Sponsored Ad
Go Back   TTORA Forum > Desert Tech > Long-Travel Suspension Tech
Thread Tools Display Modes
Old 01-20-2009, 07:29 PM   #1
ledzeppelin135
Default alcan springs
hi i am wondering if any one has had experience with alcan leaf springs. i have an 01 2wd 5 lug tacoma leaf under and i am looking at getting an 8 leaf alcan, but i am wanting to pull around 14 inches of travel. I have 14" travel kings that are going to be bolted to a shock hoop after i cycle the leafs, but will i be able to pull 14" travel with the alcans. Also i am worried about stiff ride and hopping. I will give them mall the correct information about my truck but will it stop most hopping and give a good ride. They told me it would be about 300 plus shipping for custom leaf springs which is better than deaver by far. But just give me your opinions thanks alot
ledzeppelin135 is offline   Reply With Quote
Old 01-25-2009, 11:41 AM   #2
devinsixtyseven
devinsixtyseven's Avatar
Default
Well, if you're just gonna hit the mall, it ain't gonna matter ...
This is actually a question for Alcan, they will know their own springs best. In general, you can estimate the suspension can be cycled the natural arch plus an inch (maybe two) of negative arch, plus half the length of your shackle, depending on how the springs were designed to operate, how thick the leaves are, etc...so like I said, you really gotta ask Alcan how far that spring pack can cycle (not including shackle), then add half the length of your shackle...that's a decent estimate for what you'll get from that pack.
I sorta doubt it's gonna be 14", particularly if it's a stock-length pack. My Alcans (built for weight, not travel) should be able to get 11" on their own (9" natural arch, 2" negative arch & that's pushing it), plus about 2" more from shackle movement, on a 60.5" main leaf with 8 leaves a hair over 0.25" thick and a double-wrapped half leaf on the front of each pack.
Let them know you need travel, IIRC they'll use thinner leaves vs what they use on packs like mine which were designed to carry excess weight.
It will help if you can give them the weight over the rear axle. Most truck stops can help you, either free or for about eight bucks. Subtract...oh...maybe 350# & the weight of your wheels & tires, that's about how much weight you have on the rear suspension.
You'll have very little wheel hop compared to stock, and they'll ride great at whatever weight you specify they need to ride great at...hopefully that makes sense. Mine are awesome, they're pushing seven years old, and should have another 5 years or more on them before they're considered "worn"...Alcan usually guesses about 150k miles of normal use, unless you're always reversing them or racing on them.
'00 Project, constant state of (d)evolution
Originally Posted by Atilla the Tundra
That will sound like godzilla throwing schoolbuses full of screaming children into a wood chipper. Have fun with your fix it tickets!
"Tonight, you are going to hear...music you've never heard before. Tonight...you are going to hear...the most cantankerous, poisonous, roughneck dubplates ya ever HEARD!"
devinsixtyseven is offline   Reply With Quote
Old 01-25-2009, 05:19 PM   #3
RkcrawlrWnab
Default
300?! 300 hundred what, dollars? Thay just told me 500 for stock replacement springs...
RkcrawlrWnab is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
Alcan springs Mxtaco48 Parts/Electronics/Wheels & Tires For Sale 4 04-02-2007 08:33 PM
Alcan springs J94runner Tech 7 02-08-2006 07:50 AM
alcan springs toubabokoomi Suspension 3 12-05-2005 07:50 PM
Alcan springs? mohawk17 Early Tacoma Tech 13 11-04-2005 02:43 PM
OME Dakar springs or Alcan Springs ? xcmountain80 Suspension 11 03-09-2005 11:24 AM
Sponsored Ad
Privacy Policy
Links monetized by VigLink
