TTORA Forum
Sponsored Ad
Go Back   TTORA Forum > TTORA Chapter Forums > Official TTORA Chapter Forums > Arizona Chapter > Tech/Tricks
User Name
Thread Tools Display Modes
Old 05-30-2008, 03:24 PM   #1
howyadoin
howyadoin's Avatar
Default Pimp my buggy...
So I have decided to do a fairly substantial rehab project on my ugly pos junk buggy for the next few weeks. I have a pretty good list of items that I'm planning and seem to keep coming up with more every day. Here is a quick summary of the list as it stands right now:
1. Stretch wheelbase approx. 5". I am currently at 105" and want to be around 110".
2. Adjust rear geometry in the rear to add substantially more anti-squat. I'm aiming for about 120% which is considered really high, but I have two friends who run 130% plus and probably have the two of the best climbing rigs in the nation.
3. Along with my geometry adjustments, I will be eliminating my rear wishbone and going to a true 4 link to hopefully eliminate a little rear steer.
4. Replace all of my lowers with 2" 7075 solid and replace all joints with 1.25" heims.
5. Redo my uppers with 1.5" .250 wall DOM, mostly just to accomodate the stretch.
6. Swapping out my seats to go with a tighter fit similar to my old buggy's Mastercrafts. Simply personal preference.
7. Redoing my Atlas II cross member so that it is no longer hard mounted to my skid plate.
8. Redoing my skid plate to give the Atlas II a little more breathing room and make room for the new cross member.
9. Sleeve both lower side tubes with 2" .120 wall DOM since both of those tubes are completely FUBAR'd.
10. Cut off existing truss and rebuild on my 14 bolt to accomodate 4 link.
11. Cut off and rebuild my skid plate for the hydro ram. The existing one is perhaps the biggest fabrication abortion I have ever witnessed.
12. Remounting my fuel cell further forward to increase my cargo (beer cooler) capacity!
13. Remounting my batter in order to increase said cargo capacity. May also switch back to an Oddysey?
14. Remount my computer and wiring higher up in dash and make a kick plate to protect from passenger's feet. Or just make it a one seater?
15. Remove my main kill switch since it is a bit redundant to have 3.
16. Reroute all fuel lines to tidy things up after moving fuel cell.
17. Remove about 10 feet of cable after removing main kill switch.
18. Getting GLO diff covers front and rear and shaving them to match my housings.
19. Tom Woods is building me new driveshaft front and rear to accomodate the stretch. I will rebuild the existing ones (probably won't have to touch the front, very long travel) for spares.
20. Reroute brake lines, especially in the rear to clean things up and accomodate the stretch.
21. Fix my alternator that took a shiate at AZRocks so that I don't have to manually control my charge.
22. Clean up my hydro lines and fix a small leak that I have.
23. Fix my brake fluid leak.
24. Install my ARP kingpin stud kit.
25. Remount my trans cooler mount after moving for more storage capacity.
26. Double beadlock both rears to eliminate my "burping" issue.
27. Paint the entire chassis with my "jethro powdercoat". (home depot hammered paint)
28. Make new side panels and redo lower cowl area.
29. Remove some tubing on the rear section and tie into shock towers.
30. Redoing exhaust to make room for stretch.
I'm sure there's more that I'm forgetting, but that should pretty much cover it for today...wish me luck!
AZ Undertakers
Originally Posted by badbronco
"tacomas are for pussies. had to say it"
howyadoin is offline   Reply With Quote
Old 05-30-2008, 03:28 PM   #2
FAUX X 4
Takama's-N-Shit!
FAUX X 4's Avatar
Default
You should be done by the end of the weekend........... what's on the list for next week?
I Break for Rocks.
FAUX X 4 is offline   Reply With Quote
Old 05-30-2008, 03:30 PM   #3
howyadoin
howyadoin's Avatar
Default
Here are a couple pics of the buggy for you that don't know it along with a couple quick "teardown" pics...
AZ Undertakers
Old 05-30-2008, 03:33 PM   #4
howyadoin
howyadoin's Avatar
Default
I'm going wheelin' this weekend! I'll be ridin' biatch, but I'll probably shoot a little video footage to keep myself entertained during the down time.
AZ Undertakers
Old 05-30-2008, 03:35 PM   #5
FAUX X 4
Takama's-N-Shit!
FAUX X 4's Avatar
Default
Where you headed?
I Break for Rocks.
Old 05-30-2008, 03:37 PM   #6
howyadoin
howyadoin's Avatar
Default
Where you headed?
A berry, berry secret location to look for some new stuff to break my "fresh rebuild" on in the fall. OK, going to BB a few notches west of "Saw" and east of "Mental Midget" , does that help?
AZ Undertakers
Old 05-30-2008, 03:39 PM   #7
FAUX X 4
Takama's-N-Shit!
FAUX X 4's Avatar
Default
A berry, berry secret location to look for some new stuff to break my "fresh rebuild" on in the fall. OK, going to BB a few notches north of Saw, does that help?
Yup!
Make sure Barry doesn't ask you to hold his Berry's!
Looks good so far, but you cut off the pretty part!
I Break for Rocks.
Old 05-30-2008, 04:15 PM   #8
howyadoin
howyadoin's Avatar
Default
Yup!
I will definately leave Barry's berrys alone. There is no pretty part on my buggy, never has been, never will be! I don't speak "bling"! Here's my new seat, what do you think?
AZ Undertakers
Old 05-30-2008, 04:17 PM   #9
FAUX X 4
Takama's-N-Shit!
FAUX X 4's Avatar
Default
Looks good! ........ simple and clean!
I Break for Rocks.
Old 05-30-2008, 04:21 PM   #10
howyadoin
howyadoin's Avatar
Default
You say simple and clean...I say rode hard and put away wet...many times!
AZ Undertakers
Old 05-30-2008, 04:27 PM   #11
BOVADS
BOVADS's Avatar
Default
Looks about as comfortable as my factory tacoma seats
thing should be sweet after "improvements"
nice gay-rage by the way
BOVADS is offline   Reply With Quote
Old 05-30-2008, 04:28 PM   #12
FAUX X 4
Takama's-N-Shit!
FAUX X 4's Avatar
Default
Same difference........... Remember, you can get a good look at a butchers ass if you're looking in the right hole when you ..........NO, wait...... I mean, One man's junk has another girls STD........... no wait........... WHAT WAS THE TOPIC AGAIN?
Weren't we talking about Buggies?
I Break for Rocks.
Old 05-30-2008, 05:59 PM   #13
howyadoin
howyadoin's Avatar
Default
I realize I could "get a good look at a steak by sticking my head up a bull's ass, but I'd definately rather take the butcher's word".
AZ Undertakers
Old 05-30-2008, 06:01 PM   #14
FAUX X 4
Takama's-N-Shit!
FAUX X 4's Avatar
Default
Very good!.......... somebody else has seen Tommyboy a time or 3!
Is the Buggy done yet?
I Break for Rocks.
Old 06-02-2008, 02:49 PM   #15
FAUX X 4
Takama's-N-Shit!
FAUX X 4's Avatar
Default
Updates???
I Break for Rocks.
Old 06-02-2008, 03:00 PM   #16
Kaistie
Desert Turtle
Kaistie's Avatar
Default
Yeah, WTF lazy ass! We all know you are not working your day job, so.......?
Pictures:
Kaistie is offline   Reply With Quote
Old 06-02-2008, 03:04 PM   #17
howyadoin
howyadoin's Avatar
Default
I could post a pic if you want me to, but it looks exactly the same! I'll try to get some done on it tonight, right now I'm just too busy web-wheelin' to be bothered?
AZ Undertakers
Old 06-02-2008, 03:08 PM   #18
FAUX X 4
Takama's-N-Shit!
FAUX X 4's Avatar
Default
You mean to tell me, you would actually procrastinate working on it by taking pictures of the nothing you got done?
I Break for Rocks.
Old 06-02-2008, 03:33 PM   #19
howyadoin
howyadoin's Avatar
Default
Absolutely, I am always looking for a reason to "not work"!
AZ Undertakers
Old 06-02-2008, 07:35 PM   #20
lvanst
lvanst's Avatar
Default
Nothing could be something, considering the number of times I've seen something turn out to be nothing...
Life's greatest teachers are pain and repetition...
1985 4Runner, 4 linked F&R, Exo'd, dual t-cases, locked, 37" MTRs
http://www.photobucket.com/albums/gg257/lvanst
Never pay Racer Off-Road for anything!
lvanst is offline   Reply With Quote
Old 06-02-2008, 08:10 PM   #21
SHNIPE
SHNIPE's Avatar
Send a message via MSN to SHNIPE Send a message via Yahoo to SHNIPE
Default
Needs dimples for strength!
Dennis
I drove a Jeep
SHNIPE is offline   Reply With Quote
Old 06-03-2008, 06:28 PM   #22
howyadoin
howyadoin's Avatar
Default
Just wanted to give everyone an update...I have removed the seat. I needed a cutting board?
AZ Undertakers
Old 06-04-2008, 07:28 PM   #23
lvanst
lvanst's Avatar
Default
Well, at least you got around to putting the thread in the right forum...
Old 06-04-2008, 08:10 PM   #24
MerMan
MerMan's Avatar
Default
Great progress!!.... and you get an "F":
AZ Undertakers
MerMan is offline   Reply With Quote
Old 06-05-2008, 07:47 PM   #25
howyadoin
howyadoin's Avatar
Default
What are you talking about? I spent over $2k today just on rod ends, misalignment spacers, jam nuts, truss materials, tabs, gussets, and a set of seats! I'm making some fawking progress...I have to drink alot to really set up my geometry, but I think I'm pretty much there now!
I'm going to Advanced tomorrow for a stack o' DOM...that's gonna hurt!
AZ Undertakers
Old 06-05-2008, 07:48 PM   #26
howyadoin
howyadoin's Avatar
Default
BTW, here's my new rims....I'm blingin'!!!
AZ Undertakers
Old 06-05-2008, 09:49 PM   #27
lvanst
lvanst's Avatar
Default
Old 06-05-2008, 10:40 PM   #28
howyadoin
howyadoin's Avatar
Default
OK guys, here's my progress...I'm almost done and I think it's looking really good!
AZ Undertakers
Old 06-06-2008, 12:28 AM   #29
crazycarwes
Default
Dude that is awesome! I am so bringing sg back for a re work! Save all the cool shit for yourself!
crazycarwes is offline   Reply With Quote
Old 06-06-2008, 11:33 AM   #30
zanyzonies
zanyzonies's Avatar
My Rig: 2010
Default
geeso!,,, those look really "Bling". maybe spinners?!
Originally Posted by lvanst View Post
Come on! you know you want a set for Elmo!
"Bent & Broken"
zanyzonies is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
Anyone want to pimp their H2 wheels? DrVic@BallisticFab Tires/Wheels 3 03-09-2006 10:02 PM
Un Pimp My Ride zosimov21 Off Topic 12 03-07-2006 11:04 PM
Un-pimp Your Ride weirdmexicantaco Off Topic 8 02-28-2006 11:50 AM
pimp my bride absolut taco Off Topic 6 09-16-2005 02:11 PM
This New Forum Is Pimp jimmytbud7 Off Topic 0 12-06-2004 01:04 PM
Sponsored Ad
Privacy Policy
Links monetized by VigLink
