatar
Default
I was wondering the same thing, had Alcan make me a spring pack that was rated 200lbs over stock for carting the quad around without sag. The are certainly stiff (just put them on last week) we toyed around with the idea of pulling one of the leaves (think my pack has 8 or 9). I did load the quad in and going to keep it there this week to see if they soften up a bit first.
84 Toyota Crawler
98 4Runner Limited 4x4 e-locker
JJackson is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
Alcan leaf pack problem Jeffbro Early Tacoma Tech 41 03-21-2012 08:41 AM
The plan: Alcan 8 leaf spring pack and Bilstein 5100 bdrunner Suspension 33 11-02-2007 12:27 PM
ALCAN 8 Leaf pack feeler, I need your leafs.... Cruznlife1 Parts/Electronics/Wheels & Tires For Sale 5 03-19-2007 08:37 AM
Alcan AAL's & Stock Tacoma Leafs FS Chargedtaco01 Parts/Electronics/Wheels & Tires For Sale 8 12-10-2006 06:25 PM
Just Ordered Alcan Leafs eNnihilate Suspension 7 07-26-2006 08:08 PM
Sponsored Ad
Privacy Policy
Links monetized by VigLink
