Go Back   TTORA Forum > Rock Crawling Tech > Rock Buggy/Truggy Build Ups
Thread Tools Display Modes
Old 09-20-2008, 12:26 AM   #1
chris85053
chris85053's Avatar
Default 3 link options
am trying to find a good 3 link set up.. just seening whats stronger using a cross member or mounting off of frame.. opinons what be cool.. and pics whould be even better.. thanks
chris85053 is offline   Reply With Quote
Old 09-20-2008, 08:27 AM   #2
awsumdc
awsumdc's Avatar
Default
go to these links to see a three link system that goes to the frame. We have done them on two early model Taco's, a late model Taco and an FJ cruiser. Strong as hell and awesome flex with good road manners.
http://rides.webshots.com/album/378870315SnHRiA
http://good-times.webshots.com/album/564203253zyajmq
http://www.villagephotos.com/members...der_id=2024806
http://www.ttora.com/forum/showthread.php?t=72522
Here are some pictures for you of the trucks. They all have the same three link system on them. The FJ nd the older Taco use's Johny Joints at both ends of the links and the '05 Taco use's huge 11/4" hiem joints at the axle end and johny joints at the frame on the links.
They all three use different front axles for the swap. The '02 Taco use's the tried and true Dana 44 out of a Jeep Wagoneer.
The Fj Cruiser use's an awesome Diamond axle housing with an FJ80 high pinion center section with elocker.
And the '05 Taco use's a Massive Currie Enterprise's Rock Jock 60 with 35 spline axles 5.38 gears and ford F-450 1 ton knuckles and unit bearings. Super Super strong.
Three different axles on three different trucks that all use the same three link system.
'05 "SAC" Double Cab TRD Sport 4x4 with Marlin Crawler "Taco" Box and a bunch of other stuff.
Linked, Locked & Large!
"THE BEAST"
AKA "THE BIG SEXY"
Wyatt Scott
3.4 auto crawler install
Installing an FJ Case into an 05+ Tacoma
My Build thread. Building "The Beast"
GOT SAC?
awsumdc is offline   Reply With Quote
Old 09-20-2008, 04:40 PM   #3
BOVADS
BOVADS's Avatar
Default
Originally Posted by awsumdc View Post
just saw this pic, nice pic, and i know exactly where it is
BOVADS is offline   Reply With Quote
Old 09-23-2008, 08:33 AM   #4
Symon623
Symon623's Avatar
Default
Chris, here are some pics of my set up. I went off the frame, sacrificed some ground clearence for streetability. The ground clearence really hasn't been an issue.
Here you can see the passenger side frame mount and the upper link mount bolt through the frame;
Drivers side;
All 3;
More pics are here;
http://s78.photobucket.com/albums/j1...ota/?start=all
If you do a crossmember then it has to be removable and then you have to unhook the front suspension for trans removal????
Good luck.
Sy
85 Syota, 6.0/700r4/203/300/60's/Detroits/37 MTRk's/§XX§
06 FZ1, commuter
High Country Renegades
Symon623 is offline   Reply With Quote
Old 09-24-2008, 11:01 PM   #5
chris85053
chris85053's Avatar
Default
anyone out there runs a upper link on the pass side frame with out hitting exhaust?
Old 09-25-2008, 07:01 PM   #6
awsumdc
awsumdc's Avatar
Default
Yep. All of our top links are on the passenger side at the frame and none hit the exaust. I'll try to get some pics up fr you.
"THE BEAST"
AKA "THE BIG SEXY"
Wyatt Scott
GOT SAC?
Old 09-25-2008, 11:28 PM   #7
chris85053
chris85053's Avatar
Default
how should the upper link sit? try to get it level? or at same plane as your lowers?
Old 09-26-2008, 07:33 AM   #8
awsumdc
awsumdc's Avatar
Default
My top link is almost level with the bottom links. This weekend I'll get some numbers for you so you can have an idea of how we set it up.
"THE BEAST"
AKA "THE BIG SEXY"
Wyatt Scott
GOT SAC?
Old 09-26-2008, 11:21 AM   #9
chris85053
chris85053's Avatar
Default
ok cool thanks
Old 10-14-2008, 07:10 PM   #10
Hutch98
Hutch98's Avatar
Default
Possible for some more pics of the pass side??
"Beer is proof that god loves us and wants us to be happy" Benjamin franklin
Hutch98 is offline   Reply With Quote
Old 10-14-2008, 08:34 PM   #11
awsumdc
awsumdc's Avatar
Default
Sorry... ended up busy that weekend. I'll pm you my number. Call me saturady and I'll get some pictures of mine and the '02 Tacoma for you.
"THE BEAST"
AKA "THE BIG SEXY"
Wyatt Scott
GOT SAC?
Old 10-14-2008, 08:37 PM   #12
chris85053
chris85053's Avatar
Default
ok cool .. thanks alot...
Old 11-03-2008, 10:42 AM   #13
awsumdc
awsumdc's Avatar
Default
Here are some of the pictures from Dans Three link.
"THE BEAST"
AKA "THE BIG SEXY"
Wyatt Scott
GOT SAC?
You may not post new threads
You may not post replies
Forum Jump
4 Link and 3 Link kit Progress thread DrVic@BallisticFab Suspension 57 10-26-2009 07:37 PM
Link ? ? roll-bar Bob Early Tacoma Tech 3 12-01-2006 08:36 AM
3 link upper link placement roktaco Solid Axle Swap Tech 2 11-25-2005 09:32 PM
4 Link. Factor Suspension 19 09-27-2005 12:35 AM
So how come there is no link Dick Foster News/Error Reporting/Suggestions/Help 4 08-02-2005 04:51 PM
Privacy Policy
Links monetized by VigLink
