#451 |
inttora
![]() Join Date: Feb 2007
yeah yeah, still doable with space and tools and a manual. and some
2001 tacoma 2.7 5sp. with some ![]() ![]() amsoil dealer |
#452 |
My Rig: 2005 TACOMA DCSB
Yeah looks like a quick couple hour job to me...lol
Blue Ribbon Coalition #4847 '05 Tacoma DCSB, 35/12.5/17 MTR's, Rear Disc Brakes, ARB's F/R, Fox C/O's & Airbumps up front w/ All-Pro LT, 14" 7100 resi's/63" Chevies in back, full tube bed, Hella 500 w/ HID conversion, XRC 8000# winch, Dual MV50 On-board air ![]() '02 Tacoma DCSB, OME 881's, Dakars, and Nitrochargers Former InTTORA President - 2009-11 |
#453 |
It does look scary, but I have done many dirtbike transmissions and you only have to take apart the shaft that has the problem. The other shafts can stay in one peice and just set aside. I am not saying it is easy to get it back together you just need more then two hands to hold things in place.
Brian (aka B Squared) 1993 4Runner 2 inch OME lift springs in rear 1.5 inch ball joint spacers loc rite rear locker 4XInnovation sliders 4XInnovation front bumper all pro rear bumper 33 X 10.50 TSL Warn Manual Hubs |
#454 |
Brian
In no particular order..........
- Brake MC swap Hardline extensions Secure old reservoir and plug hole,(now used just for clutch) - limit straps just bolt onto front side of upper and lower coilover mount bolts - trim t-case crossmember trim out ¼” of tunnel portion that goes over front DS - replace rear DS center support bearing hardest part should be removal an re-install of u-joint - belly skid to protect t-case and exhaust 2 to 3 support beams across with 1 or 2 supports between make small dip for t-case and make sure it clears the exhaust make it bolt-up to to the bottom of frame rail (so support beams will only butt up against the inside edge ) - shorten rear bumpstops and make a boxed in support for bumpstop instead of just pipe. The Big Two (that have a good chance of not happening): -get the front 4.88's installed -get 36-38" tires . |
#455 | |
Brian
Yeah...amazing how priorities change when you live in Cincy and get 3" of snow....then realize that they dont plow streets that well here. Just ordered the install kit and hopefully will have the gears installed by the time i get back from xmas vacation. |
#456 |
Brian
rear locker isnt working...again. If the locker is indeed toast, I think it might be time to get rid of the truck....im tired of this shit.
#457 |
What kind of locker? MY lockright lasted a few weeks...its welded up right now...
#458 |
Brian
the e-locker, unless it magically starts working again....im doing the MC swap, DS center support bearing change then hopefully by the end of the summer itll be traded in.
#459 |
Are you reading this?
![]() My Rig: 1989 Toy
What all are you having troubles with?
Trail truck: 89 Toy extra cab, stock
Current:2012 Ram 1500 Express, Hemi, regular cab (SOLD)2009 Tacoma Regular Cab ICON 2.5,All pro uca, 4.88's, ARB's f/r, Bentup brand front bumper, high clearance rear, sliders, etc. |
#460 |
sounds like you need to get out on a trail...
#461 |
Brian
its time to face the truth...i havent been wheeling in two years, my truck is only 90% "done", i work for the EPA & i dont make enough money to properly develop my truck. Its depressing to walk out to a vehicle everyday that has at least one thing wrong with it. Maybe ill pick up wheeling again after i get settled into a real job and life, but at this point im traveling WAY too much (ive already put 20,000 miles on my SAS) and have more important things to spend my hard earned money on.
#462 |
Brian
the steering linkage still sucks and needs to be redone DS support bearing Master cylinder needs to be swapped i need larger tires so im not driving 60 on the freeway with 4.88's my rear locker just shit out on me....again the rear springs need to be properly done.....or just link the rear with a 3-link 02 sensors belly skid crossmember needs to be trimmed to clear the front DS at full stuff ...thats alot of stuff for no funds and no garage. |
#463 |
Well if you trade it in, I'll trade ya bumpers
#464 |
H-O-L-Y-------S-H-I-T-H-H-A-A
![]() My Rig: 1997 Toyota Tacoma
Brian, the last thing I want to do is be the first one to tell you not to do something, but I am also in the same shoes you are. You know when the last time I went wheeling (behind the wheel) was because you were with me.
I have felt on many occasions such as you do now. In fact my recent bout was last week. But Momma Bear is good about talking me out of getting rid of the truck and I am thankful. With that being said, let me put a spin to your reasoning so to speak. Right now, with the winter months, it is easy to get discouraged about everything in life, especially since we are from the same part of the country, where summer is perpetual. But once the weather warms up and you are able to spend some more quality time with the truck, (money or none) you will have a brighter look at the final outcome. IF that was not the case do you think I would have stuck with my junk as long as I have? I agree you do a lot of traveling but maybe if you can nurse the truck along until funds increase, you could buy a d.d. that will also help your outlook. just some thoughts to hopefully get you thinking. We need to keep you around because you are definitely a strong and solid cog to our little TTORA machine we are trying to build up in these parts.
BEAR OVERKILL IS AN UNDERRATED ACHIEVEMENT Originally Posted by abbott … remember, in the world of cars and trucks, its not cubic inches, its cubic dollars. GO SPURS GO!!!!
#465 |
Brian
well thankyou for trying to talk me out of it. I seem to have a knack for knowing when i need to cut bait and live to fight another day...and this is that time. I need to get my life in order first. ill still be around and i will always help others do quality fab work (especially utlilizing the lessons learned from my mistakes) but i have to do the right thing at this point. There is no shame in trying something and it not working out. A number of unfortunate events occured and i have to work with what i have...maybe ill be back later after a few years...maybe not...maybe ill pick up a new (cheaper) hobby.
btw, the shop tells me that the gears are done. |
#466 | |
My Rig: 1985 Pickup
~ Todd 85 ex. cab with the usual stuff on 38's 01 Dodge Ram 2500 w/ a Cummins.....Tow rig |
#467 |
Brian
blue book is 14,000
ill probably start around 9,000-10,000 |
#468 |
Did you compare N.A.D.A to Kelly? I have seen some big differences between the two as the cubs have done their car shopping as of recent.
Unfortunately what we view as improvements by replacing the front suspension, the car market normally views it as depreciating the value of the trucks. But that is stating the obvious as you have already started with an overall lower price. Any idea on when you might replace it with another trail rig?
#469 |
Brian
Probably not for awhile.
The price i started at is exactly that...a starting point. I wont be suprised by what offers i get. |
#470 |
Well anyway it is sliced up, it still sucks! just keep in touch and let us know what is going on and if you ever need anything.
#471 |
I just wanna see the finished product before you sell it! (In other words...hold on to it
#472 |
Moderator
My Rig: FJC and tube buggy
hey Brinner i'm here from your past
do you still have the dent in your tailgate from my hand at Harlan a few years back? I'm with Bear on this one at this point at least it's drivable. if anyone understands the problems your facing right now its me and Bear. The last time my heep of s*&% was on a trail for longer than 10 MINUTES without breaking was in early 2007. last April when I took it to Harlan and it broke on the graval road to the trail i was ready to lose it on the way back home. ( for the record that's 9 hrs down, sleep 5 hrs, 10 MINUTES on the trail, 9 hrs drive home) I quit the hobby and was done PERIOD. 2 months ago i was ready to cut it into tiny little pieces and put it in trash cans. 1 month ago i was going to sell the whole damn thing like you. Now i'm going to fix it. I told my dad it was all his after I put in a new clutch and new fuel lines. I've already traded my 2 sets of wheels and tires for 2 sets of toy axles and i'm planning my next buggy. I guess what my long winded ass is trying to say is that my recomendation is to forget about the offroading portion of anything right now for 6 mos, keep the truck, then step back and look at it with a little more clarity and all the work you've done and come to far to quit now. Besides....."My dad is a TV repair man. He's got an ultimate set of tools. I can fix it." "You can't fix this car Spicoli" "I can fix it" that quote is for you later Dave
"Yes we play both kinds of music....Country AND Western" "Your weemon, how much for your weemon" |
#473 |
uuuh! uuuuh! can I play? can I play? I know the answer!
oh and BTW! that is a gross avitar!
#474 |
Brian
center driveshaft support bearing replaced without too much incident. Just coaxing with two hammers at one. Cut the old one off.
#475 |
Brian
#476 |
inttora
i vote you park it in my driveway and buy a 2000$ car to drive around
#477 |
Moderator
[/quote]If you want I can change it to the pic of my right leg with 42 staples in it Later
#478 |
Brian
#479 |
River Rat
Haven't really been in town too much to work on her, but I put some new shoes on. I've also been slowly sanding the rust and painting it back to black.
![]() ![]() I'm heading to a school in Indiana for 5 weeks.....so no more updates for a bit. Next up is some fiberglass fenders / softopper campershell.
05 Taco - SAC'd HPD44 - F.O.A. Coilovers - Armored and Locked. 99 Cummins - Workin towards 1,000lbs Torque 05 GSXR 750 - 20th Anniversary - My Coffin I'm Brown And I will Rule The World One Day. |
#480 |
Looks good. Glad to see it is still progressing. Hopefully we can meet up and wheel with you soon!
| Thread Tools | |
| Display Modes | |
| New Project | KLP | Tell us who you are | 6 | 12-13-2007 09:33 AM |
| bed bar fab... my first project | slim99 | Fabrication/Tools | 10 | 10-15-2007 10:23 PM |
| I need a project :) | 99FlowedTaco | Tech | 16 | 04-22-2007 10:09 PM |
| Bad little project in AL | ATLRoach | Classifieds | 0 | 10-24-2005 07:11 AM |
| Need for project | Tacos4life | Wanted | 5 | 10-16-2005 12:51 PM |
