Home | Events | Emergency Rescue Team |
Sponsored Ad
Go Back   TTORA Forum > TTORA Chapter Forums > Official TTORA Chapter Forums > Colorado Chapter > Extreme Mods & Wheeling
User Name
Thread Tools Display Modes
Old 04-18-2009, 12:31 AM   #1
00regcab
00regcab's Avatar
Default 3.4/ext cab swap
Started the swap tonight, Russell and I started around 4, and had the cab off and motor ready to come out of my truck when Doug showed up around 6:15.
Doug and i got the cab situated, and everything moved around for some space to work. Got the 2.7 motor mounts cut off my frame (PITA BTW), and the 3.4 mounts cut off the frame section (i have pictures showing the differences, i'll get them posted up Sunday or so, along with all of the others).
Cutting the mounts off carefully (to not bend/damage them) was a huge pain in the ass, but I managed to get the task done. After a few more hours of work (and a pinched pinky later), Doug and i got the 3.4 lined up (transfer case x-member is in the same location, but the mount on the 3.4 t-case is wider) and the mounts tacked onto the frame.
Tomorrow I'll do the finish welding on the mounts, and get the 3.4 in (should be done by noon), then its onto the cab.
The cab is going to have to be notched to fit over the frame rails at the rear section, and the floor pan will have to be tubed to clear the gas tank. Also will have to figure out what I'm going to do for the filler neck so I do not have to run it through the cab.
Progress is going good, this is the biggest step. Cutting up the bed, and triangulating the shocks will be the easy work. I have to triangulate the shocks since where the new bed mount will be needs to be on the inside of the frame, right where the passenger shocks bolts to. The tabs are already on my axle, so all I need to do is get a cross member welded in and the degree set on each shock. For now I wont do a u-bolt flip, but it will happen down the road (probably not before moab, but whatever).
Just thought I'd post up some basic info, once everything is DONE and I have time to sit down and resize/edit/upload pics I'll get that done, along with all of the info, and step-by-step processes of the actual motor swap, and what needs to be done to the cab.
00regcab is offline   Reply With Quote
Old 04-18-2009, 05:33 AM   #2
My Rig: 1999 tacoma
Default
Good to hear.
I like goats
87 cherocar
ike is offline   Reply With Quote
Old 04-18-2009, 09:00 AM   #3
Nate
Nate's Avatar
Default
can wait to see the pics
4xinnovations sliders,lockers, Ome 881's,
Rear 63" chevys , Arb front bumper,
Custom rear bumper, winch, Natebuilt skids and some other stuff
Nate is offline   Reply With Quote
Old 04-18-2009, 09:05 AM   #4
mrdoug
mrdoug's Avatar
My Rig: 3.4 swapped 85 xcab
Default
it's amazing how easy the 2rz-5vz swap is when you're also swapping the cab. All electrical issues should be void. Doing all this with no cab in the way is like cheating.
I'm afraid I might loose the bet that this can't be done in a weekend. I might have to cut some wires or something today to seal the victory.
de·gen·er·ate
mrdoug is offline   Reply With Quote
Old 04-18-2009, 10:26 AM   #5
Avsfreak1234
Avsfreak1234's Avatar
My Rig: 98 Taco, 35s n Stuff
Default
nice! cant wait to see the final result
Avsfreak1234 is offline   Reply With Quote
Old 04-18-2009, 11:10 AM   #6
poorboyota26
poorboyota26's Avatar
Send a message via MSN to poorboyota26
Default
What are you doing with the 3rz?
86 runner
Rebuilt 22re, r151, ep9.0, 31's, addicted front bumper
04 Tacoma DC with custom body work
Dreams of owning a fzj80, fj60, fj45 troopy.
Originally Posted by thefatkid View Post
Yea, 2 days later and I still feel like a sack of assholes.
Originally Posted by Mr.Leary ExPo
Years from now, when we are dead and gone... the roaches will be driving little Toyotas with 3.4s.
poorboyota26 is offline   Reply With Quote
Old 04-18-2009, 11:27 AM   #7
extremepaint
extremepaint's Avatar
Default
hell yea nate! GET IT!!!!
i cant wait for teh pics!
extremepaint is offline   Reply With Quote
Old 04-18-2009, 11:32 AM   #8
Sucka
Sucka's Avatar
Default
Can't wait to see the pics and final product on the trail.
Thanks for the update Nate!
04 Tacoma DC 4x4 - E-Locker - Camburg 2.5's - RevengeFab Sliders - Badlands Bumper
Sucka is offline   Reply With Quote
Old 04-18-2009, 01:02 PM   #9
Quick Draw
Quick Draw's Avatar
My Rig: DORIS
Default
1980 Toyota Pickup: CB antenna, custom 2-tone paint, duct tape mod, weight reduction, 29" meats. sway bar and torque bar removed for MAD FLEX.
Quick Draw is offline   Reply With Quote
Old 04-18-2009, 02:04 PM   #10
thefatkid
My Rig: Your Mom
Default
Installing it in his honda so it will be fast
Sorry I could not make it up. Ft. Fun is too far away for just the evening. The drive time would have been killer.
1996 4runner outfitted with a ton of ARB stuff. Got some Warn Items also
1983 Hilux, nuff said
thefatkid is offline   Reply With Quote
Old 04-18-2009, 08:02 PM   #11
My Rig: 1999 tacoma
Default
Russ it taking the 3rz.
I like goats
87 cherocar
Old 04-18-2009, 11:08 PM   #12
Nate
Nate's Avatar
Default
Old 04-18-2009, 11:27 PM   #13
RedRunnertc
RedRunnertc's Avatar
Default
Took tons of pictures on Nate's camera...
There's a picture floating around of someone who chopped a 2nd gen runner and went straight down behind the rear seats, and then has a little flatbed.
That's pretty much what Nate's creation looks like right now.
Got a lot done today:
Motor is in and pretty much everything is hooked up.
Body is in place, most of the clearancing is done. Mounts are tacked in.
Almost all of the body-frame interfacing parts are hooked up (steering, wiring, etc)
Still a long ways to go:
Weld solid the body mounts
Patch holes in the floor required for clearance
Figure out the gas tank situation
Bleed the brakes, etc.
President - CO Chapter
'96 Impala SS - my own personal cop car
RedRunnertc is offline   Reply With Quote
Old 04-18-2009, 11:34 PM   #14
Lysmachia
Almost Out of 9 Lives
Default
Was a full day. I think I turned a wrench. Once... But We were there for 12 hours. I wish we had been able to get Nate's Gas tank hooked up but we ran into issues with the hard lines when dropping the XCab down.
Lysmachia is offline   Reply With Quote
Old 04-18-2009, 11:49 PM   #15
00regcab
00regcab's Avatar
Default
I would say we are definitely on the downhill side of things.
HUGE thanks to troy, doug, jay, and molly for the help today.
As already stated, the 3rz drivetrain belongs to Russ. He is going to be putting it in his truck.
Heres a teaser pic. Because I'm too fucking tired to go through and edit all of them...
As i said in the other thread, doubt me and i'll prove you wrong.
Still a little more to do, but it'll be running/drivable under its own umph tomorrow.
Old 04-19-2009, 12:01 AM   #16
Nate
Nate's Avatar
Default
lookin good
Old 04-19-2009, 12:01 AM   #17
00regcab
00regcab's Avatar
Default
BTW troy, this the runner you're talking about?
Found the pic buried on my comp, i wont have to tub my cab quite that much.
Heres two others i found of SWB frames with ext cabs.
Stretched wheel base about 2"
Same wheel base, but the cab itself is shorter on the older trucks.
Old 04-19-2009, 12:28 AM   #18
99FlowedTaco
Shrockworks 4x4 Products
99FlowedTaco's Avatar
Send a message via ICQ to 99FlowedTaco Send a message via AIM to 99FlowedTaco Send a message via MSN to 99FlowedTaco Send a message via Yahoo to 99FlowedTaco
Default
lookin good
Mitch
2002 4Runner SR5 - DD
http://www.shrockworks.com
Got questions on a product we sell , please PM any questions.
99FlowedTaco is offline   Reply With Quote
Old 04-19-2009, 07:53 AM   #19
Quick Draw
Quick Draw's Avatar
My Rig: DORIS
Default
Good work, Nate. No doubt in my mind, now.
Are you staying with white, or are you changing colors? I personally think the black looks great.
It kinda looks like one of those trucks thats so modded that it should be SAS'd by now... I definitely like the route you're taking, though. Its unique.
Old 04-19-2009, 08:13 AM   #20
mrdoug
mrdoug's Avatar
Default
unique is an understatement. I'm looking forward to seeing how he reworks the rear floor for all that clearancing. I know he'll work some magic, just not sure I can visualize what he's describing.
If ever there is an easy way to do a swap, this is it. It is cheating, no 2 ways about it.unplug, unbolt, move, plug it in, bolt it up. The ex-cab on short frame is the hardest part but even that is looking pretty straight forward.
He'd be driving it now if only we hadn't misplaced that front gas tank strap. And no, I didn't misplace it to throw him off the pace.
Nate, don't forget when you write this up...
Things to do with the cab off: hook up P/S lines change diff breather (if needed). What a PITA doing it after the fact.
BTW.. are you going to change your damn screen name again?
de·gen·er·ate
Old 04-19-2009, 08:30 AM   #21
Jacket
Jacket's Avatar
Default
Wow Nate - incredible! I guess I missed the thread where you were planning to do this. Are you going to keep the (chopped) bed, or just tube it? Seems like a little bit of storage is needed for trips and such?
1976 FJ40
2006 Tacoma *Sold*
Jacket is offline   Reply With Quote
Old 04-19-2009, 09:43 AM   #22
Avsfreak1234
Default
ya nate, whats the new sn? 03extcab.w/3.4_onstdcabframe
we did make a lot of progress yesterday and it looks good. definitely the way to do a 3.4 swap. once we dropped the body on the harness just plugged in and all the vacuum lines just slipped on. i gotta see what you end up doing to the floor though.
Old 04-19-2009, 09:53 AM   #23
AxleIke
Default
Looks really good Nate!!!!!!!
I like the black as well.
I'm voting VERY strongly that you tube bed the back of that thing. The regular bed will just look silly. JMHO.
AxleIke is offline   Reply With Quote
Old 04-19-2009, 10:52 AM   #24
stubby3vze
stubby3vze's Avatar
Default
looks nice keep the black
91 runner,chopped,locked,armored.
stubby3vze is offline   Reply With Quote
Old 04-19-2009, 10:56 AM   #25
00regcab
00regcab's Avatar
Default
Thanks for the comments.
I plan to keep the black, and just re-paint the bed black after i shorten up the front.
Kyle, i feel the same. With how this thing looks i feel it should be bigger (sas, 35's-37's etc.).
Isaac, I disagree with the tube bed. If i was bigger (sas, etc.) i would be all over a tube bed. But with how small the truck still is, i want it to look OEM. Like it came from Toyota this way.
Getting ready to head up north to do more work on it, give me a ring if you're in the area and have some free time.
seven too zero 951 twenty three thirty five
Old 04-19-2009, 11:39 AM   #26
Avsfreak1234
Default
you want it to look OEM? really? it has a 3' bed. just pointing that out. even the honda ridgeline has a 5 foot bed!
Old 04-19-2009, 12:24 PM   #27
RedRunnertc
Default
Yeah, that is the 4Runner pic I was thinking about. They didn't tub it, that's how 4Runners are ... your bed will be about that same size!
Old 04-19-2009, 01:19 PM   #28
vwfastg60
vwfastg60's Avatar
Default
Im sure nate will post the rest of the pics from the weekend when its all done. Im Leaving now to go up and help him finish it up and do up the tail light harness. I have to say this is the fastest swap of this kind i have ever seen.
We had a blast up there yesterday even tho we couldnt stay the whole time.
87 DLX longbed, Bobbed a foot with soft topper, 3rz,dualcases,4.7 rear case,5.29's, elockers front and rear,4" SAS, Taco dash, Recaro seats, Diamond front and FJ cruiser axles 67.25" wms to wms, Brembro brakes for FJcruiser,Raceline beadlocks, 37" mtr kevlars Rear armor and tire carrier, fjc interior bits.
vwfastg60 is offline   Reply With Quote
Old 04-19-2009, 01:24 PM   #29
Avsfreak1234
Default
id head back up to help nate but i have way to much shit thats due tomorrow to break from it. i could help out next weekend if its not done by then. and if it is done i want to see it
Old 04-19-2009, 06:17 PM   #30
AxleIke
Default
Eh, well, no worries. Its your truck man. Just throwing my .02 in the ring LOL. Looks killer man!
You may not post new threads
You may not post replies
Forum Jump
3.4 swap and a 5 speed swap!!! yotaman Tech 18 12-02-2008 05:41 PM
Cab Swap Spacecwboy Pickup/4Runner Tech 1 05-12-2007 05:54 PM
Cab Swap Amber00Dak Pickup/4Runner Tech 4 12-09-2006 10:30 PM
Oil Pan Swap before SAS? GreenTaco4x4 Solid Axle Swap Tech 11 12-07-2006 12:23 PM
3.4 swap Full_Tilt_Fud Pickup/4Runner Tech 4 11-24-2005 08:08 AM
Sponsored Ad
Privacy Policy
Links monetized by VigLink
