Sponsored Ad
Go Back   TTORA Forum > Desert Tech > Desert Race Rig Build Ups
Thread Tools Display Modes
Old 11-27-2008, 03:40 PM   #1
Rusty
Rusty's Avatar
Default tube sleeve
Are these tubes sleeved together and if so how long is the inner piece?
ID:	16151   Click image for larger version
Rusty is offline   Reply With Quote
Old 11-27-2008, 06:51 PM   #2
TimF
TimF's Avatar
Default
Yes, at least 6" with plug welds are the way to go.
TimF is online now   Reply With Quote
Old 11-28-2008, 08:50 AM   #3
Rusty
Rusty's Avatar
Default
what exactly is a plug weld?
Old 11-28-2008, 09:34 AM   #4
K.Patel
K.Patel's Avatar
Send a message via AIM to K.Patel
Default
I think plug weld is the same as a rossette weld.
K.Patel is offline   Reply With Quote
Old 11-28-2008, 12:20 PM   #5
Rusty
Rusty's Avatar
Default
So you fill in the holes and weld around the butt joint of the two peices?
Old 11-28-2008, 01:32 PM   #6
K.Patel
K.Patel's Avatar
Default
Yep thats how I have done it. TimF might have to confirm.
Old 11-29-2008, 10:08 AM   #7
TimF
TimF's Avatar
Default
This sleeve is about 6" long, I could not go longer with the bends above and below it.
This has a 10" sleeve in it. By plug weld I mean a 3/8 to 1/2" hole drilled in the exterior tube so you can weld to the sleeve in more places than just the splice.
Old 12-03-2008, 12:39 PM   #8
prerunnerguy
prerunnerguy's Avatar
Default
Is that truck ever gonna be finished???
04 Tacoma Double Cab caged, long traveled, linked, and S/C'd
prerunnerguy is offline   Reply With Quote
Old 12-03-2008, 04:08 PM   #9
TimF
TimF's Avatar
Default
Cage is almost done! Time to go weld on it right now!
You may not post new threads
You may not post replies
Forum Jump
Cam bolt sleeve in LCA wont come out! jrwing98 Suspension 10 10-16-2010 11:34 AM
Solid Pinion Crush Sleeve? KStacoma Early Tacoma Tech 15 05-23-2009 09:33 AM
Crush-Sleeve eliminator... SADGOAT Newbie Tech 2 02-05-2008 04:32 PM
Help!!! Sleeve Yoke problem. jbstrd Early Tacoma Tech 11 03-30-2006 10:59 PM
Copper compression sleeve Fernslinger Performance/Engine/Exhaust 3 01-19-2006 11:11 AM
Sponsored Ad
Privacy Policy
Links monetized by VigLink
