Sponsored Ad
Go Back   TTORA Forum > General Tech > Interior/Electrical/Electronics
Thread Tools Display Modes
Old 06-29-2005, 09:37 PM   #1
taugust
taugust's Avatar
Default Power off timer?
Does anyone know how to tap into the circuit that has power after the key is removed (like the interior and headlights)? I would like to have power without the key for some things but I like the power-off battery saver feature. I have done the full time power outlet mod. Can the power outlets be modified to cut out after 30min?
2003 Tacoma V6 4x4 TRD ExtraCab
Tuff Country 5" Lift, King Coilovers, 33x10.50R15 BFG MT's, Black Steelies, Viair 450C Air Compressor and Tank, Custom Swaybar Disconnects, Yaesu FT-857D All Band Amateur Radio, Bestop Softtop, K&N Filter, Dual Batteries, LED Rocklights, Custom Sliders.
Deck Plate, Gray Wire, Rear Shock Spacer, Two-Low, Free Alarm Mods
Member Cal4Wheel, Tierra Del Sol 4WD Club
taugust is online now   Reply With Quote
Old 06-29-2005, 10:02 PM   #2
nilson
nilson's Avatar
Send a message via AIM to nilson Send a message via Yahoo to nilson
Default
Probably the quickest and easiest thing to do would be to run a new hot wire to the battery and you will need to find a 12V DC timer to throw in the circuit. Put a fuse block on that and then you can have a new set of timed circuits.
1996 4Runner Limited / 3.4L V6 / 4x4 / E-Locker / 204,000mi and counting
2005 Honda CRF250R
nilson is offline   Reply With Quote
Old 06-30-2005, 10:51 AM   #3
absolut taco
absolut taco's Avatar
Default
Man, I would love it if the damn headlights would shut off when I turned the key off. I love my DRLs but I shouldn't have to open the door or hit the light switch to keep from draining the battery if I wanna remain in the vehicle.
2004 Tacoma Extended Cab 4x4 TRD | 3.4 Liter V6 | 5-speed manual
absolut taco is offline   Reply With Quote
Old 06-30-2005, 11:04 AM   #4
nilson
nilson's Avatar
Default
yeah... I cant think of a reason why the headlights need to remain on without a key in the ignition... if you want your lights to shine on something you should be close enough to the truck to have the key in it
2005 Honda CRF250R
Old 06-30-2005, 11:15 AM   #5
TRD SyRuP
Send a message via AIM to TRD SyRuP Send a message via MSN to TRD SyRuP
Default
i love the door open light off feature..
TRD SyRuP is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
lost low end power... help? bigd9247 Performance/Engine/Exhaust 9 02-27-2006 04:51 PM
engine has no power tommylevy Performance/Engine/Exhaust 5 04-06-2005 09:43 PM
No power in power steering MarzzTaco Early Tacoma Tech 4 02-28-2005 03:14 PM
Cold Weather and Power Steering sjvicker Early Tacoma Tech 2 01-14-2005 02:10 PM
Ignition On Power Sources TheChiefSinner Interior/Electrical/Electronics 5 12-30-2004 07:55 AM
Sponsored Ad
Privacy Policy
Links monetized by VigLink
