05 tacoma 3" spacer lift, 1.5" wheel spacer and "285/75R16" 33's tires?? will it fit? - TTORA Forum
Go Back   TTORA Forum > General Tech > Tires/Wheels
Thread Tools Display Modes
Old 12-11-2008, 11:00 AM   #1
yellowpasta2000
yellowpasta2000's Avatar
Default 05 tacoma 3" spacer lift, 1.5" wheel spacer and "285/75R16" 33's tires?? will it fit?
Whats up guys!
-05 tacoma- Need new tires - want to replace with bigger tires. BFG A/T
-set up- My question... Will this work??
-3" lift in front (coil spacer)
-1.5" wheel spacer (for tire not to rub on upper control arm??)
-BFG A/T 285/75R16 - 33" tires.
Thanks for the help!
Anto
(05 tacoma 3" spacer lift, 1.5" wheel spacer and "285/75R16" 33's tires?? will it fit?)
yellowpasta2000 is offline   Reply With Quote
Old 12-11-2008, 11:03 AM   #2
snowboardman2002us
snowboardman2002us's Avatar
Send a message via AIM to snowboardman2002us
Default
probably.... but i wouldn't trust the wheel spacer....
07 Sport 4x4 Black - Pioneer D3 - Bilstein 5100's up front 2.5 lift - Uniden Pro520xl CB w/PA - Custom Bed Bar - Tint - Maglight MOD - 285/75/16 Nitto Terra Grappler but they rub - 16x8 AR Chambers - BLHM - Skull grill ornament - Back up lights - Bed lights - Alpine 500w Mono Amp - 2x Alpine type r 10" sub in fitted box - Rear TSB's - Rear Bilstein 5125 - K&N intake system - Flowmaster 40 series - Wheelers stainless steel lines F&R - HID 6000k headlight 3000k fog light
snowboardman2002us is offline   Reply With Quote
Old 12-11-2008, 11:10 AM   #3
yellowpasta2000
Default
y not? i hade 3" wheel spacers on my 04 tacoma i dont think 1.5" is any bad...
Old 12-11-2008, 01:59 PM   #4
drinkintedbr
drinkintedbr's Avatar
Default
3" wheel spacers on a DD? Jesus
drinkintedbr is offline   Reply With Quote
Old 12-11-2008, 02:44 PM   #5
yellowpasta2000
Default
HAHAHHAA. whats a DD? but yea i had 3 inch wheel spacers n had no problems with it 4 more then a year... i jumped the truck, off roaded, preeran... lol but dont have the truck no more it flipped over offroading. NOT DUE 2 THE 3" SPACERS!!!
Old 12-11-2008, 04:18 PM   #6
Taco12
Taco12's Avatar
Default
DD: daily driver... did it flip cuz of donuts? to answer the above question the 3 inch lift with 285's/33 on a 15" rim will work without the wheel spacers. I would not run wheel spacers at all it puts to much stress on your wheel studs and what not and will cause lots of problems. the toytec 3" kit will get you everything to run 285s and make your truck look good.
02 trd DC taco
Taco12 is offline   Reply With Quote
Old 12-11-2008, 11:29 PM   #7
yellowpasta2000
Default
ooh yeaa DD driven hard! lol taking off curbs almost everyday cuz 2 lazy to drive to exit of parkinglot at school hahaha
so without the 1.5" wheel spacer i wont have any rub with the tire on the upper control arm running 285/75/r16??
Old 12-11-2008, 11:30 PM   #8
yellowpasta2000
Default
another truck collided with me while both of us offroading and hit the front of my truck and made me spin around then went off flipping. effin 16 yearold kid in a ranger...
Old 12-20-2008, 09:40 AM   #9
darksyde
Default
I have a 05 tacoma with a 3" spacer lift and running BFG AT285/75R16's i get a little bit of rub when makind hard turns or when backing up and turning its not too bad but it get s annoying after awhile. I'm planning to get a 1" wheel spacer to fix that.
darksyde is offline   Reply With Quote
Old 12-20-2008, 01:08 PM   #10
BC_TACOMA
Default
I Agree.
BC_TACOMA is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
05 tacoma 3" spacer lift, 1.5" wheel spacer and "285/75R16" 33's tires?? will it fit? yellowpasta2000 Suspension 5 12-11-2008 10:52 PM
need 1" front coil spacer/1" lift spacer dirtrider15 Wanted 0 09-19-2007 10:38 PM
"clunk" with new spacer lift install on 05 Pirox Early Tacoma Tech 20 01-24-2006 03:36 PM
"Best" way to spacer lift? Top of strut, or coil spacer, or both? anestech* Suspension 14 01-27-2005 04:59 PM
1.5" wheel spacers with 86-88 IFS rims & 2.5" spacer lift? Cracker Early Tacoma Tech 5 12-26-2004 07:23 PM
