Tire rubbing on frame...how much lift do I need? - TTORA Forum
Go Back   TTORA Forum > Vehicle Specific Tech > PreRunner Tech
Thread Tools Display Modes
Old 12-13-2008, 06:06 AM   #1
TACOMA03
TACOMA03's Avatar
Send a message via MSN to TACOMA03
Default Tire rubbing on frame...how much lift do I need?
I'm running P265/70r17 on my 03 Dcab with the Tundra 17" wheels. The only issue I have is that it rubs the frame on the right side. It has actuall worn the paint off and bare "shiney" metal is showing. Anyone know how much lift i would need to eliminate this? Also, what type of paint would you use to touch up the frame?
Thanks!
2003 Tacoma PreRunner V6 SR5 Double Cab
There are many choices in life,
Eternity only has two.
John Seltzer
TACOMA03 is offline   Reply With Quote
Old 12-13-2008, 07:24 AM   #2
countryboyAL
countryboyAL's Avatar
My Rig: 1989 pickup
Smile
I really dont know how much lift would help i hope someone else more knowledgeable can help you there. I usually just use a black spraypaint and put a couple of coats on the frame. Hope this helps
89 Pickup
AO front winch bumper, taylor fab sliders and skids, trailmaster lift in front, stock duals, 36x13.50 Irok, 4.88 gears, lockrite in the rear, 63" Chevy leafs
Originally Posted by TacoDell View Post
~ off road thought, for the day ~
" if ya wheel like an idiot... it probably shows "
Originally Posted by cztheman64 View Post
yeah but you wheel like Tim Cameron
countryboyAL is offline   Reply With Quote
Old 12-13-2008, 07:30 AM   #3
02tacoSR5
02tacoSR5's Avatar
My Rig: 2013 Tacoma DCLB 4X4
Default
Sounds like spacers might be your best bet. Is it rubbing in the front or rear?
02tacoSR5 is offline   Reply With Quote
Old 12-13-2008, 07:31 AM   #4
TACOMA03
TACOMA03's Avatar
Default
RUBBING IN THE INNER REAR OF THE FRONT RIGHT TIRE
John Seltzer
Old 12-13-2008, 07:37 AM   #5
pray4surf
Just another newb....
pray4surf's Avatar
Default
Any coilover lift (adjustable / spacer) is not going to give you enough 'lift'. Needless to say a body lift will do nothing to rectify that rub.
A drop-bracket lift or a SAS will work.
The 'right' alignment tech could probably alleviate some of that rubbing.
But the tried and proven method will be to reduce backspacing. Stock toyota rims typically have a backspacing of 4.5", Many have found that 4" (or 3.75") is satisfactory. So you either live with the rub, replace the rims, use a wheel spacer, or reduce the tire height and/or width.
Mine rub, but I've acquired a 'feel' for how much steering wheel 'turn' I've got before the rubber hits the frame and adjust my driving accordingly.
As for paint, why bother - it's just going to rub right off. Unless you correct the 'cause'. In that case, sand-prime-paint with any metal compatible paint - Rustoleum rattle cans will be just fine.
I call myself "El Jefe"....other call me "pendejo".....I prefer El Jefe...
SoCal TTORA Forum
SoCal TTORA Website
pray4surf is offline   Reply With Quote
Old 12-13-2008, 10:53 AM   #6
hot-taco
hot-taco's Avatar
Default
or use Old Man Emu springs any lift will get rid o some of the rubbage mabey some lift spindels mine pushed the tires out 1.25 inches on each side
Officer: Excuse me sir, is that a water bong?
Driver: No sir, indeed not! That right there is my J-Pipe!
Sorry, we're too busy playing with our MIDS. Check back later!
critersized
hot-taco is offline   Reply With Quote
Old 12-13-2008, 06:34 PM   #7
02tacoSR5
02tacoSR5's Avatar
Default
Probably gonna have to get you a set of spacers. I bet being stock wheels that it has a real high backspacing that is pushing everything into the fenderwell causing it to rub.
Old 12-13-2008, 10:10 PM   #8
lunarmist02
lunarmist02's Avatar
Default
None of the OME springs will get rid of it,I had 882's and they had no affect on the frame rub. Like others have said, a different back spacing should do it. 4" bs worked for me.
lunarmist02 is offline   Reply With Quote
Old 12-14-2008, 12:00 AM   #9
My Rig: 1999 tacoma
Default
Backspacing or wheel spacers.
ike is offline   Reply With Quote
Old 12-14-2008, 10:24 AM   #10
tacoma_2002
tacoma_2002's Avatar
My Rig: 2002 Tacoma
Send a message via Yahoo to tacoma_2002
Default
wheel spacers, but i bet when you space them out from the frame they're gonna rub your inner fenders...i'd get a set of like 1-2" lift springs (ome etc.) and do a AAL or a set of longer greaseable shackles....any way you go wheel spacers will still be a must....any kind of black spray paint will do the trick on the frame
2002 Xtra Cab TRD Taco 3.4 Manual
Super White 2
Lifted, Locked, Armored
2007 Double Cab TRD Taco 4.0 Auto
Silver Streak Metallic
2.5 SAW's, 2.0 Icons rear with Deaver pack
Originally Posted by SafetyDang View Post
Look at my picture I posted you can see that you may need 2-3 more inches.
tacoma_2002 is offline   Reply With Quote
Old 12-14-2008, 10:45 AM   #11
JOEPRUNC
JOEPRUNC's Avatar
My Rig: 2004 Taco
Default
The stock backspacing on your old tacoma rims were 4.5". I belive the Tundra wheels that you put on have 5" backspacing. I don't think a lift or alignment will do enough to cure the problem. Looks like your going to need to install some longer wheel studs and a 1/2" wheel spacer to get the BS back to 4.5".
As mentioned above 4.5" to 3.75" BS is what the majority are going to be running.
2004 Ext. Cab V6 5spd. 4X4
Camburg CO & Dakars
15x8 Mojaves w/32 KMs
DO Sliders / R. Bumper
On the hunt for:
R. Locker; On board Air; F. Bumper
JOEPRUNC is offline   Reply With Quote
Old 12-14-2008, 03:33 PM   #12
79coyotefrg
79coyotefrg's Avatar
Default
where do you get these "slide on" spacers?? (need for a top secret project)
um i would use these
http://www.marlincrawler.com/htm/axles.htm
AR-TTORA founder/current President, www.ar-ttora.com
22R bored .060 over, LCEngineeing stage II race cam, 3236 weber,
entire drivetrain from www.Marlincrawler.com 1200 NON ceramic clutch, L52HD 5 speed + dual transfer case. Driveline E-brake, front suspension and hi-steer from www.allprooffroad.com
79coyotefrg is offline   Reply With Quote
Old 12-14-2008, 04:36 PM   #13
hytenor
hytenor's Avatar
My Rig: '00 Tacoma
Default
Thanks!
No amount of lift will solve your problem. Get rid of the wheels an use properly backspaced ones (see above)
wheel spacers only put huge more stress on the already weak spindle bearings.
Originally Posted by Teryx View Post
Yeah, well, I'm just glad I snagged a few Spector cans before EPA converted them to Sphincters
Originally Posted by Tacoma Jake View Post
Lube may be your best friend (depending on location).
'00 Excab Tacoma, 2.7, 5sp with a Bunch-o-mods
Inchworm Rock Walkin' Gear
hytenor is offline   Reply With Quote
Old 01-13-2009, 12:09 PM   #14
off_road_punk
off_road_punk's Avatar
Default
smaller back spacing?
07 tacoma pre-runner l camburg LT l DMZ l
off_road_punk is offline   Reply With Quote
Old 01-19-2009, 09:47 PM   #15
yellowpasta2000
yellowpasta2000's Avatar
Default
any 1 have the link 2 the pinch weld mod 3 the 05+ tacomas 2 fit bigger tires without rubbing???
yellowpasta2000 is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
Tire rubbing frame Logan Tech 13 12-11-2008 07:20 AM
Frame rubbing JVK Early Tacoma Tech 4 09-16-2008 10:53 AM
tire rubbing Nate Newbie Tech 6 08-04-2008 07:40 PM
new tires rubbing frame jason Tires/Wheels 7 08-14-2007 01:18 AM
Tire rubbing on passenger side frame? Details Newbie Tech 13 12-21-2005 06:44 PM
