#1 |
Anybody know how you remove the rear window on a 95? its a reg cab w/o a slider... Thanks
#2 |
Are you trying to save it? If not use a BFH
1998 Toyota Tacoma X-Cab TRD 3.4L 5 Speed IT GOES WHEREVER I POINT IT!!!!! |
#3 | |
Get in a possition where you can push on both ends with equal preasure with your feet from the inside. It will pop right out and hurt nothing.They are made to do that as well as the front . Mike
2001 Tacoma SR5 4x4 , step side, 2.7 , extended cab, Auto. Mobile 1 syn 5w30 , Valvoline 75-90 syn in front and rear diffs and transfer case. Factory 16" wheels ,31" Wild Country TXR 265/75/R16, Aluminum Betterbuilt bed tool box, CB , 55W Halogen light mounted on tool box for back up, Elbow air box mod, 2 500 Hella running lights, Nissan clinometers/Altimiter custom mounted on dash with red back lights.Red dome and mapp light. 2,35watt backup lights. |
#4 |
Hogtie it with the string after you get it out????????
#5 |
Use a guitar string.
#6 |
well, I was trying to get it from the outside..... locked the damn keys in it again and someone suggested this once before. but no worries, I just cut it open with a chainsaw
BTW what do you use the string for?
#7 |
Is there a more detailed explanation somewhere of how to remove but more importantly install a new one? I have a 95.5.
#8 |
I just removed and installed another and it only took an hour start to finish. Basically I stuck a couple of screw drivers between the window rubber seal and the body of the truck on the outside. Moving the screw drivers I was finally able to pop the window out.
Replacing the window took more time. I slid the window in as much as I could making sure the rubber seal was where it was supposed to be inside the cab on the top and to one side. Then using the screw driver method I ran along the bottom of the half I slid in popping the rubber seal to the inside. Then I did that corner. Then I started from the middle towards the other side. I was just going to take it to a shop but I'm sure this saved me $20-$50 minimum. |
| Thread Tools | |
| Display Modes | |
| Canopy Rear Window Vision (Wipers/Visors?) | Beave | Cheap Tricks | 17 | 04-26-2005 03:32 PM |
| Rear end clunk (not axle wrap?) | BajaTaco | Early Tacoma Tech | 28 | 04-07-2005 05:30 PM |
| Sliding Rear Window? | CuriousJ0N | Interior/Electrical/Electronics | 4 | 03-27-2005 06:31 PM |
| Need rear glass window | PreRunnerTaco | Wanted | 2 | 03-24-2005 09:50 PM |
| Rear window defroster for fiberglass cap | Uneasy Rider | Early Tacoma Tech | 3 | 12-23-2004 08:53 PM |
