Sponsored Ad
Go Back   TTORA Forum > TTORA Chapter Forums > Official TTORA Chapter Forums > Indiana Chapter > Tech
Thread Tools Display Modes
Old 03-11-2009, 07:00 PM   #61
muddertrucker99
muddertrucker99's Avatar
Default
Bear keep me updated if gadget may think its the fuel pump also. But it could be possible that the fuel pump is failing.
97 4runner Buds skids,Aussie locker(front),Arb locker(rear), Cooper stt's 285/75/16 on black steelies, Custom built bumper front by Hardnose welding and truck equipment!
98 tacoma sas'd gone
muddertrucker99 is offline   Reply With Quote
Old 03-13-2009, 09:17 AM   #62
NwiTACO
My Rig: 2005 TACOMA DCSB
Default
So what are you going to try this weekend? (WOW! I actually replied in your thread...)
Blue Ribbon Coalition #4847
'05 Tacoma DCSB, 35/12.5/17 MTR's, Rear Disc Brakes, ARB's F/R, Fox C/O's & Airbumps up front w/ All-Pro LT, 14" 7100 resi's/63" Chevies in back, full tube bed, Hella 500 w/ HID conversion, XRC 8000# winch, Dual MV50 On-board air
'02 Tacoma DCSB, OME 881's, Dakars, and Nitrochargers
Former InTTORA President - 2009-11
NwiTACO is offline   Reply With Quote
Old 03-13-2009, 09:51 AM   #63
Bear
H-O-L-Y-------S-H-I-T-H-H-A-A
Bear's Avatar
My Rig: 1997 Toyota Tacoma
Default
Thats a first!
1) "sniffing out" all the vacuum lines
2) double checking vacuum line routing
3) See if the check valve is installed properly and not clogged
4) crank angle sensor. (Gadget says the teeth of the broken crank pully should be stuck to it as it is magnetized and if so, it would throw all the readings off
5) disconnect the TCM1.1 box
If none of that works, then just work on electrical and interior and call Gadget back
BEAR
OVERKILL IS AN UNDERRATED ACHIEVEMENT
Originally Posted by abbott
… remember, in the world of cars and trucks, its not cubic inches, its cubic dollars.
GO SPURS GO!!!!
Bear is offline   Reply With Quote
Old 03-15-2009, 06:52 PM   #64
muddertrucker99
Default
Did you working the truck this weekend?
Old 03-15-2009, 07:13 PM   #65
Bear
Bear's Avatar
Default
very little. I checked the vacuum lines to make sure everything was routed correctly and it was! all the vacuum lines appeared to be in good shape.
I pulled the crank angle sensor as Gadget said that it could possibly be holding the missing teeth from the crank pulley gear. But they were not on the sensor ( so the mistery continues on where they ended up)
I went to have the sensor tested, but of coarse no one could test it on a Sunday so it was cleaned up and put back in. I need to move the toyota tomorrow and with a gapping hole where the sensor sits, I didn't feel like spraying new motor oil out of it.
I am basically lost on what is going on. the "usual suspects" are not yeilding any answers.
I even contemplated this morning pulling the entire motor and start tearing it down to rebuild. But I am keep telling myself the problem is going to be something simple because everything else in the motor appears to be in great shape, other than it not wanting to accelerate.
BEAR
GO SPURS GO!!!!
Old 03-15-2009, 08:19 PM   #66
DN1911
Default
has anyone checked the compression on ALL the cylinders?
DN1911 is offline   Reply With Quote
Old 03-16-2009, 09:24 AM   #67
brinner
Brian
brinner's Avatar
Default
Originally Posted by Bear View Post
...........I even contemplated this morning pulling the entire motor......
minus the video for the first 10 seconds....
http://www.freeonlinegames.com/fun-g...und-board.html
...yup that pretty much represents anything i could possibly say to that comment.
brinner is offline   Reply With Quote
Old 03-16-2009, 09:54 AM   #68
NwiTACO
Default
I just don't know what to say anymore except good luck Bear!
Old 03-16-2009, 10:22 AM   #69
Bear
Bear's Avatar
Default
I don't think it is any major component, otherwise it would not be running so well at idle.
To address Dustin's question, no compression check has been performed as I don't know anyone with a compression gauge that will work with 3.4's. but at this point I am willing to give anything a shot.
I have to install the hitch on the ford tonight so I will be doing that, and then back to the toyota to thrash until this weekend.
I began thinking again about the TMC1.1 timing control box that is attached to my ECU outputs. I recently (well before the troubles) had some monkey working on my stereo, and I have found other items behind my dash that were cut and spliced back together etc. or just not working any longer. So my latest theory hinges around all that.
I am wondering if he had not bumped or pulled a wire from that TCM which is throwing things off. My next step is to take the glove box back out and inspect all the wires, if they are still visibly okay/connected, I am going to disconnect the box and see if maybe it just has gone bad.
It is electrical and electrical items do go bad. The last time I messed with the settings, I noticed the lack of reaction of the truck to the adjustments I was making. so maybe this is part of all that.
But at the time of adjustments, I didn't think much of lack of response, because the differences normally seen are so small anyway it is actually hard to notice them.
BEAR
GO SPURS GO!!!!
Old 03-16-2009, 08:16 PM   #70
DN1911
Default
i would have someone do a compression check just to be safe. That Toyota dealer we were talking about can at least do that. other than that there could be a loss of spark or fuel up in the RPM range. as far as figuring that out i don't know.
you may want to go have a chat with the owner of Linder Fuel Injection on the Alley. they specialize in rare and hard to diagnose FI problems. you may be able to make arrangements to have them look at your truck if the compression check comes back good. they are awesome at what they do and the only place i can think of that may be able to help you.
Old 03-17-2009, 01:47 PM   #71
jason6746
inttora
jason6746's Avatar
Default
i second the compression check. it will at least tell you if the motor itself is sound.
2001 tacoma 2.7 5sp.
with some
amsoil dealer
jason6746 is offline   Reply With Quote
Old 03-17-2009, 10:32 PM   #72
Bear
Bear's Avatar
Default
I contacted Linder at the very beginning of all this trouble a few days after the truck stalled on the way home from your parents house. I was told that they did not do anything with Toyota motors or injectors.
If you know someone over there to talk to I am all ears. I will admit, I did not talk to the owner, but I did talk to a tech and not just someone in the "office"
The latest task is to remove the TMC1.1. Gadget seems to have a systematic approach to this so I am trying to follow his lead. I gave him all the symptoms, what parts already removed/changed. I gave him the readings the dealership came back with so he is pretty much up to speed with everything. And he is the one suggesting the removal of the piggy back.
I was going to pick up a compression tester today, but ran out of time, as well as asked to play basketball with my littlest one...as much as I want the truck running, I have to keep the "priorities" in order. AS always "flesh and blood over Metal"!
BEAR
GO SPURS GO!!!!
Old 03-18-2009, 09:37 AM   #73
brinner
Brian
brinner's Avatar
Default
unless you can find a way to make your family out of metal
Old 03-18-2009, 09:50 AM   #74
Bear
Bear's Avatar
Default
then I would have to worry about heavy metal poisoning!
BEAR
GO SPURS GO!!!!
Old 03-24-2009, 07:40 AM   #75
Bear
Bear's Avatar
Default Linder fuel injector service
I stopped in Linder fuel injector service on Gasoline alley this morning on the way to work. (Dustin's recommendation) but as I was told in the past, they do not work on Toyota's.
But I pressed the issue (reason for going in person instead of calling as I had done previously) and got one of their injector "wizards" to agree that they can look at the injectors and clean them as long as I take the injectors into them out of the vehicle.
He said it would only take them a day to inspect and clean. So I should be able to drop them off in the morning and pick them up tomorrow night (If I am able to get off work early enough)
Since there is only four injector manufactures out there, they can still do an awesome job on servicing them. and quite possibly have the larger injectors I need in case they are too bad to service (at least that is my hopes) Bottom line is that they can inspect them and know what they are doing, even though they only work on domestics. The parts are still the same.
I was really hoping that they had the wide band sensor I was looking for to borrow, but when I mentioned it, I got the "cold fish" response I expected.
BEAR
GO SPURS GO!!!!
Old 03-24-2009, 07:55 AM   #76
NwiTACO
Default
You think nowadays work would be work. Guess some people still don't care...
Old 03-24-2009, 08:01 AM   #77
Bear
Bear's Avatar
Default
I think in this case it is quite the opposite, they care so much about their craft that they still insist on specializing.
Besides in doing research on the company, it seems the owner has his hands in a few ventures with the main one being training of technicians and only has the injector service on the side of that more as support than any other reason.
Walking into the office though was like walking back in time. I haven't been in a speed shop like this in quite some time. almost museum atmosphere.
IN fact reading their website yesterday starting back in 06 they have made more than one trip out to Bonnivelle with a vehicle they have built! which in it's self is pretty damn cool
BEAR
GO SPURS GO!!!!
Old 03-24-2009, 08:04 AM   #78
NwiTACO
Default
I can go to Bonneville with a tricycle
Old 03-24-2009, 09:00 AM   #79
Bear
Bear's Avatar
Default
you are not much of a history buff are you.
bonnivelle is Cool as shit-tha.
anything with speed and wheels are cool!
BEAR
GO SPURS GO!!!!
Old 03-24-2009, 12:59 PM   #80
Bear
Bear's Avatar
Default Most Recent update!!!!!
For some reason I have always been intimated about removing the supercharger. Don't ask me why, just a phobia that has developed.
Anyway, since I am planning on taking the injectors up to an injector shop to be cleaned and inspected. I asked a neighbor/friend that has been helping me with this all to go ahead and start removing the injectors (he is home unemployed) so that I wouldn't be on the truck all night.
Well he has already removed the injectors which means the supercharger was the first thing to come off the motor.
And Holy Sh-i-t-t-a!!!!!!!
the intake gasket is split! which would cause a severe vacuum leak! and what has been the symptoms? yup! that is right… a sever vacuum leak.
I am somewhat excited, as I am really thinking/hoping this is the cause.
I know I have felt this way before, but we have also never seen anything so blatantly obvious that was wrong either!
New gasket is being ordered as well as injectors cleaned. (Might as well since they are out of the truck anyway!)
BEAR
GO SPURS GO!!!!
Old 03-24-2009, 01:01 PM   #81
NwiTACO
Default
I am happy and sad at the same time. I call shotty on some runs in Harlan if it's fixed! I thought you had already checked/replaced that gasket?
Old 03-24-2009, 01:05 PM   #82
Bear
Bear's Avatar
Default
Were you really wanting to tow your truck that badly?
on it being fixed, don't hold your breath yet, just keep your fingers crossed!
BEAR
GO SPURS GO!!!!
Old 03-24-2009, 01:38 PM   #83
NwiTACO
Default
Naw, just bein me Doesn't really matter. Depending on how much crap we (YOU) have, we may just fit in my truck. Don't know what kinda milage you'd get towing, but I doubt it is better than my crappy milage.
Old 03-24-2009, 01:44 PM   #84
tacoma_2002
tacoma_2002's Avatar
My Rig: 2002 Tacoma
Send a message via Yahoo to tacoma_2002
Default
hmmmm....i hate to brag, but......
I Told U So!!!!
2002 Xtra Cab TRD Taco 3.4 Manual
Super White 2
Lifted, Locked, Armored
2007 Double Cab TRD Taco 4.0 Auto
Silver Streak Metallic
2.5 SAW's, 2.0 Icons rear with Deaver pack
Originally Posted by SafetyDang View Post
Look at my picture I posted you can see that you may need 2-3 more inches.
tacoma_2002 is offline   Reply With Quote
Old 03-24-2009, 01:46 PM   #85
Bear
Bear's Avatar
Default
Remind me sometime to tell you the "evolution of the thought process" of all this mess!
maybe "if" this turns out to be the problem you will understand more of my frustration than the average person.
BEAR
GO SPURS GO!!!!
Old 03-24-2009, 01:50 PM   #86
Bear
Bear's Avatar
Default
Naw back at you. if the truck is still not fixed, then we will tow your truck with the trailer! I told you we would and I don't break promises.
Besides. you may break something with me riding with you so we will need to get back to Indiana some how anyway!
I have not towed with the tow stroke yet so I need to see what the milage is going to be. so if my truck ain't ready yours will serve as the guinea pig!
BEAR
GO SPURS GO!!!!
Old 03-24-2009, 01:53 PM   #87
tacoma_2002
My Rig: 2002 Tacoma
Default
just glad your actually turning up possibilitys now instead of running blind about the ordeal. I'd be willing to make a wager that thats your issue or at least I hope it is...maybe now you'll be able to sleep at night
Super White 2
Old 03-24-2009, 01:55 PM   #88
Bear
Bear's Avatar
Default
Life is too short to loose sleep over a truck!
Hell who I am kidding! I think I have put more thought into this damn problem than I have over all other parts of my life!
Now maybe I can start thinking about that deck I promised the misses. LOL
BEAR
GO SPURS GO!!!!
Old 03-24-2009, 01:58 PM   #89
NwiTACO
Talking
I though that was gonna be done a few weekends ago? As I am slowly learning, it is true that you have to keep the misses happy...or nobody's happy...really...I've never had to kiss so much ass in my life!
oh, btw :fingerscrossed: for ya man!
Old 03-24-2009, 03:02 PM   #90
Bear
Bear's Avatar
Default
Oh, the deck is being built, but I just have not had a lot of time to think out the details for it. that is all I am meaning.
and yes, kiss some ass to get some ass!
BEAR
GO SPURS GO!!!!
You may not post new threads
You may not post replies
Forum Jump
2002 Tacoma 2wd Prerunner lack of rear braking power.... tomytum Early Tacoma Tech 4 01-04-2009 10:05 PM
random lack of power!! Portman Early Tacoma Tech 1 06-04-2008 07:35 AM
lack of power? Spacecwboy Pickup/4Runner Tech 1 11-11-2007 08:37 AM
for the lack of a bigger truck masternayte Pickup/4Runner Tech 1 08-25-2006 12:00 AM
Lack of Power scottdeane Performance/Engine/Exhaust 7 08-15-2006 12:09 PM
Sponsored Ad
Privacy Policy
Links monetized by VigLink
