Sponsored Ad
Go Back   TTORA Forum > General Tech > Suspension
Thread Tools Display Modes
Old 01-27-2009, 05:08 PM   #1
kigmob
kigmob's Avatar
Default Bilstein 5100 questions
I have a 1997 Toyota Tacoma 4WD with a 3 in. Tuff Country suspension lift. The lift is pretty old too. I don't know exactly how much lift the front spacers and rear blocks give my truck but I was looking into replacing my shocks with Bilstein 5100 Adj shocks in the front (I would remove the spacer in the front) and my back shocks with the regular Bilstein 5100 shocks. I was wondering if the Bilstein 5100 Adj shocks would give my truck the same amount of lift in the front as the spacers and also if the rear shocks would work with the lift blocks I have installed. Also would the Bilstein shocks give my truck a noticeably smoother ride? I am running 32" tires and I would like the Bilstein shocks to not make my truck sit any lower. Please help!
kigmob is offline   Reply With Quote
Old 01-27-2009, 05:34 PM   #2
redrazr
redrazr's Avatar
My Rig: 2011 Tacoma 4WD
Send a message via Yahoo to redrazr Send a message via Skype™ to redrazr
Default
the 5100's will lift your truck up to 2.5" and will ride better than the spacer. the rear 5100's are good for up to 3" of lift so it depends on how tall the block is.
http://www.wheelersoffroad.com/9504tacoadjbils.htm
CURRENT: 2010 Mustang GT Premium Black
2.5" offroad H-pipe
SOLD: 2011 Tacoma Regular Cab 4WD Auto Black Sand Pearl
SOLD:
2007 Tacoma Regular Cab PreRunner SR5 Radiant Red
redrazr is offline   Reply With Quote
Old 01-27-2009, 05:56 PM   #3
kigmob
kigmob's Avatar
Default
ok thanks! Im pretty sure the rear block is no bigger than 3 in. so I should be good.
Old 01-27-2009, 07:35 PM   #4
kigmob
kigmob's Avatar
Default
Any other answers out there? Or suggestions of another way I could give my truck about 3 in. of lift and still have a smooth ride?
Old 01-28-2009, 06:53 AM   #5
PowellTacoma
PowellTacoma's Avatar
Send a message via AIM to PowellTacoma
Default
If you have 32's just get the adjustable bilstein shocks for the front and set them on the mid setting. For the rear, trash the blocks and go with a small(long) lift add-a-leaf kit or shackle kit with the bilsteins in the rear too.
I use to have 32s on my atock height truck with no rubbing, so you won't need that much lift to clear them. Every truck is different though.
/_TN TTORA_/
2002 3.4L Limited TRD Badass Prerunner Double Cab --- Pics.Vid
-stock TRD suspension
-*currently converting to 4WD*
-265/75/16 BFG All-Terrains
PowellTacoma is offline   Reply With Quote
Old 01-28-2009, 07:01 AM   #6
01 Double Cab
01 Double Cab's Avatar
Default
So these shocks you speak of lift our truck without new springs? Are they stiff as hell?
2001 Double Cab 4x4 TRD Limited
Tundra Brake Upgrade
Magnaflow Catback
ARB Bumper
Donahoe Coilovers
OME Dakars with D6XL AAL. 5125 Bilsteins
Timbrens
Cooper ST 255/85 R16 on "port install Toyota wheels" painted Semi Gloss back by yours trully.
New frame courtesy of Toyota.
01 Double Cab is offline   Reply With Quote
Old 01-28-2009, 11:36 AM   #7
redrazr
redrazr's Avatar
Default
yes, they lift your truck and ride better than the stockers
2.5" offroad H-pipe
SOLD:
You may not post new threads
You may not post replies
Forum Jump
HELP!! Bilstein 5100 Adj boggyboy Suspension 24 01-11-2009 12:08 AM
bilstein 5100 hahirajay Newbie Tech 9 01-07-2009 05:14 PM
Bilstein HD or 5100? toyotatruckman Suspension 5 05-24-2007 08:29 PM
Bilstein 5100? SinCityTaco Suspension 2 03-02-2007 12:06 PM
bilstein 5100 Q's 2LONGTOY89 Suspension 2 04-15-2005 09:21 PM
Sponsored Ad
Privacy Policy
Links monetized by VigLink
