Sponsored Ad
Go Back   TTORA Forum > General Tech > Toyota Truck & 4Runner Tech
Thread Tools Display Modes
Old 12-07-2008, 06:21 PM   #1
GPorsch
GPorsch's Avatar
Default Super Strong Tie Rods!!!
So after starting to break rod ends, and doing research on stronger options, I've moved forward with building my own steering setup. I did all of this myself and all at the same time with the following:
New steering box (old one leaked)
Custom bronze bushings in the idler
Steel tie rods; 9" long, 1" o/d, .25" wall thickness (beefy)
Heim joint rod ends; 3/4" shank, 5/8" hole, chromoly body, hardened chrome ball, teflon lined (very stout)
Center link and steering arm tapered holes machined out to 5/8"
Total Chaos steering arm gussets
Grade 8 hardware throughout
I think this setup will be much stronger. The steering feel is much more precise now too.
'90 4x4 xtra-cab, V6, 5-spd, 33" MTR's, rancho torsion bars, ball joint spacers, downey shock hoops, longer bilstiens, idler arm braced and bushed, custom tie-rods w/heim joint ends, a-arm truss, rear leaf pack, rancho traction bars(for sale), 3" body lift, fabbed rear bumper, sliders, bed bar, snorkel. SAS in the works!
GPorsch is offline   Reply With Quote
Old 12-07-2008, 06:27 PM   #2
RedRunnertc
CO Chapter Prez
RedRunnertc's Avatar
Default
How did you adapt the knuckles to accept the heims?
President - CO Chapter
'96 Impala SS - my own personal cop car
RedRunnertc is offline   Reply With Quote
Old 12-07-2008, 07:05 PM   #3
Default
Looks great! My only concern would be all of those bolts that are now not caslte bolts. Better make sure that they stay tight. I would definately put some locktite on them.
Originally Posted by JeepGuy View Post
Yeah, Fuck EJS. If I wanted to hang out in a parking lot with a bunch of shiny geaps I'd go one of the malls in Scottsdale.
77 toyota longbed DD project
ike is offline   Reply With Quote
Old 12-07-2008, 07:16 PM   #4
GPorsch
GPorsch's Avatar
Default
I had to machine the steering arms to 5/8" all the way through. Stock setup they are tapered for factory rod ends. So I had them machined all the way through so that a 5/8" bolt could slide through.
The centerlink and steering arms a super strong forging! You can't just drill them out. I had to use a small boring bar on a lathe to do it! Very time consuming.
Old 12-07-2008, 07:16 PM   #5
wslytoy
I just got laid... off.
wslytoy's Avatar
Default
that's pretty slick!
05' TRD 4x4(gas guzzler)
85 4Runner 3RZ power! For sale!
85' 4Runner Build Up Thread
New Forum Rule
When in doubt, bring Wes' name into the argument to turn attention from yourself. Not sure of what to post b/c you're an attention posting whore? Call Wes' intelligence into question... Always good for a little snicker. And if you act fast enough, it's guaranteed to make you feel better about YOU.
wslytoy is offline   Reply With Quote
Old 12-07-2008, 07:29 PM   #6
Camstoy86
Camstoy86's Avatar
Default
Wow very nice, how much lift and on what size tires?
86 4runner, some goodies.
Hammer down.
Camstoy86 is offline   Reply With Quote
Old 12-07-2008, 10:06 PM   #7
GPorsch
GPorsch's Avatar
Default
Leaf pack in the back. Bigger torsion bars up front. 1.5" ball joint spacers. 3" body lift. 33" Wrangler MTR's.
It's all in my sig.
Old 12-08-2008, 07:43 AM   #8
Camstoy86
Camstoy86's Avatar
Default
It's all in my sig.
oh, haha I didn't even look. Nicely done though
Hammer down.
Old 12-08-2008, 09:16 AM   #9
hunter4runner
hunter4runner's Avatar
Default
are your lower bump stops bent ?
-Bobby
The above written is not intended to insult your mechanical ability, it is simply a suggestion or option.
hunter4runner is offline   Reply With Quote
Old 12-08-2008, 11:54 AM   #10
GPorsch
GPorsch's Avatar
Default
Yeah, they're bent pretty badly. Good eye! The guy who had the truck before me beat it up pretty badly. But now I get more travel! Ha!
Old 12-08-2008, 01:08 PM   #11
Gerdo
Gerdo's Avatar
Default
Looks great. I have a friend that has a 2nd gen 4runner, looks like the same set-up. He has some major problems. I would bet he has 2"+ of play, side to side. He needs to do this to his truck.
2000 4Runner.
3rd gen 4runner fuel tank skidplates http://lilskipsoffroad.wordpress.com/
Gerdo is offline   Reply With Quote
Old 12-08-2008, 01:22 PM   #12
CentralCoastTaco99
We Got What You Need!
CentralCoastTaco99's Avatar
Default
Looks good. Like it was mentioned earlier, you need to do something about the hardware that you used. I'd suggest getting some top-lock nuts for those bolts. Last thing you need is to have a nut come loose and end up swerving into oncoming traffic.
1999 Tacoma 4x4 TRD ext cab V6 5spd:
Long Travel, Tires, Fenders... the usual
CentralCoastTaco99 is offline   Reply With Quote
Old 12-08-2008, 03:07 PM   #13
GPorsch
GPorsch's Avatar
Default
I've gone off road pretty hard on it twice now. The very first time out, the bolts barely loosened up. Almost nothing. Probably just everything settling in. I re-tightened it and went out again even harder and no loosening at all. They're all very easy to access so I check them everytime I go off road. It should hold up well. But I may 'double-nut' them regardless just for that extra little bit of security.
Old 12-08-2008, 03:22 PM   #14
RedRunnertc
CO Chapter Prez
Default
One other thing is to run the bolts the other way - that way if the nut comes off, the bolt is still in the holes instead of falling out. Being that the load is almost totally in shear, all you need to do is hold the bolt in the holes - why not have gravity help?
Old 12-09-2008, 12:54 PM   #15
GPorsch
GPorsch's Avatar
Default
The reason I run the bolts from the bottom up is so that the smooth portion of the bolt has a tighter fit in the steering arm. Since there is more meat there it takes up more of the slack in the system. Plus if that top nut comes loose at all I would feel the play right away. And it has a long way to go before it threads itself all the way off. I think I still may double nut it just in case.
Old 12-09-2008, 01:28 PM   #16
hunter4runner
Default
I was looking at that going wow thats a lot of travel! then i realized. what was the total cost of this ? anyway ?
-Bobby
Old 12-09-2008, 02:24 PM   #17
jpsstewart3
jpsstewart3's Avatar
Send a message via AIM to jpsstewart3
Default
looks great man
butt...
u wouldnt have to worry bout breakin stuff if u had an SaS with hi steering. pays its off in the long run.
unless ure doin some pre-running/ jumping
1995 SR5 4Runner- SAS, rear locker, 4.88's, 35's, armor, bumpers, winch, lights, extras
jpsstewart3 is offline   Reply With Quote
Old 12-09-2008, 06:35 PM   #18
GPorsch
GPorsch's Avatar
Default
Total cost was not that bad. I was looking at the kit Total Chaos makes for like $500 or something and thinking to myself, "Thats crazy! I can build that for way cheaper!" So I start digging around on the net and find a part here, a part there and eventually come up with everything that I need. Heres a rough cost estimate:
Heim joints (rod ends).........$25 each
Tie rod tubes in steel..........$15 each
Jam nuts and spacers.........$10
Grade 8 hardware...............$30
Steering arm gussets..........$35
Machine work....................$30
So all in all about $235 for the tie rod kit. Plus some shipping and time and welding rod and paint. About $250 on super strong tie rods!
And... at the same time I sent my idler arm out to have bronze bushings made for it......$70
And I put A new IFS box in it.
And the alignment of course!
But it was well worth it. I'm really happy with it! I would do it again in a heart beat. I love making my own stuff!
Old 12-09-2008, 07:10 PM   #19
hunter4runner
Default
its really nice i've been thinking about something like that
-Bobby
Old 12-09-2008, 09:34 PM   #20
RedRunnertc
CO Chapter Prez
Default
These guys have them ready to go:
http://www.custommachiningusa.com/Specialty_Items.html
Old 12-09-2008, 10:46 PM   #21
GPorsch
GPorsch's Avatar
Default
Thats who I sent my idler to! They stock a couple of sizes of kits but due to all the varrying sizes of aftermarket or rebuilt idlers they don't always fit. So they ask you for accurate measurements and cutom machine a kit to fit.
OR.... You can send in your idler arm, THEY measure it, machine some bushings that fit, install them, and ship it back. All for no extra charge!!!
Old 06-29-2010, 04:36 PM   #22
AxleIke
Default
Old thread dig up:
How did you get the tie rods to clear the center link? I'm working on something similar, and the only way I see to get the tie rods to clear if you want them straight is to move the box and idler forward.
-1998 Corolla, Brotastic Edition. 195's, front bumper mod, trunk mod, fenders trimmed-
-Internet Nice Guy
AxleIke is online now   Reply With Quote
Old 06-29-2010, 06:46 PM   #23
hunter4runner
Default
looks like misalignment and washers
-Bobby
Old 06-29-2010, 07:18 PM   #24
AxleIke
Default
In that pic, it looks like his wheels are turned. When the wheels turn, there is gobs of room. Its when they are straight that they will bind at full stuff, at least from what I've seen.
Maybe its just enough with the washers to clear, but mine will hit really bad when compressed when the tires are straight.
-Internet Nice Guy
Old 06-29-2010, 09:21 PM   #25
hunter4runner
Default
it is its that he has enough washers to clear thats all
-Bobby
Old 06-30-2010, 10:12 PM   #26
RedRunnertc
CO Chapter Prez
Default
Isaac - if you need to bend the adjuster sleeve, Eric at NoCoAutoParts just got a bender and has a bunch of different dies. The smallest is 3/4" pipe IIRC.
Old 07-01-2010, 05:09 PM   #27
AxleIke
Default
Yah, I gots one now too! Though only 1.75 and 1.5 for now.
I don't want to bend it because it makes aligning the truck the traditional method impossible. I am moving everything forward. I wanted to try to do it in the stock location, but I don't want to use heims like he did.
-Internet Nice Guy
You may not post new threads
You may not post replies
Forum Jump
Super Strong Magnet for your oil filter NorcalPR Cheap Tricks 26 07-11-2008 04:47 PM
Strong D44 Complete Axle 4xClover Classifieds 4 03-02-2008 12:07 PM
How strong are the box compartments? ScreamingTaco Newbie Tech 7 03-29-2007 01:19 PM
D44 Strong Axle Shafts toycoma732 Solid Axle Swap Tech 14 04-25-2006 10:24 AM
new MAF truck running strong. talvaren Performance/Engine/Exhaust 3 09-19-2005 03:10 PM
Sponsored Ad
Privacy Policy
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
