HomeAboutEventsForum
Sponsored Ad
Texas TTORA Forum
Go Back   TTORA Forum > TTORA Chapter Forums > Official TTORA Chapter Forums > Texas Chapter > Tech
User Name
Thread Tools Display Modes
Old 04-18-2009, 09:19 AM   #1
84 tx yota
84 tx yota's Avatar
Default suspension question
Ive started the 63 in chevy rear swap on my 4runner. After measureing I mounted the front hangers 11 1/2 in forward of the existing. I built 6 in shackles and mounted them in the stock rear hanger. When I put weight on them they went all the way to the frame. My question is should I move the shackle hanger, use dual shackles, or do a 3/4 eliptical set up? I know a 4 link would be best but Im working on a tight budget. I have a welding machine, cutting rig ect.... so the fab work isnt bad. Im just looking for which direction I should go. Ive done searches on the eliptical setup and read the good and bad so Im aware, people still useing it. I havent found much on dual shackles though. If annyone has a pair of hangers laying around pretty cheep that would help too. Anny helpful info apreciated.
84 tx yota is offline   Reply With Quote
Old 04-18-2009, 02:52 PM   #2
troublesome222
troublesome222's Avatar
Default
On my Taco with 63s I have the stock Chevy shackle bolted to the stock Toy shackle. The Toy shackle sits against the frame when not flexed. Then swings down to give awsome droop while flexing. The shockes are in the stock location and limit the droop, for now. But I need to move the hanger to give a better shackle angle and a better ride on the street.
But for your situation I would suggest moving the hanger back a few inches by grinding the welds and rewelding it.
For my Runner I bought the cheepest ones I could fine, $20.
http://www.davezoffroadperformance.c....php?f=3&t=517 If you can find the correct size tubing you could make some.
Jess
99 Tacoma Prerunner TRD "CONVERTED TO 4WD" Fully locked, 3.5" Fabtech, 63" Chevy, DP mod, CBI sliders, 33s.
83 Toyota Land Cruiser FJ-60
SOLD
85 4Runner "Project LeatherNeck"
http://www.tacomaterritory.com/forum...d.php?t=112767
troublesome222 is offline   Reply With Quote
Old 04-20-2009, 08:35 PM   #3
84 tx yota
84 tx yota's Avatar
Default
Finaly ground the rear hangers off and welded tham back on, 4 in down the frame.
Old 04-22-2009, 04:32 PM   #4
Bear80
Bear80's Avatar
Default
Here is my writeup for the chevy spring swap on to my '86 pickup.
Keep in mind you'll need to do have a double cardan joint drive shaft made. Just take front drive shaft, have it lengthened and install a multi drilled rear output flange on the t-case.
1986 Truck - Hybrid IFS & Chevy Leafs
1997 FZJ80 - Locked, Lifted, Setting and Looking Pretty
Range Rover Recovery Vehicle
Bear80 is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
suspension question Chris12789 Newbie Tech 0 08-22-2006 03:27 PM
Question Suspension Iggy General Discussions 3 01-22-2006 06:12 PM
Suspension question fiveo Early Tacoma Tech 6 06-30-2005 07:11 PM
Yet another suspension question Toyota4x46921 Suspension 17 05-05-2005 02:14 AM
suspension question tacojustin Tell us who you are 2 04-23-2005 02:13 PM
Sponsored Ad
Privacy Policy
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
