Sponsored Ad
Go Back   TTORA Forum > New Members Area > Newbie Tech
Thread Tools Display Modes
Old 09-11-2008, 01:52 PM   #1
DreadyRider
Default Rhino line the floor pans.
I took out the carpets and I want to eventually Rhino line it. I have a couple of problem though. When I spray out the truck the water does really run out of the drain holes well. So I want to pitch it so it flows out better, any suggestions on materials to use? Also I have a heat problem on the passenger side so I also need to insulate the floor pans first. I was thinking about just using some spray foam and then smoothing it all out and then coating it with fiberglass but I don't know anything about how to use it.
Any and all suggestions would be much appreciated.
A vinyl bench seat would be great too.
DreadyRider is offline   Reply With Quote
Old 09-11-2008, 01:55 PM   #2
StealthTaco
StealthTaco's Avatar
Send a message via AIM to StealthTaco
Default
Well you could use the BFH to get your flow better.
Won't the rhino line act as an insulator? How hot is it getting? Like uncomfortable to touch or just warm?
2001 V6 TRD, OME 882 w/ N91s, Daystar 1", TLT mod, AOR Shackles, 1" RB Body, ARB Bumper, Warn Winch, Hella FF75, 4.88 yukons, K&N FIPK, Safari Snorkle, 35x12.50R15, Wheelers 15" Black Wheels
http://s166.photobucket.com/albums/u...se2002/Tacoma/
StealthTaco is offline   Reply With Quote
Old 09-11-2008, 07:19 PM   #3
DreadyRider
Default
what is the bfh? And the heat is hot and warms up the whole passenger seat. I was thinking of covering the whole floor with heat tape first.
Old 09-11-2008, 07:28 PM   #4
pirateblktaco
pirateblktaco's Avatar
My Rig: 2000 Toyota Tacoma
Send a message via AIM to pirateblktaco
Default
Originally Posted by DreadyRider View Post
what is the bfh?
Its a Big Fuckin Hammer! should do the trick for your drain problem
FLAT DESERT TAN 2000 XTDCAB TRD 4X4
-Tuff Country 5 inch suspension
-SAW 2.5'S with 14" 650# king coils
-Factory 16x8 "baja" wheels 285/75/16 DEFNITY DAKOTA M/T
-grey wire mod
-Deckplate mod
-2001 center console
-Mercer Fabrication square sliders welded on
-custom heavy duty front plate winch bumper
KHYBER PASS MULE BUILD THREAD
pirateblktaco is offline   Reply With Quote
Old 09-11-2008, 07:41 PM   #5
John Carter
Default
Are you missing a heat shield on your exhaust???
Expanding foam is not easy to smooth out. Even if you drag something across the wet surface to level it, bubbles will come here and there. Misting it with water helps to speed up the curing, but it will not be perfectly flat.
John Carter is offline   Reply With Quote
Old 09-11-2008, 11:20 PM   #6
STEPCHILD
Default
Hopefully it only gets hot on pass. side then who cares.Expanding foam sucks trying to use worse than gorilla snot (3m weatherstrip).
'04 TACO 2.7, 5 SPD, XTRA CAB, SAS, 4.88'S LOCKED F/R, D44 WAGGY, WARN 8000, IF IT'S FIXED BREAK IT, IF IT'S BROKE FIX IT
STEPCHILD is offline   Reply With Quote
Old 09-12-2008, 03:54 AM   #7
Wetnwild
Default
Go to the source of the heat problem and fix that first. If it doesn't have a heat shield, then replace it or make one. If you decide to reinstall the carpet, then installing "Dynamat" (www.dynamat.com) under the carpet will also help.
Wetnwild is offline   Reply With Quote
Old 09-12-2008, 11:20 AM   #8
DreadyRider
Default
The heat sheild is there it's just not enough. The reason I took out the carpet in the first place was because my truck always looked like a potato farm. I go muddin almost every weekend and I want to be able to spray it out easily and not clean it for hours on end.
Also with the BFH, have you seen the floor pans bare? It would take forever to beat it out, there's ridges 2" wide every 2". As far as the spray foam goes, don't they sell those heat wires you can just pull through the foam. Then I could sand it down. I don't know, if this is a stupid idea tell me.
Old 09-12-2008, 12:49 PM   #9
Wetnwild
Default
I would say no to the spray foam and I would install a heat shield that would be large enough to do the job of reducing the heat. Have you looked into the do-it -yourself type of roll-on liner (Herculiner, etc.)?
Old 09-12-2008, 03:25 PM   #10
DreadyRider
Default
Is there a special metal that is used for a heat sheild? A bunch of my buddies have done it to there vehicles.
Old 09-15-2008, 12:33 PM   #11
DreadyRider
Default
Does anybody know what they use to make surfboards?
Old 09-15-2008, 12:42 PM   #12
drabnor
Home Grown Tacoma
drabnor's Avatar
My Rig: 2000 Tacoma
Default
um fiberglass...
id advise against rhino lining or line-x ing any part of the interior of the cab, think about what would happen if the stuff caught fire...
i recently had the opportunity to cut up my bed which was lined with line-x, at first i was using a cutting wheel on my grinder and it would heat up and start to burn the line-x, the fumes coming off this shiot were UNBELIEVABLY toxic! i was in an open area with a face shield on and when just a bit of the fumes would get under the shield id have to stop what i was doing and get the fuck out of there.
id imagine that if you had a fire in the cab with the windows up you would be dead before you could even get the truck to stop or the windows to go down...
TBH IE division
Originally Posted by Scuba View Post
Did you read any part of the reply that just took me 10 mins to search for and write?
Originally Posted by miguelitro View Post
I know I hate having to poke my wire into such a tight hole...
mike
drabnor is offline   Reply With Quote
Old 09-15-2008, 07:54 PM   #13
miguelitro
miguelitro's Avatar
Default
not to mention that that spray foam releases mustard gas when it ignites.
Team Bad Habits
Don't own one yet but there is nothing but diesel cruisers and tacos down here.
"I feel sorry for people who don't drink. When they wake up in the morning, that's as good as they're going to feel all day. " ~Frank Sinatra
miguelitro is offline   Reply With Quote
Old 09-20-2008, 02:15 PM   #14
DreadyRider
Default
Thanks for the burning info. I didn't know that about either of those products.
Old 09-20-2008, 08:02 PM   #15
maulcruiser
maulcruiser's Avatar
Default
I'd suggest wrapping your exhaust in that heat wrap they sell for headers, or making a heat shield and putting that reflective HVAC tape on one side of it. As for the floorboards, I'd take some thin gauge sheetmetal and make a false floor for it. Be sure to put plenty of spot welds throughout the surface so that it won't rattle, then go back and fill the voids with expansion foam. That's just an idea for ya...
Ash
Wilmington Fire Dept.
'07 DC TRD OR Taco, OME HD suspension, 285/75/16 BFG Rugged Terrains, ARB bumper, Warn M8000, PIAA fogs, Overkill Offroad rear bumper, BHLM
maulcruiser is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
Rhino vs. Line-x Aurelius Exterior/Paint/Body Panel Modifications 52 11-29-2007 01:00 PM
Rhino-line paint joeonthego717 Exterior/Paint/Body Panel Modifications 35 07-30-2007 11:07 AM
high steer and new floor pans Spacecwboy Pickup/Early 4Runner Tech 2 05-30-2007 06:18 AM
Camo or Rhino Line the b!tch? RyanAndJenn Exterior/Paint/Body Panel Modifications 23 10-27-2006 12:24 PM
Line-X vs Rhino Coat? TacoMike82 Exterior/Paint/Body Panel Modifications 24 03-01-2006 04:24 PM
Sponsored Ad
Privacy Policy
Links monetized by VigLink
